IPsec VPN killed under heavy load
Hi!
I have a serious problem. When i start my favorite IDE (PhpStorm) my VPN will suddenly killed (connection timeout)
I have discussed this issue already with Jetbrains but i also have this problem sometimes when i use Microsoft Teams!
jetbrains suport forum
jetbrains bugtracker
It happen obviously when my system is under heavy load. I guess its a “kernel scheduler” issue or something similar, but i am not sure! I also played already with more CPU prio (nice value) for process like NetworkManager or xl2tpd, but don’t have luck.
Could someone help me please to find a way to fix that?
Okt 09 16:24:51 xps-9310 charon[68074]: 14[IKE] sending keep alive to 212.121.155.82[4500]
Okt 09 16:24:54 xps-9310 charon[68074]: 15[NET] received packet: from 212.121.155.82[4500] to 192.168.34.20[4500] (108 bytes)
Okt 09 16:24:54 xps-9310 charon[68074]: 15[ENC] parsed INFORMATIONAL_V1 request 1156804524 [ HASH N(DPD) ]
Okt 09 16:24:54 xps-9310 charon[68074]: 15[ENC] generating INFORMATIONAL_V1 request 1494625831 [ HASH N(DPD_ACK) ]
Okt 09 16:24:54 xps-9310 charon[68074]: 15[NET] sending packet: from 192.168.34.20[4500] to 212.121.155.82[4500] (108 bytes)
Okt 09 16:25:15 xps-9310 charon[68074]: 07[IKE] sending keep alive to 212.121.155.82[4500]
Okt 09 16:25:24 xps-9310 charon[68074]: 13[NET] received packet: from 212.121.155.82[4500] to 192.168.34.20[4500] (108 bytes)
Okt 09 16:25:24 xps-9310 charon[68074]: 13[ENC] parsed INFORMATIONAL_V1 request 2604566442 [ HASH N(DPD) ]
Okt 09 16:25:24 xps-9310 charon[68074]: 13[ENC] generating INFORMATIONAL_V1 request 84414971 [ HASH N(DPD_ACK) ]
Okt 09 16:25:24 xps-9310 charon[68074]: 13[NET] sending packet: from 192.168.34.20[4500] to 212.121.155.82[4500] (108 bytes)
Okt 09 16:25:45 xps-9310 charon[68074]: 14[IKE] sending keep alive to 212.121.155.82[4500]
Okt 09 16:25:54 xps-9310 charon[68074]: 15[NET] received packet: from 212.121.155.82[4500] to 192.168.34.20[4500] (108 bytes)
Okt 09 16:25:54 xps-9310 charon[68074]: 15[ENC] parsed INFORMATIONAL_V1 request 1123824463 [ HASH N(DPD) ]
Okt 09 16:25:54 xps-9310 charon[68074]: 15[ENC] generating INFORMATIONAL_V1 request 1493072706 [ HASH N(DPD_ACK) ]
Okt 09 16:25:54 xps-9310 charon[68074]: 15[NET] sending packet: from 192.168.34.20[4500] to 212.121.155.82[4500] (108 bytes)
Okt 09 16:26:01 xps-9310 jetbrains-phpstorm-9bfdaebd-e6f8-47f6-8eaf-642afdb93be6.desktop[66945]: Starting cer server. Pre-initialize spent 0 ms.
Okt 09 16:26:09 xps-9310 systemd[1]: Bluetooth service skipped, unmet condition check ConditionPathIsDirectory=/sys/class/bluetooth
Okt 09 16:26:09 xps-9310 gnome-keyring-daemon[2876]: asked to register item /org/freedesktop/secrets/collection/login/5, but it's already registered
Okt 09 16:26:09 xps-9310 systemd[2860]: Started app-org.chromium.Chromium-69543.scope.
Okt 09 16:26:38 xps-9310 terminator.desktop[68230]: Terminal::match_remove: Unable to remove non-existent match launchpad_bug
Okt 09 16:26:38 xps-9310 terminator.desktop[68230]: Terminal::match_remove: Unable to remove non-existent match launchpad_code
Okt 09 16:26:38 xps-9310 terminator.desktop[68230]: Terminal::match_remove: Unable to remove non-existent match apturl
Okt 09 16:26:38 xps-9310 systemd[2860]: Started VTE child process 70124 launched by terminator process 68230.
