kalzEOS
January 21, 2022, 12:01am
#1
Hi everyone,
This is my very first post on these forums, so I’d like to apologize in advance if I’m posting in the wrong place.
I have intel/nvidia hybrid graphics. I don’t need Nvidia, because I don’t really do anything graphics intensive. Also, I want to get rid of nouveau because it’s been causing issues with my wifi usb adaptor (completely black screen after suspend where I can’t do anything beside force power off the laptop. Not even TTY). So, I’m forced to run the “auto install proprietary driver” in the settings, but that is eating the battery really quick on my laptop. So, my question is, like the title says, is it at all possible to run only on intel’s graphics? Like disable nvidia and nouveau completely? (Note that I don’t have an option to disable nvidia on my BIOS) If so, how? I am not an advanced user by any means, but I can follow instructions, as long as they are not too complicated. Also, I don’t know what’s currently running my system, intel, nvidia or nouveau. Like I mentioned, I did “auto install proprietary driver” from the hardware configurations in the settings.
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=33b9cef7-8b09-4b5c-b8d4-405d1f320df4 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=935eaefd-5656-4168-9c4a-f670924802a4 udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: Dell product: Inspiron 7573 v: N/A
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: Dell model: 0X1X3N v: A00 serial: <superuser required> UEFI: Dell
v: 1.22.0 date: 12/14/2021
ID-1: BAT0 charge: 35.6 Wh (73.9%) condition: 48.2/56.0 Wh (86.1%)
volts: 16.8 min: 15.2 model: LGC-LGC3.553 DELL 81PF3 type: Li-ion
serial: <filter> status: Charging
Device-1: hid-0018:04F3:2540.0001-battery model: ELAN2097:00 04F3:2540
serial: N/A charge: N/A status: N/A
RAM: total: 15.37 GiB used: 4.19 GiB (27.3%)
RAM Report:
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2300 high: 2302 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2300 2: 2300 3: 2300
4: 2302 5: 2300 6: 2300 7: 2300 8: 2300 bogomips: 32012
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep sgx
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Dell driver: nvidia
v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:174d
class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0bda:58f5 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: ASUSTek 802.11ac NIC type: USB driver: rtl88x2bu bus-ID: 1-3:2
chip-ID: 0b05:184c class-ID: 0000 serial: <filter>
IF: wlp0s20f0u3 state: up mac: <filter>
bus-ID: 1-7:4 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 476.94 GiB used: 61.58 GiB (12.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: SC311 SATA 512GB
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0P10 scheme: GPT
ID-1: / raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
used: 61.57 GiB (13.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 33b9cef7-8b09-4b5c-b8d4-405d1f320df4
used: 6.6 MiB (2.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: B4A1-7FAC
ID-3: /home raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
ID-4: /run/timeshift/backup raw-size: 467.84 GiB
size: 467.84 GiB (100.00%) used: 61.57 GiB (13.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: 33b9cef7-8b09-4b5c-b8d4-405d1f320df4
ID-5: /var/cache raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
ID-6: /var/log raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 935eaefd-5656-4168-9c4a-f670924802a4
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: ASUSTek 802.11ac NIC type: Network driver: rtl88x2bu
interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA chip-ID: 0b05:184c
Device-2: 1-5:3 info: Realtek Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 1-7:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 55.0 C pch: 52.0 C mobo: 52.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 3206
Processes: 298 Uptime: 3h 2m wakeups: 7 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1330 lib: 342
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole
inxi: 3.3.12```
I have nvidia GeForce MX130, but I don't know why it isn't showing in the settings.
Thank you in advance
kalzEOS
January 21, 2022, 12:18am
#3
Fixed it. Hope that works now.
cscs
January 21, 2022, 1:02am
#4
Thanks.
I would suggest first make sure to have only the following mhwd profiles installed:
video-linux
video-moesetting
If you dont know how click this
Here is an an example of listing, removing and installing:
mhwd -li
sudo mhwd -r pci video-nvidia
sudo mhwd -i pci video-linux
Then blacklist nouveau:
printf 'blacklist nouveau\noptions nouveau modeset=0' | sudo tee /etc/modprobe.d/blacklist-nouveau.conf
If you want to go further and make sure the card is fully powered down you can probably do so with acpi_call. To install the module for your kernel:
sudo pacman -Syu $(ls /boot | awk -F "-" '/^linux/ { print $1"-acpi_call" }')
(you may wish to restart here - especially if there were a number of updates)
Then load the module:
sudo modprobe acpi_call
And try turning off the card with the provided script:
sudo /usr/share/acpi_call/examples/turn_off_gpu.sh
kalzEOS
January 21, 2022, 2:48am
#5
A couple of questions if you don’t mind.
Will this disable nouveau and nvidia and leave only intel?
Also, this command you provided
Do I just run it as is, or do I replace the “examples” with something?
And which provided script are you talking about?
I’m trying to post a screenshot of my current set up, but I can’t. I have “video-hybrid-intel-nvidia-prime” on both nvidia and intell sections. Then after that, I have modsettings checked. All of that is in the “installed” section.
Here is what mhwd -li
give me
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
cscs
January 21, 2022, 3:00am
#6
kalzEOS:
Run as-is, that is the path. It is the script.
