been running manjaro on a Asrock Z590, and a 11600k cpu for about a year , and I still get error messages every time I update that their are missing drivers , I confirmed this when I open manjaro setting manager and look at Hardware info , expand all and see missing drivers listed as " Unknown devise name"
Is their something I can install to correct this ? edit running kernal 5.17
Which drivers? Please post any relevant output.
Please see:
Where?
when I do a major update , I will watch the updates download , then when the system auto configures itself says missing module drivers .
The system seems to run ok , I just thought that their might be something I could do to correct the issue .
Anyway thanks for the reply , probally I just have to wait for a future kernal release .
still no solution, thinking it is time for New Motherboard …maybe dump intel for a new am5 platform
Do you mean this here?
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> Starting build: 5.15.79-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [systemd]
-> Running build hook: [btrfs]
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
-> Running build hook: [sd-vconsole]
-> Running build hook: [fsck]
-> Running build hook: [bootsplash-manjaro]
==> Creating zstd-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
Nothing to worry here. That are really old and very special firmware. You see that only because the fallback kernel includes every module, but the default one has only the needed modules.