Okt 09 16:26:55 xps-9310 NetworkManager[68124]: xl2tpd[68124]: Maximum retries exceeded for tunnel 14617.  Closing.
Okt 09 16:26:55 xps-9310 NetworkManager[68124]: xl2tpd[68124]: Terminating pppd: sending TERM signal to pid 68125
Okt 09 16:26:55 xps-9310 NetworkManager[68124]: xl2tpd[68124]: Connection 36650 closed to 212.121.155.82, port 1701 (Timeout)
Okt 09 16:26:55 xps-9310 pppd[68125]: Terminating on signal 15
Okt 09 16:26:55 xps-9310 pppd[68125]: Connect time 2.5 minutes.
Okt 09 16:26:55 xps-9310 pppd[68125]: Sent 27174 bytes, received 226266 bytes.
Okt 09 16:26:55 xps-9310 charon[68074]: 14[KNL] interface ppp0 deactivated
Okt 09 16:26:55 xps-9310 charon[68074]: 12[KNL] 172.16.55.60 disappeared from ppp0
Okt 09 16:26:55 xps-9310 pppd[68125]: Overriding mtu 1500 to 1400
Okt 09 16:26:55 xps-9310 pppd[68125]: Overriding mru 1500 to mtu value 1400
Okt 09 16:26:55 xps-9310 NetworkManager[648]: <info>  [1791556015.3248] device (ppp0): state change: disconnected -> unmanaged (reason 'unmanaged-external-down', managed-type: 'external')
Okt 09 16:26:55 xps-9310 charon[68074]: 07[NET] using forecast interface enp0s13f0u1u4
Okt 09 16:26:55 xps-9310 charon[68074]: 10[IKE] uninstalling bypass policy for 192.168.10.2/32
Okt 09 16:26:55 xps-9310 charon[68074]: 07[CFG] joining forecast multicast groups: 224.0.0.1,224.0.0.22,224.0.0.251,224.0.0.252,239.255.255.250
Okt 09 16:27:01 xps-9310 pppd[68125]: Connection terminated.
Okt 09 16:27:01 xps-9310 charon[68074]: 14[KNL] interface ppp0 deleted
Okt 09 16:27:01 xps-9310 NetworkManager[68124]: xl2tpd[68124]: death_handler: Fatal signal 15 received
Okt 09 16:27:01 xps-9310 NetworkManager[648]: <warn>  [1791556021.3358] platform-linux: do-add-ip4-address[13: 172.16.55.60/32,192.168.10.2]: failure 19 (Kein passendes Gerät gefunden - ipv4: Device not found)
Okt 09 16:27:01 xps-9310 NetworkManager[648]: <warn>  [1791556021.3359] l3cfg[988151b7376d9b82,ifindex=13]: unable to configure IPv4 route: type unicast 10.22.0.0/16 via 192.168.10.2 dev 13 metric 50 mss 0 rt-src user
Okt 09 16:27:01 xps-9310 NetworkManager[648]: <warn>  [1791556021.3360] l3cfg[988151b7376d9b82,ifindex=13]: unable to configure IPv4 route: type unicast 212.222.128.0/24 via 192.168.10.2 dev 13 metric 50 mss 0 rt-src user
Okt 09 16:27:01 xps-9310 NetworkManager[648]: <warn>  [1791556021.3360] l3cfg[988151b7376d9b82,ifindex=13]: unable to configure IPv4 route: type unicast 10.24.0.0/16 via 192.168.10.2 dev 13 metric 50 mss 0 rt-src user
Okt 09 16:27:01 xps-9310 NetworkManager[70198]: Stopping strongSwan IPsec...
