Is it possible to flash an Android phone on Manjaro?
i was use ubuntu i don’t know where is it on gnome arch is different between
i use terminal to do update and upgrade
sudo pacman --noconfirm -Syy
sudo pacman --noconfirm -Syu
sudo pacman --noconfirm -Su
yay --noconfirm -Syu
i will subscribe it
i have another question also about flashing android phone
i want to use Jodin3 should i need to install Heimdall
how to install Samsung Android USB Driver on manjaro
thank you :heavy_heart_exclamation:
This the one and only correct command for syncing with the repo mirror.
If you know your system is up-to-date but you need a single applicaton you can use
sudo pacman -S <pkgname>
It is possible to flash android phones.
sudo pacman -S android-tools
For Samsung phones you may need heimdall
sudo pacman -S heimdall
Add your user to group adbusers (remember to logout to make the new group stick)
sudo gpasswd -a $USER adbusers
thank you for your information
i want to be on system upgrade always
is it enough to use
sudo pacman -Syu
i use odin before on windows
Is there any danger to my phone if I misuse because I was the first time I used it, and I’m afraid I’m going to make a mistake?
yes
When working with devices there is always the risk of making a mistake.
Check and check - triplecheck if that makes you confident - in the end you are the system administrator - you are reponsible for your system - no one else.
thank you for your help bro
of course will check and I’ll let you know
You’ll also need android-udev besides android-tools.
