Since this update, whenever I start Iridium (browser based on Chromium), I’m asked to type my password to unlock keyring. I use XFCE as desktop environment, auto-login is off. What can I do to disable this keyring pop-up?
If you’re not concerned about losing any existing saved passwords, you can just delete the keyring. The next time you are prompted to use it you can create a new one with a password that matches your logon.
rm ~/.local/share/keyrings/login.keyring
I didn’t want to lose existing password, so I installed SeaHorse, right-clicked Default-keyring → Change Password, entered my old password (the same as my login password) and then entered that same password again for new password. It fixed it: no more prompt when opening Iridium after logging in.
