Hi. I can’t seem to update/install any software via Add/Remove Software.
sudo pacman -Syu
But with no change to the problem.
Hope that someone could help, I’d be very greatful.
Thank you
sudo pacman -Syu
Thank you
Welcome to the forum!
Yes, it’s a known problem, caused by the archlinux-appstream-data package
. The devs are working on it.
Meanwhile, update your system with…
sudo pacman-mirrors -f && sudo pacman -Syyu
Thank you very much for letting me know, I will run the suggested line as recommended.
Best wishes
Y
There was an update to libpamac
earlier today, which fixes the bug introduced yesterday.
