Is Manjaro on DeX possible
#1
As I am sure some of you are aware. Samsung announced Linux on DeX today. It will be a version of ubuntu because they have partnered with canonical.
Would it be possible to use this same app and covert it to boot Manjaro instead. I would absolutely die if I could get manjaro on my note 9. I have already registered to get the beta when the drop it.
Manjaro on Samsung Linux on Dex
Manjaro on DeX
#2
Pretty certain this will be using an ARM CPU, so Manjaro won’t work.
Manjaro-ARM might, but it would need to support the hardware.
It’s unlikely it will work OOB.
#3
  • Linux on DeX currently supports one customized Ubuntu image (Ubuntu 16.04 LTS version provided by Canonical) which only operates on selected Samsung devices. (Note9 and Tab S4).
#4
I read that, I am just curious that if I can get that application information into the hands of the manjaro devs. Would they be able to reference the ubuntu build and convert it possibly to manjaro arm.
#5
Don’t double post thanks Manjaro on DeX
#6
Hello I posted this early in the general discussion forum out side of Manjaro ARM.
Samsung announced Linux for DeX, I was wonder would it be possible to use that software to figure out how to get Manjaro on DeX to work?
If so when I get the beta app how do I gather the right information and share it with you wonderful devs.
#7
Typo?
Linus —> Linux
#8
My bad, Thank you!
#9
First of all i dont have a samsung phone.
To have manjaro. You could rather root your phone, install full linux on it, then you can vnc from phone to localhost to a full linux desktop on your phone.
Dex seems to be a desktop linux for samsung phones. With its own set of desktop applications. I doubt there would be mutch linux on dex, but if they are claiming it will be that is cool.
Come back and update when you have tested it ? :slight_smile:
#10
For it to be possible to get Manjaro on it, there would have to be a kernel and bootloader (like uboot) available for it.
#11
Threads merged and moved
closed #12
This topic was automatically closed 89 days after the last reply. New replies are no longer allowed.
opened #13
