Is it safe to uninstall these Gnome packages from Cinnamon?
On my laptop there is a cascade of “Required By” as follow:
  • Nautilus
  • xdg-desktop-portal-gnome
  • gnome-session
  • gnome-shell
  • gnome-control-center-x11-scaling
    Interestingly none of those 5 apps are installed on my desktop pc that uses the same edition/version of Manjaro (exactly the same down to the same theme/font/background etc…)
I googled the x11-scaling and I came across a post on this forum with issues about it not working - but it was from 2022 - so probably fixed!
Anyway, if I understand correctly, the purpose of x11-scaling is to increase/decrease the display by a fractional % (75%, 100%, 125%, etc…)
So I checked and compared the ‘Display’ settings in both the laptop and the desktop. They are as follow
On the Desktop (remember it does NOT have x11-scaling)
In the settings tab ‘Enable fractional scaling controls (experimental)’ is set to Off
In the layout tab ‘User interface scaling’ has 100% or 200% options and is set to 100%
Enabling ‘Fractional scaling’ adds more options in 25% increments
On the Laptop
In the layout tab ‘User interface scaling’ only 100% options is available
Enabling ‘Fractional scaling’ does Nothing! still only 100%
I actually don’t have a need for fractional scaling and looks like x11-scaling is not working! so it should be safe to uninstall all 5 apps (starting from x11-scaling back up to Nautilus)?
Hi @chameau -
As I know nothing about Cinnamon, and your original support request has been solved, I have moved your post asking if it would be safe to remove some Gnome packages to this new topic.
none of these are present in my Cinnamon installation - they belong to Gnome
see above - same here
You must have installed something which had at least one of these packages as a dependency.
I do not know at the moment how to check which package
(likely AUR, but that is only speculation)
that might be/have been.
Now that we know that none of those packages are required by your Cinnamon system (thank-you @Nachlese ), you can check if any other installed packages rely on them by using the same command that you ran in the other thread:
pamac info package-name
And checking the “Required by:” line of the output.
Or, you could just skip all of that and run the command:
pamac remove nautilus xdg-desktop-portal-gnome gnome-session gnome-shell gnome-control-center-x11-scaling
If any other installed packages require them, pamac will let you know. If nothing relies on them, then they will be uninstalled when you enter your password.
Thanks but I already used ‘pacman’ to find the “Required by” line
pacman -Q -i package-name
I then repeated the command with the “required by” package-name until the response was ‘None’ that gave me the 5 packages I listed in my first post.
I then used pacman to remove all 5 packages one at a time in reverse order
sudo pacman -Rns package-name
Now Nautilus is gone and all works fine.
I do have another issue with AUR packages, but I create another post for that
