Is the old finger command in any Manjaro package?
Whether this is what you are looking for I cannot say - I only vaguely remember the name - not what it was used for.
$ pamac search -f /usr/bin/finger
/usr/bin/fingerterm is owned by fingerterm
$ pamac info fingerterm
Version : 1.4.16-1
Description : A terminal emulator with a custom virtual keyboard
URL : https://github.com/sailfishos/fingerterm
Licenses : GPL-2.0-only
Repository : extra
Installed Size : 285,5 kB
Groups : --
Depends On : qt5-feedback nemo-qml-plugin-notifications
Optional Dependencies : --
Required By : --
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Packager : Felix Yan <felixonmars@archlinux.org>
Build Date : man 13 apr 2026 18:26:43 CEST
Install Date : lør 13 jun 2026 07:04:08 CEST
Install Reason : Explicitly installed
Validated By : Signature
Backup files : --
Yeah, fingerterm is not what I’m looking for. Thanks, though.
Oh, just found it in an aur package. Sorry!
Which package?
Oh crap, sorry, forgot to mention! It was netkit-bsd-finger. Thanks!
If you’re ever looking for a specific binary or file you can try for example: pacman -F finger which will give you:
extra/chawan 0.4.1-1
usr/lib/chawan/cgi-bin/finger
The program was moved out of the distribution for a reason. Unless you really need to query remote hosts, there is pinky to query local users on your machine.
Thanks, that’s good to know, but this is for a remote host.
