Random question but, is it safe to remove the layouts package on Manjaro Gnome? And with it also the extensions like dash-to-dock, dash-to-panel, …
Is there a list of dependencies that are required by the Layouts app that can/should be removed when I delete it?
I use vanilla Gnome 40 and only have the Pamac updates indicator and User Themes extensions enabled so it seems like overkill to have all these unused dependencies installed. Or am I making a big deal out of something that really isn’t?
Dash to dock is already removed btw, because I had some issues with it when going to Gnome 40 a while back and I don’t use it anyway so
Hello.
The manjaro gnome plugins and software can be uninstalled. There will be no harm to the system.
Note: I didn’t uninstall the software, but I made Gnome vanilla. Programs don’t interfere. They wrote above - they are useful +1
I don’t know, this morning I had 2 updates according to the indicator. Now O had a bunch. Just installed them along with making the changes to layouts and the extensions. Now I can’t boot.
I can do alt+f2 and login tot tty but that doesn’t help tbh.
Yeah, I think I found the issue. Did a journalctl _UID=1000 and I am getting errors from gdm-x-session. Which is weird because I am on Wayland. Following the steps again I could see that 61-gdm.rules has uncommented the nvidia wayland lines but commenting them again doesn’t fix the issue.
Tbh, I’m considering just doing a reinstall. I don’t have the time to spend hours on trying to fix this on a work machine. Typing all of this on my phone is also extremely frustrating.