Okt 09 16:27:01 xps-9310 charon[68074]: 00[DMN] SIGINT received, shutting down
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] closing CHILD_SA e3e9f8e8-1eba-4c5c-9aba-6844099ad144{1} with SPIs c91d380e_i (232431 bytes) 460b083d_o (31675 bytes) and TS 192.168.34.20/32[udp/l2f] === 212.121.155.82/32[udp/l2f]
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] sending DELETE for ESP CHILD_SA with SPI c91d380e
Okt 09 16:27:01 xps-9310 charon[68074]: 00[ENC] generating INFORMATIONAL_V1 request 3784358028 [ HASH D ]
Okt 09 16:27:01 xps-9310 charon[68074]: 00[NET] sending packet: from 192.168.34.20[4500] to 212.121.155.82[4500] (92 bytes)
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] deleting IKE_SA e3e9f8e8-1eba-4c5c-9aba-6844099ad144[1] between 192.168.34.20[192.168.34.20]...212.121.155.82[212.121.155.82]
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] sending DELETE for IKE_SA e3e9f8e8-1eba-4c5c-9aba-6844099ad144[1]
Okt 09 16:27:01 xps-9310 charon[68074]: 00[ENC] generating INFORMATIONAL_V1 request 3464344390 [ HASH D ]
Okt 09 16:27:01 xps-9310 charon[68074]: 00[NET] sending packet: from 192.168.34.20[4500] to 212.121.155.82[4500] (108 bytes)
Okt 09 16:27:01 xps-9310 pppd[68125]: Modem hangup
Okt 09 16:27:01 xps-9310 pppd[68125]: Exit.
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] uninstalling bypass policy for 10.5.0.0/24
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] uninstalling bypass policy for 172.17.0.0/16
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] uninstalling bypass policy for 192.168.34.0/24
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] uninstalling bypass policy for 192.168.122.0/24
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] uninstalling bypass policy for 2a02:8109:fe1a:cc00::/64
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] uninstalling bypass policy for fd7b:b718:8414::/64
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] uninstalling bypass policy for fe80::/64
Okt 09 16:27:01 xps-9310 charon[68074]: 00[IKE] uninstalling bypass policy for 192.168.34.1/32
Okt 09 16:27:01 xps-9310 ipsec_starter[68073]: child 68074 (charon) has quit (exit code 0)
Okt 09 16:27:01 xps-9310 ipsec_starter[68073]: charon stopped after 200 ms
Okt 09 16:27:01 xps-9310 ipsec_starter[68073]: ipsec starter stopped
Okt 09 16:27:01 xps-9310 nm-l2tp-service[68027]: ipsec shut down
While I’m sure the log output you’ve provided will be helpful, detailed Information about your system will also be useful in ascertaining the cause of the issue.
Please provide the output of:
inxi --filter --verbosity=8
inxi -zv8
Running `inxi` in `chroot`
Providing `inxi` when you cannot access your desktop environment
no problem, have a look:
  Kernel: 7.2.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.2-x86_64
    root=UUID=9911c2cd-3714-4bc5-92cf-cd7d98e17a58 rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
    intel_iommu=on
  Desktop: GNOME v: 50.4 tk: GTK v: 3.24.52 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 50.3 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Dell product: XPS 13 9310 v: N/A
  Mobo: Dell model: 0MRT12 v: A00 serial: <superuser required> part-nu: 0991
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 3.37.0
    date: 05/25/2026
  ID-1: BAT0 charge: 37.2 Wh (93.8%) condition: 39.7/51 Wh (77.9%)
    health: good temp: 27.5 C volts: 7.72 min: 7.6 model: SMP DELL WN0N012
    made: 2021-02-26 type: Li-poly serial: <filter> charging:
    status: not charging control: start: 50% end: 90% type: custom
    avail: adaptive,custom,fast,standard,trickle cycles: N/A
  System RAM: total: 32 GiB available: 31.06 GiB used: 8.9 GiB (28.7%)
  Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
    speed: 4267 MT/s volts: curr: 0.6 width (bits): data: 16 total: 16
    manufacturer: N/A part-no: N/A serial: N/A
  Device-2: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
  Device-3: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
  Device-4: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
  Device-5: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
  Device-6: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
  Device-7: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
  Device-8: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
  Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xBE
