I have received a laptop from my wife as a gift, Acer Swift.
The battery is supposed to be very good.
Upon installation of Manjaro it seemed that way.
However, day by day I am noticing the battery life is already shortening in alarming ways.
First it lasted around 9h, then 5, now it says the battery will last for 3 hours.
irq/184-AudioDS
is always around 10% of processor usage.
It is beyond me how to tackle the issue
Please help good people
edit// to be expected wink
I was going to provide the “…” but my two children can disrupt the whole day let alone my thread posting here goes:
Kernel: 5.10.131-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Acer product: Swift SF314-511 v: V1.10
serial: <filter>
Mobo: TGL model: Sake_TL v: V1.10 serial: <filter> UEFI: Insyde v: 1.10
date: 09/16/2021
ID-1: BAT1 charge: 32.6 Wh (55.9%) condition: 58.3/56.0 Wh (104.2%)
volts: 15.1 min: 15.4 model: SMP AP18C7M type: Li-ion serial: <filter>
status: discharging cycles: 4
RAM: total: 15.43 GiB used: 2.04 GiB (13.2%)
Array-1: capacity: 16 GiB slots: 8 EC: None max-module-size: 2 GiB
note: est.
Device-1: Controller0-ChannelA type: LPDDR4 detail: synchronous
size: 2 GiB speed: 4267 MT/s volts: 0.6 width (bits): data: 16 total: 16
manufacturer: Micron Technology part-no: 53E1G32D2NP-046 serial: N/A
Device-2: Controller0-ChannelB type: LPDDR4 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR4 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR4 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR4 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR4 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR4 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR4 detail: synchronous
Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
smt: enabled arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB L3: 8 MiB
Speed (MHz): avg: 2167 high: 4159 min/max: 400/4200 volts: 0.7 V
ext-clock: 100 MHz cores: 1: 534 2: 400 3: 3883 4: 1350 5: 1948 6: 3274
7: 4159 8: 1789 bogomips: 38720
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen12.1 ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 3-5:2
chip-ID: 04f2:b6dd class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0xda91 res: 1920x1080 hz: 60
dpi: 158 size: 309x174mm (12.17x6.85") diag: 355mm (14") modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.3
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio
vendor: Acer Incorporated ALI driver: sof-audio-pci bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.131-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.55 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 491.26 GiB used: 41.95 GiB (8.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVL2512HCJQ-00BT7
size: 476.94 GiB speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: GXA7302Q temp: 38.9 C scheme: GPT
ID-2: /dev/sda type: USB vendor: SanDisk model: Ultra USB 3.0
size: 14.32 GiB type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-1: / size: 215.65 GiB used: 17.41 GiB (8.1%) fs: ext4
dev: /dev/nvme0n1p6 label: N/A uuid: d540af20-98bf-4853-84e1-5bce691c998d
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p5 label: NO_LABEL uuid: 375E-CC05
ID-3: /run/media/rafal/Acer size: 255.37 GiB used: 24.54 GiB (9.6%)
fs: ntfs dev: /dev/nvme0n1p3 label: Acer uuid: EE4AA6FE4AA6C327
ID-4: /run/media/rafal/ESD-USB size: 14.3 GiB used: 320 KiB (0.0%)
fs: vfat dev: /dev/sda1 label: ESD-USB uuid: 9A37-2FC0
ID-1: /dev/nvme0n1p1 size: 100 MiB fs: vfat label: ESP uuid: 44A6-6A0A
ID-2: /dev/nvme0n1p2 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 size: 1024 MiB fs: ntfs label: Recovery
uuid: 782CA7A32CA75B40
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-5:2 info: Chicony HD User Facing type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6dd
Device-2: 3-7:3 info: LighTuning EgisTec EH575 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 1c7a:0575 class-ID: ff00 serial: <filter>
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: Bluetooth
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-1:2 info: SanDisk Ultra Flair type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0781:5591 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 244 Uptime: 6h 41m wakeups: 677 Init: systemd v: 251
default: graphical Compilers: gcc: 12.1.0 clang: 14.0.6 Packages:
pacman: 1260 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