(note - .sh
is a common extension for scripts)
Then remove it with
sudo mhwd -r pci video-hybrid-intel-nvidia-prime
kalzEOS
January 21, 2022, 3:09am
#7
Running
gave me this:
sudo: /usr/share/acpi_call/examples/turn_off_gpu.sh: command not found
cscs
January 21, 2022, 3:13am
#8
Did you install and start the module ?
kalzEOS
January 21, 2022, 3:14am
#9
Twice. The second time to make sure I did. I rebooted after installing it then ran the last command.
cscs
January 21, 2022, 3:18am
#10
It wont be loaded after a restart, we are just testing it.
So make sure it is loaded with modprobe.
And … oh, maybe we want to do it a little differently…
cd /
sudo ./usr/share/acpi_call/examples/turn_off_gpu.sh
kalzEOS
January 21, 2022, 3:24am
#11
Same results.
Installed it with this command
did NOT reboot
then ran
then cd /
and
and I’m still getting this
sudo: ./usr/share/acpi_call/examples/turn_off_gpu.sh: command not found
cscs
January 21, 2022, 3:26am
#12
Ok … now the lookyloo:
pacman -Qs acpi_call
lsmod | grep acpi_call
ls -la /usr/share/acpi_call/examples
kalzEOS
January 21, 2022, 3:28am
#13
This is what I got
[kalzi@Jaro /]$ pacman -Qs acpi_call
local/linux515-acpi_call 1.2.2-4 (linux515-extramodules)
A linux kernel module that enables calls to ACPI methods through /proc/acpi/call
[kalzi@Jaro /]$ lsmod | grep acpi_call
acpi_call 16384 0
[kalzi@Jaro /]$ ls -la /usr/share/acpi_call/examples
ls: cannot access '/usr/share/acpi_call/examples': No such file or directory
[kalzi@Jaro /]$
cscs
January 21, 2022, 3:31am
#14
…hah. I gave you the wrong path.
(it was missing the kernel-module directory)
/usr/share/linux515-acpi_call/examples/turn_off_gpu.sh
kalzEOS
January 21, 2022, 3:34am
#15
Ran it without sudo
and got a bunch of “permission denied” then ran it with sudo
and got this:
[kalzi@Jaro /]$ sudo /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh
[sudo] password for kalzi:
Trying \_SB_.PCI0.GFX0.ATPX: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41: war
ning: command substitution: ignored null byte in input
failed
Trying \_SB.PCI0.P0P1.VGA._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
warning: command substitution: ignored null byte in input
failed
Trying \_SB.PCI0.P0P2.VGA._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB_.PCI0.OVGA.ATPX: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41: war
failed
Trying \_SB_.PCI0.OVGA.XTPX: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41: war
failed
Trying \_SB.PCI0.P0P3.PEGP._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.P0P2.PEGP._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.P0P1.PEGP._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.MXR0.MXM0._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.PEG1.GFX0._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.PEG0.GFX0.DOFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.PEG1.GFX0.DOFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.PEG0.PEGP._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.XVR0.Z01I.DGOF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.PEGR.GFX0._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.PEG.VID._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41: w
failed
Trying \_SB.PCI0.PEG0.VID._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.P0P2.DGPU._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.P0P4.DGPU.DOFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.IXVE.IGPU.DGOF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.RP00.VGA._PS3: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.RP00.VGA.P3MO: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.GFX0.DSM._T_0: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.LPC.EC.PUBS._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 4
1: warning: command substitution: ignored null byte in input
failed
Trying \_SB.PCI0.P0P2.NVID._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.P0P2.VGA.PX02: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB_.PCI0.PEGP.DGFX._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41
failed
Trying \_SB_.PCI0.VGA.PX02: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41: warn
failed
Trying \_SB.PCI0.PEG0.PEGP.SGOF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
Trying \_SB.PCI0.AGP.VGA.PX02: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41: w
failed
Trying \_SB.PCI0.RP05.PXSX._OFF: /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh: line 41:
failed
kalzEOS
January 21, 2022, 3:40am
#16
Also, went into the file itself with dolphin, clicked on it to excute it, but nothing happened. Opened that directory with a terminal and ran that single .sh file, but it keeps telling me sudo: turn_off_gpu.sh: command not found
From the long output above, it looks like there is something wrong with line 41 in that file result=$(cat /proc/acpi/call)
cscs
#17
We might try running it as root for real and making sure its bash;
su -
bash
cd /
./usr/share/linux515-acpi_call/examples/turn_off_gpu.sh
kalzEOS
January 21, 2022, 3:42am
#18
same long message. There is something wrong with line 41 of the acpi_calls
this one result=$(cat /proc/acpi/call)
cscs
January 21, 2022, 3:49am
#19
Hm. Yeah. I see some other reports.
Care to try replacing the script?
Maybe back up first;
sudo mv /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh.bak
sudo nano /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh
And put in the following:
Contents of /usr/share/linux515-acpi_call/examples/turn_off_gpu.sh
#!/bin/sh
if lsmod | grep -q acpi_call; then
methods="
\_SB_.PCI0.VGA.PX02
\_SB.PCI0.GPP0.PG00._OFF
for m in $methods; do
printf "Trying %s: " "$m"
echo "$m" > /proc/acpi/call
case "$result" in
Error*)
echo "failed"
echo "works!"
# break # try out outher methods too
esac
done
else
echo "The acpi_call module is not loaded, try running 'modprobe acpi_call' or 'insmod acpi_call.ko' as root"
exit 1
fi
And try again
kalzEOS
January 21, 2022, 4:00am
#20
Which command should I try after doing these two
of course, pasting the long script you provided
Sorry, I am kind of getting confused. lol
just give me the command you wanted me to try after your last comment
