Are af=drc and ad-lavc-ac3drc=1 in mpv.conf good options?
This bug report to mpv suggests af=drc and ad-lavc-ac3drc=1 are not good options
"af=drc" causes sudden jumps in audio volume · Issue #2759 · mpv-player/mpv · GitHub
But this meta:question has 3 options
DRC for Movies that have quiet dialogues but very loud sound effects? · Issue #8418 · mpv-player/mpv · GitHub
--audio-channels=stereo
(downmix to stereo is all I use on media players)
--af=format=channels=stereo,loudnorm
FFmpeg Filters Documentation - 8.83 loudnorm
--af=format=channels=stereo,dynaudnorm
FFmpeg Filters Documentation - 8.71 dynaudnorm
I need to use mono, is it viable option? Also i wrote mpv.conf, is the symbol - - valid? Do i need all the above?
Remixing audio to mono is probably viable but I would notice the loss of stereo sound and would not using that option myself
the option prefix --
is needed for terminal or script commands but is not needed If you are making a custom configuration file ~/.config/mpv/mpv.conf
mpv does not have a system configuration file, but it does have an example configuration file /usr/share/doc/mpv/mpv.conf with some of the option settings commented out with #
Ok but do i need all the above options?
I can’t answer to what you need. I suggest you try all the options and use what works and sounds good for you and your system
I use audio-channels=stereo
for audio to stereo speakers and that is usually enough to hear dialog and backing music from the surround sound mix, so I have not tried using additional filters
