I’m again getting some errors that .zshsomething (it crashed before i could read the whole name) folder isn’t lockable and read only, and that another folder can’t be written into which then leads to crashing.
Should i back up my data and use something else?
I only went with BTRFS because of system restore as that’s supposed to be faster to make a restore point, but it seems i’m getting folder ownership and other errors which never happened on ext4. The nvme drive is new, so i doubt it has corruption on it.
Or is this something else related?
By now i have accumulated some data i don’t wish to lose, so it would be nice to know the problem root before i commit more data to this drive…
Kernel: 6.1.4-x64v1-xanmod1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-manjaro-xanmod
root=UUID=27a6f9c0-8b45-42c5-85e1-be095307048f rw rootflags=subvol=@
amdgpu.gpu_recovery=1 audit=0
resume=UUID=b58bc35c-1a93-4c4c-a1ec-5eefe535dea6 udev.log_priority=3
amd_iommu=on vfio-pci.ids=1002:6658,1002:aac0
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: B550M Pro4 serial: <superuser required>
UEFI: American Megatrends LLC. v: P2.30 date: 02/24/2022
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3691 high: 3900 min/max: 1400/4464 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2988 2: 3900
3: 3900 4: 3900 5: 3900 6: 3213 7: 3900 8: 3900 9: 3900 10: 3900 11: 3900
12: 3002 bogomips: 93422
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Bonaire XTX [Radeon R7 260X/360] vendor: PC Partner / Sapphire
driver: vfio-pci v: N/A alternate: radeon,amdgpu arch: GCN-2
code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17 pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 1002:6658 class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm)
built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: DP-1,HDMI-A-1 empty: DP-2 bus-ID: 06:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 35.0 C
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: AOC Q3279WG5B serial: <filter> built: 2020 res: 2560x1440 dpi: 90
gamma: 1.2 size: 725x428mm (28.54x16.85") diag: 842mm (33.1") ratio: 15:9
modes: max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: AOC Q3279WG5B
serial: <filter> built: 2020 res: 2560x1440 dpi: 90 gamma: 1.2
size: 725x428mm (28.54x16.85") diag: 842mm (33.1") ratio: 15:9 modes:
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.4-x64v1-xanmod1-MANJARO) direct render: Yes
Device-1: AMD Tobago HDMI Audio [Radeon R7 360 / R9 OEM]
vendor: PC Partner / Sapphire driver: vfio-pci bus-ID: 3-2.2:4
alternate: snd_hda_intel chip-ID: 1235:8200 pcie: class-ID: 0103
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.1
chip-ID: 1002:aac0 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Focusrite-Novation Scarlett 2i4 USB type: USB
driver: snd-usb-audio
Sound API: ALSA v: k6.1.4-x64v1-xanmod1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: JACK v: 1.9.21 running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-2.1:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 698.65 GiB used: 305.19 GiB (43.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: SBI02102 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-1: / raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
used: 305.19 GiB (68.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
ID-4: /var/log raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
Kernel: swappiness: 30 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 16.5 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 34.5 C mobo: 33.0 C gpu: amdgpu temp: 35.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1109 fan-3: 0 fan-4: 0 fan-5: 0 fan-6: 0
fan-7: 0
Processes: 341 Uptime: 5m wakeups: 0 Memory: 30.74 GiB
used: 4.32 GiB (14.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1835 libs: 499 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.24