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1147 min/max: 400/3000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1147 2: 1147 3: 1147 4: 1147 5: 1147 6: 1147
    7: 1147 8: 1147 bogomips: 47923
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
    rep_good sdbg sep sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
    sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc tsc_adjust
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: DP-5,DP-6 off: eDP-1 empty: DP-1, DP-2,
    DP-3, DP-4, DP-7, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
    class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: DP-5 model: Lenovo G27qe-20 serial: <filter> built: 2022
    res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.671 y: 0.325 green:
    x: 0.294 y: 0.627 blue: x: 0.141 y: 0.051 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
  Monitor-2: DP-6 model: Lenovo G27qe-20 serial: <filter> built: 2022
    640x480, 720x400
  Monitor-3: eDP-1 model: Sharp 0x14fa built: 2020 res: 3840x2400 dpi: 339
    gamma: 1.2 chroma: red: x: 0.663 y: 0.322 green: x: 0.286 y: 0.631 blue:
    x: 0.149 y: 0.051 white: x: 0.314 y: 0.329 size: 288x180mm (11.34x7.09")
    diag: 340mm (13.4") ratio: 16:10 modes: 3840x2400
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 vendor: intel mesa v: 26.2.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL GT2)
    device-ID: 8086:9a49 memory: 30.33 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: Intel 500 Series Family On-Package High Definition Audio
    vendor: Dell driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
    snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a0c8
    class-ID: 0401
  API: ALSA v: k7.2.3-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm QCA6390 Wireless Network Adapter vendor: Rivet Networks
    driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
    gen: 3 speed: 8 GT/s bus-ID: 72:00.0 chip-ID: 17cb:1101 class-ID: 0280
  IF: wlp114s0 state: up mac: <filter>
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.4:4
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s13f0u3u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-d1d778d50376 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-2: docker0 state: down mac: <filter>
  IF-ID-3: veth15ea097 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-4: veth3b0597b state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-5: veth62f5948 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-6: veth75afc59 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-7: veth7a5d0b7 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-8: virbr0 state: down mac: <filter>
  Info: services: apache2, NetworkManager, sshd, systemd-timesyncd,
    wpa_supplicant
  Local Storage: total: 953.87 GiB used: 292.61 GiB (30.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: KXG60ZNV1T02 NVMe
    1024GB size: 953.87 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 10604107
    temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 250 GiB size: 250 GiB (100.00%) used: 194.75 GiB (77.9%)
    fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: 9911c2cd-3714-4bc5-92cf-cd7d98e17a58
  ID-2: /boot/efi raw-size: 500 MiB size: 496 MiB (99.20%)
    used: 111.1 MiB (22.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: ESP uuid: F8A5-9CAB
  ID-3: /mnt/daten raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
    used: 97.75 GiB (40.0%) fs: btrfs dev: /dev/nvme0n1p9 maj-min: 259:9
    label: Daten uuid: 0d3b4dd6-e1ba-4c32-ac2f-f2faf061e945
  ID-1: swap-1 type: partition size: 33.2 GiB used: 0 KiB (0.0%)
    priority: -1 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: cc542564-aeb1-4ce7-a998-20a224039cdc
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 244.14 GiB fs: ntfs label: N/A
    uuid: 0E4C91B64C919953
  ID-3: /dev/nvme0n1p6 maj-min: 259:6 size: 1.2 GiB fs: ntfs
    label: WINRETOOLS uuid: 76F671D3F6719459
  ID-4: /dev/nvme0n1p7 maj-min: 259:7 size: 10.68 GiB fs: ntfs label: Image
    uuid: D8B6AB9AB6AB77A0
  ID-5: /dev/nvme0n1p8 maj-min: 259:8 size: 1.41 GiB fs: ntfs
    label: DELLSUPPORT uuid: C460AD6060AD59C6
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 2-3:2 info: Realtek Dell dock ports: 4 rev: 3.1
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 0bda:0487
  Hub-4: 2-3.3:3 info: Realtek Dell dock ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0413
  Device-1: 2-3.4:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:533c class-ID: ff00
