Is it possible to install applications on another disk?
So I am just wondering if it is possible to install some applications on another disk? If so, how? Just in case I would ever run out of space on the disk I installed Manjaro on.
Hello,
Just FYI, if you do a search for your question, and make sure to put linux in description, Google will pull up the answer for you. Here is some info, that may help you. https://askubuntu.com/questions/227713/install-apps-to-another-disk
Also please make sure to do the Following when asking questions. How to ask for info with inxi from users during support
Dump your inxi -Fxzc0 here and bookmark it
