# <file system> <mount point> <type> <options> <dump> <pass>
UUID=2218-9BA3 /boot/efi vfat umask=0077 0 2
UUID=180cdfdd-3557-4ce8-bfcc-c5abc43b2883 / ext4 defaults,noatime 0 1
UUID=96ef776b-98cf-42a9-b213-7e7417fae936 swap swap defaults,noatime 0 0
Got a brief scare when I used gdisk to reorder partitions (I wanted the ESP/sda1 in front of sda2 the way a fresh install would look like) and my system wouldn’t boot. I used a manjaro ISO to reinstall grub and that seemed to fix the problem. Would this affect disk performance? (sry about the paranoia. I’m using this computer mostly for gaming and I don’t deal with disk partitions very often.)
I am a bit curious though, why would renumbering the partitions cause grub to fail? sda1/sda2 isn’t mentioned anywhere in the grub config file and I thought newer versions of grub only use partition UUIDs.