  Hub-6: 3-4:3 info: Realtek Dell dock ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5487
  Hub-7: 3-4.3:4 info: Realtek Dell dock ports: 6 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5413
  Device-1: 3-4.3.2:6 info: CHERRY Corded Device type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046a:c098 class-ID: 0300
  Device-2: 3-4.3.3:7 info: Logitech G303 Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c080 class-ID: 0300
    serial: <filter>
  Device-3: 3-4.3.5:8 info: Dell dock type: HID driver: hid-generic,usbhid
    power: 100mA chip-ID: 413c:b06f class-ID: 0300 serial: <filter>
  Device-4: 3-4.5:5 info: Dell Dock WD19S type: HID,billboard
    chip-ID: 413c:b06e class-ID: 1100 serial: <filter>
  Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 42.0 C mobo: 41.0 C sodimm: 36.0 C
  Fan Speeds (rpm): cpu: 0 fan-2: 0
  Packages: 2065 pm: pacman pkgs: 2044 libs: 545
    tools: gnome-software,pamac,yay pm: rpm pkgs: 0 pm: flatpak pkgs: 21
    1: https://mirror.23m.com/manjaro/stable/$repo/$arch
    2: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    3: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    4: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    5: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    6: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    7: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    8: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 405
  1: cpu: 29.2% command: phpstorm pid: 6584 mem: 3300.7 MiB (10.3%)
  2: cpu: 14.2% command: firefox pid: 9517 mem: 899.7 MiB (2.8%)
  3: cpu: 6.6% command: gnome-shell pid: 3166 mem: 307.9 MiB (0.9%)
  4: cpu: 4.4% command: jetbrains-toolbox pid: 3350 mem: 395.7 MiB (1.2%)
  5: cpu: 3.2% command: code pid: 12366 mem: 340.2 MiB (1.0%)
  Memory top: 5 of 405
  1: mem: 3300.7 MiB (10.3%) command: phpstorm pid: 6584 cpu: 29.2%
  2: mem: 899.7 MiB (2.8%) command: firefox pid: 9517 cpu: 14.2%
  3: mem: 427.8 MiB (1.3%) command: chromium pid: 6161 cpu: 2.0%
  4: mem: 398.4 MiB (1.2%) command: mysqld pid: 1417 cpu: 0.6%
  5: mem: 395.7 MiB (1.2%) command: jetbrains-toolbox pid: 3350 cpu: 4.4%
  Processes: 405 Power: uptime: 18m states: freeze,mem,disk suspend: s2idle
    image: 12.36 GiB services: gsd-power, power-profiles-daemon, upowerd
    Init: systemd v: 261 default: graphical tool: systemctl
  Compilers: clang: 22.1.8 gcc: 16.2.1 Shell: fish v: 4.9.1
    running-in: terminator inxi: 3.3.41
It is obviously a conflict between the IntelliJ’s Java network stack and your VPN. A simple Google search should give you some pointers.
aha!? do you have a link for me?
And do you think IntelliJ’s Java network stack is used by Microsoft Teams as well?
Which one is it?
Or…
Whether this is specific to the rare application or happens under heavy system load in general would would drastically change where I would look next.
There are many ways to generate load, and this doesn’t necessarily only mean saturating your CPU cores. But that would be a good place to start, as it’s easy to do.
How exactly is the VPN configured? Are you using NetworkManager’s L2TP plugin with an IPsec configuration, or a separate VPN client? Did you configure the connection yourself?
Well Java apps have been known to put a system under heavy load. That is one of the reasons I stopped trying to use Apps like InteiJ based IDEs.
I couldn’t agree more
NetworkManager. Do you see the discussion i’ve linked to IntelliJ IDEA forum and bugtracker?
well, i also dont like Java Applications. But even than the OS shouldn’t loose the control above all other apps (e.g. NetworkManager).
I have try now other distributions and even Windows.
I agree, but I was merely pointing out to @Molski that both could be true.
Running a Java app and the System being under heavy load. I wasn’t diagnosing your problem.
Never had such troubles with wireguard, for the vpn to fall because of intelliJ garbage
fine. good for you, but i can’t decide the VPN technologie
Just a thought, have you tried a different VPN, such as Proton, or Mullvad
As @tracyanne suggest try a different VPN provider. Use wireguard through ProtonVPN. Their whole infrastructure is based on it, and with the new updates they have totally phased out OpenVPN. You can start with their free tier
I’ve found a solution. I’ve replaced xl2tpd with kl2tpd which is more stable.
Let’s hope it’s more stable. Keep us in the loop
