When I do wget, it hangs
i.e.
wget -v https://gems.hashicorp.com/specs.4.8.gz ✔
--2021-09-24 23:41:44-- https://gems.hashicorp.com/specs.4.8.gz
SSL_INIT
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving gems.hashicorp.com (gems.hashicorp.com)... 2600:9000:21d1:2400:11:a45a:acc0:93a1, 2600:9000:21d1:3800:11:a45a:acc0:93a1, 2600:9000:21d1:1800:11:a45a:acc0:93a1, ...
Connecting to gems.hashicorp.com (gems.hashicorp.com)|2600:9000:21d1:2400:11:a45a:acc0:93a1|:443... ^C
If i force ipv4, it seems to work
wget -v -4 https://gems.hashicorp.com/specs.4.8.gz INT ✘ 2m 45s
--2021-09-24 23:46:23-- https://gems.hashicorp.com/specs.4.8.gz
SSL_INIT
Resolving gems.hashicorp.com (gems.hashicorp.com)... 13.226.69.35, 13.226.69.102, 13.226.69.96, ...
Connecting to gems.hashicorp.com (gems.hashicorp.com)|13.226.69.35|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 424 [binary/octet-stream]
Saving to: ‘specs.4.8.gz’
specs.4.8.gz 100%[========================================================================================================================================>] 424 --.-KB/s in 0s
2021-09-24 23:46:24 (6.36 MB/s) - ‘specs.4.8.gz’ saved [424/424]
This seems to be causing issues with other applications (like my vagrant)
vagrant up ✔
Installing plugin vagrant-bindfs
Vagrant failed to initialize at a very early stage:
Vagrant failed to load a configured plugin source. This can be caused
by a variety of issues including: transient connectivity issues, proxy
filtering rejecting access to a configured plugin source, or a configured
plugin source not responding correctly. Please review the error message
below to help resolve the issue:
timed out (https://gems.hashicorp.com/specs.4.8.gz)
Source: https://gems.hashicorp.com/
How do i force all network connections to use ipv4 only?
Thanks
