I’m trying to install the NVENC patch for my graphics card but it requires a the 390.87 version of the driver while the one I have is 390.144.
Is there a way to replace it without messing up my installation since mhwd does not allow for specific file installation?
Thanks
Why are people editing my post?
I don’t believe there is a way to do so without issues. You’d need to downgrade every package that depends on that specific version, and also downgrade packages that depends on those packages that you just downgraded, and then same cascading downwards from there.
If that’s the case, then here are the nvidia packages that I have:
Packages:
lib32-nvidia-390xx-utils 390.144-1
linux510-nvidia-390xx 390.144-2
mhwd-nvidia 470.57.02-1
mhwd-nvidia-390xx 390.144-1
Here are the list of dependencies for each one of them:
$ pacman -Qii linux510-nvidia-390xx
Required By : None
$ pacman -Qii lib32-nvidia-390xx-utils
Required By : lib32-libglvnd
$ pacman -Qii mhwd-nvidia-390xx
Required By : mhwd-db
$ pacman -Qii nvidia-390xx-utils
Required By : lib32-nvidia-390xx-utils libglvnd linux419-nvidia-390xx linux510-nvidia-390xx linux54-nvidia-390xx
It’s not that complicated I think, any ideas ?
This patch is really important as it takes the load of the CPU and gives it to the GPU.
It can enhance my machines performance by a good margin. Since my CPU does most of the work, I would like to have that patch in my machine.
Fabby
August 28, 2021, 3:43pm
6
Because you posted your question in the wrong category: Your problem is unrelated to #support:plasma and is purely a #support:graphic-cards issue.
Then take a Cold System Backup:
Difficulty: ★★☆☆☆
If you follow the tutorial completely, you will be able to create a backup of your entire system not only limited to Manjaro, but also including Windows, RHEL, Ubuntu, … whatever else you might have installed on your system!
Even if your replace your HDD by an SSD, your HDD crashes, your entire system gets stolen, … you can always restore a Cold System backup to an identical system (You cannot restore E.G. a Dell XPS onto a Dell PowerEdge and then expect that to wo…
and then just do it and if you mess up, restore the system backup!
