Is Cinnamon DE actively supported and updated?
Hello team
I’ve used Manjaro for a few years, and am planning to switch to the Cinnamon DE. Since this is an available download, I am I right to assume that it is actively supported and “developed”. I need to be careful how I use that term (develop) since I don’t have a clue how Cinnamon is supported in the Manjaro world. I just want to verify it’s not an implementation with limited support.
If I transition to that DE, will Cinnamon DE updates be passed through, along with other system updates?
Thanks
Reid
The Cinnamon Edition is one of our Community Editions, i.e. it is being compiled by one developer in his spare time, as opposed to by the entire Manjaro Team.
However, that said, I believe that a new Cinnamon ISO was only recently released. Installing from that and then making sure that you update your system right away should put you on par with every other Edition. :wink:
Indeed, they will, provided that upstream — in our case, Arch — has itself issued updates to the Cinnamon packages. :wink:
Thanks Aragorn -
The download page shows a June 2025 date. Are you referring to that?
RV
No, there is definitely a more recent one — I remember someone asking about it only a few weeks ago — but the website hasn’t been updated yet to reflect this.
I’m not a Cinnamon user myself, but let me see whether I can dig up the link… :face_with_diagonal_mouth:
Awesome
Ah, here it is… :backhand_index_pointing_down:
:wink:
great.. thx
I am probably missing something obvious here, but I was thinking I would find a garden-variety .iso, no such luck. The closest I could find were the manjaro-cinnamon-26.1.2-minimal-261017-linux618.iso.z01 & .z02 files, which I merged and decompressed, but I wasn’t able to boot. I created a bootable USB from the iso, which normally is simple, but got this error on boot:
“Booting from failed: verify it contains a 64-bit UEFI OS”
Also, I couldn’t use that ISO to build a virtual machine in VMM.
Likely I missed a step in the process.
Thx
Reid
You are not supposed to merge the .zip, .z01& z02 files before extracting. You need to download all 3 files, including the .zip.
Then, extract the .zip file using 7zip and the numbered files (.z01 & .z02) will be included.
For more info, see this post I recently made in another thread:
Ha !! no idea I needed the .zip file. Got the rest. What’s in the .zip ?
working fine now :->
Parts of the ISO. :wink:
OK… perfect… all good and thanks
