this is definitely one of the more stupid questions, but I haven’t found a solution on the internet so far.
I just want to deinstall deja-dup completely, including all configuration, which it seems to keep after deinstalling and deleting the deja-dup folder in .cache.
I would have thought it was quite easy, but deja-dup is quite persistent it seems and it just back it’s original config from somewhere.
Pointing me to a documentation which helps is appreciated too, because all I have found didn’t help me find the answer to my question.
I’ve looked there before and, after your comment, again. Sadly, nothing to be found. I used the dconf-editor which solved the problem.
Thanks for your support!
