Looking for a Cinnamon section so I can ask a technical question there.
No, there is no specific category for Cinnamon. Depending on your issue, you could look for the closest match (Maybe Support
→ Software & Applications
because it’s probably installed from the Manjaro repos).
And you should set the cinnamon
tag as the user below indicates.
Will do, thank you.
Cool frog, what species?
I don’t know, it was just sitting there posing for me. Probably something middle-european because that’s where I took the photo (at least hopefully).
Edit: Google classifies it as “common frog” and the linked wiki page shows an identical image. So as generic as frogs come
There is you can find it in support./cinnamon!
Not listed as separate category, like @mithrial
already said
See below:
