pinxi is at an advanced stage now, the oldest issues and glitches are now being taken care of, a large internal refactor, many new small features and fixes.
Due to huge number of internal changes, any testers appreciated, and also of course, the new feature -L if you use LVM/LUKS etc would be great to see some output. Note there is a very large difference now between -RL and -RLa
Also, for complicated setups give -RLay1 a try, that creates a dmidecode style output, which is easier to scan as long as it’s only a main feature or two.
If you have pinxi already, then just do: pinxi -U
to install it:
cd /usr/local/bin ; sudo wget -O pinxi smxi.org/pinxi ; sudo chmod +x pinxi
The new option is -L, for --logical, it was going to be --lvm but then I realized there were other types of logical block devices.
To get -L able to function, I had to rewwrite RAID -R, which now also supports LVM RAID. -D Local Storage totals now take RAID into account, and will modify the reported totals and uses, with raw: … usable: used and also for LVM, an lvm-free: item with -x which shows how much unassigned LVM space there is.
Note that the test vm has a bunch of disks, many volume groups, logical volumes, lvm raid, mdraid… and of course, lvm on mdraid.
It does not have all the variants possible since there are too many, which is why feedback would be appreciated.
Note that I have on my todo list bcache support, but I am getting a bit burned on this, so figured, let’s see if the basic stuff is working for most people before it gets extended.
Let me know if there is anything you think is missing or should be added, LVM uses lvs to get the data, which a specially constructed option list, so it it can be added that way, I can extend stuff, but not a lot more.
This is in pinxi current, not in inxi, inxi and pinxi right now are about as far apart from eachother as they have been since pinxi perl was born, I’d say 10-15% of the internal logic has been refactored or optimized or enhanced or restructured.
# pinxi -LRDy
VG-1: vg0 type: lvm2 size: 49.99 GiB free: 23.99 GiB
LV-1: flac type: linear size: 15 GiB devices: 1: sdb 2: sdc
LV-2: mp3 type: linear size: 6 GiB devices: 1: sdb
LV-3: opus type: linear size: 5 GiB devices: 1: sdb
VG-2: vg1 type: lvm2 size: 24.41 GiB free: 14.64 GiB
LV-1: lvm_raid1 type: raid1 size: 4.88 GiB components: c-1: dm-10 c-2: dm-11
c-3: dm-13 c-4: dm-15
VG-3: vg2 type: lvm2 size: 24.98 GiB free: 4.98 GiB
LV-1: data1 type: linear size: 5 GiB devices: 1: md0
LV-2: data2 type: linear size: 5 GiB devices: 1: md0
LV-3: data3 type: linear size: 5 GiB devices: 1: md0
LV-4: data4 type: linear size: 5 GiB devices: 1: md0
VG-4: vg3 type: lvm2 size: 38.37 GiB free: 26.36 GiB
LV-1: lvm_raid5 type: raid5 size: 8 GiB components: c-1: dm-12 c-2: dm-5
c-3: dm-6 c-4: dm-7 c-5: dm-8 c-6: dm-9
VG-5: vg4 type: lvm2 size: 24.41 GiB free: 14.64 GiB
LV-1: thin_mirror0 type: raid1 size: 4.88 GiB components: c-1: dm-21
c-2: dm-22 c-3: dm-23 c-4: dm-24
Crypto-1: LUKS id: luks-a00baac5-44ff-4b48-b303-3bedb1f623ce size: 4.26 GiB
devices: 1: sda2
Crypto-2: LUKS id: luks-3342c0fb-1868-4ee4-84bd-4f77278cdb61 size: 35.91 GiB
devices: 1: sda1
Device-1: lvm_raid1 type: lvm2 level: mirror size: 4.88 GiB sync: idle
Components: Online: 1: dm-11 2: dm-15 Meta: 1: dm-10 2: dm-13
Device-2: lvm_raid5 type: lvm2 level: raid-5 size: 8 GiB sync: idle
Components: Online: 1: dm-12 2: dm-6 3: dm-8 Meta: 1: dm-5 2: dm-7 3: dm-9
Device-3: thin_mirror0 type: lvm2 level: mirror size: 4.88 GiB sync: idle
Components: Online: 1: dm-22 2: dm-24 Meta: 1: dm-21 2: dm-23
Device-4: md0 type: mdraid level: mirror status: active size: 24.98 GiB
report: 2/2 UU
Components: Online: 0: sdf 1: sdg Spare: 2: sdi
Local Storage: total: raw: 340.19 GiB usable: 276.38 GiB
used: 8.49 GiB (3.1%)
ID-1: /dev/sda vendor: VirtualBox model: VBOX HARDDISK size: 40.19 GiB
ID-2: /dev/sdb vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
ID-3: /dev/sdc vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
ID-4: /dev/sdd vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
ID-5: /dev/sde vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
ID-6: /dev/sdf vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
ID-7: /dev/sdg vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
ID-8: /dev/sdh vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
ID-9: /dev/sdi vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
ID-10: /dev/sdj vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
ID-11: /dev/sdk vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
ID-12: /dev/sdl vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
ID-13: /dev/sdm vendor: VirtualBox model: VBOX HARDDISK size: 25 GiB
## And the full, --admin level RAID and Logical report.
# pinxi -LRDay
LV-1: flac type: linear maj-min: 254:2 dm: dm-2 size: 15 GiB
devices: 1: sdb maj-min: 8:16 size: 25 GiB 2: sdc maj-min: 8:32 size: 25 GiB
LV-2: mp3 type: linear maj-min: 254:4 dm: dm-4 size: 6 GiB
LV-3: opus type: linear maj-min: 254:3 dm: dm-3 size: 5 GiB
LV-1: [lvm_raid1_rimage_0] type: linear maj-min: 254:11 dm: dm-11
devices: 1: sdd1 maj-min: 8:49 size: 12.21 GiB
LV-2: [lvm_raid1_rimage_1] type: linear maj-min: 254:15 dm: dm-15
devices: 1: sde1 maj-min: 8:65 size: 12.21 GiB
LV-3: [lvm_raid1_rmeta_0] type: linear maj-min: 254:10 dm: dm-10 size: 4 MiB
LV-4: [lvm_raid1_rmeta_1] type: linear maj-min: 254:13 dm: dm-13 size: 4 MiB
LV-5: lvm_raid1 type: raid1 maj-min: 254:16 dm: dm-16 size: 4.88 GiB
components:
c-1: dm-10 maj-min: 254:10 size: 4 MiB dev: d-1: sdd1 maj-min: 8:49
c-2: dm-11 maj-min: 254:11 size: 4.88 GiB dev: d-1: sdd1 maj-min: 8:49
c-3: dm-13 maj-min: 254:13 size: 4 MiB dev: d-1: sde1 maj-min: 8:65
c-4: dm-15 maj-min: 254:15 size: 4.88 GiB dev: d-1: sde1 maj-min: 8:65
LV-1: data1 type: linear maj-min: 254:17 dm: dm-17 size: 5 GiB
devices: 1: md0 maj-min: 9:0 size: 24.98 GiB
LV-2: data2 type: linear maj-min: 254:18 dm: dm-18 size: 5 GiB
LV-3: data3 type: linear maj-min: 254:19 dm: dm-19 size: 5 GiB
LV-4: data4 type: linear maj-min: 254:20 dm: dm-20 size: 5 GiB
LV-1: [lvm_raid5_rimage_0] type: linear maj-min: 254:6 dm: dm-6 size: 4 GiB
devices: 1: sdd2 maj-min: 8:50 size: 12.79 GiB
LV-2: [lvm_raid5_rimage_1] type: linear maj-min: 254:8 dm: dm-8 size: 4 GiB
devices: 1: sde2 maj-min: 8:66 size: 12.79 GiB
LV-3: [lvm_raid5_rimage_2] type: linear maj-min: 254:12 dm: dm-12
devices: 1: sdh2 maj-min: 8:114 size: 12.79 GiB
LV-4: [lvm_raid5_rmeta_0] type: linear maj-min: 254:5 dm: dm-5 size: 4 MiB
LV-5: [lvm_raid5_rmeta_1] type: linear maj-min: 254:7 dm: dm-7 size: 4 MiB
LV-6: [lvm_raid5_rmeta_2] type: linear maj-min: 254:9 dm: dm-9 size: 4 MiB
LV-7: lvm_raid5 type: raid5 maj-min: 254:14 dm: dm-14 size: 8 GiB
components:
c-1: dm-12 maj-min: 254:12 size: 4 GiB dev: d-1: sdh2 maj-min: 8:114
c-2: dm-5 maj-min: 254:5 size: 4 MiB dev: d-1: sdd2 maj-min: 8:50
c-3: dm-6 maj-min: 254:6 size: 4 GiB dev: d-1: sdd2 maj-min: 8:50
c-4: dm-7 maj-min: 254:7 size: 4 MiB dev: d-1: sde2 maj-min: 8:66
c-5: dm-8 maj-min: 254:8 size: 4 GiB dev: d-1: sde2 maj-min: 8:66
c-6: dm-9 maj-min: 254:9 size: 4 MiB dev: d-1: sdh2 maj-min: 8:114
LV-1: [thin_mirror0_rimage_0] type: linear maj-min: 254:22 dm: dm-22
devices: 1: sdh1 maj-min: 8:113 size: 12.21 GiB
LV-2: [thin_mirror0_rimage_1] type: linear maj-min: 254:24 dm: dm-24
devices: 1: sdj1 maj-min: 8:145 size: 12.21 GiB
LV-3: [thin_mirror0_rmeta_0] type: linear maj-min: 254:21 dm: dm-21
LV-4: [thin_mirror0_rmeta_1] type: linear maj-min: 254:23 dm: dm-23
LV-5: thin_mirror0 type: raid1 maj-min: 254:25 dm: dm-25 size: 4.88 GiB
components:
c-1: dm-21 maj-min: 254:21 size: 4 MiB dev: d-1: sdh1 maj-min: 8:113
c-2: dm-22 maj-min: 254:22 size: 4.88 GiB dev: d-1: sdh1 maj-min: 8:113
c-3: dm-23 maj-min: 254:23 size: 4 MiB dev: d-1: sdj1 maj-min: 8:145
c-4: dm-24 maj-min: 254:24 size: 4.88 GiB dev: d-1: sdj1 maj-min: 8:145
Crypto-1: LUKS id: luks-a00baac5-44ff-4b48-b303-3bedb1f623ce maj-min: 254:1
dm: dm-1 size: 4.26 GiB
devices: 1: sda2 maj-min: 8:2 size: 4.26 GiB
Crypto-2: LUKS id: luks-3342c0fb-1868-4ee4-84bd-4f77278cdb61 maj-min: 254:0
dm: dm-0 size: 35.91 GiB
devices: 1: sda1 maj-min: 8:1 size: 35.92 GiB
Device-1: lvm_raid1 maj-min: 254:16 type: lvm2 level: mirror size: 4.88 GiB
sync: idle
Info: stripes: 2 mismatches: 0 copied: 100% v-group: vg1 vg-size: 24.41 GiB
vg-free: 14.64 GiB
Components: Online:
1: dm-11 maj-min: 254:11 size: 4.88 GiB mapped: vg1-lvm_raid1_rimage_0
dev: sdd1
2: dm-15 maj-min: 254:15 size: 4.88 GiB mapped: vg1-lvm_raid1_rimage_1
dev: sde1
Meta:
1: dm-10 maj-min: 254:10 size: 4 MiB mapped: vg1-lvm_raid1_rmeta_0 dev: sdd1
2: dm-13 maj-min: 254:13 size: 4 MiB mapped: vg1-lvm_raid1_rmeta_1 dev: sde1
Device-2: lvm_raid5 maj-min: 254:14 type: lvm2 level: raid-5 size: 8 GiB
sync: idle
Info: stripes: 3 mismatches: 0 copied: 100% v-group: vg3 vg-size: 38.37 GiB
vg-free: 26.36 GiB
Components: Online:
1: dm-12 maj-min: 254:12 size: 4 GiB mapped: vg3-lvm_raid5_rimage_2
dev: sdh2
2: dm-6 maj-min: 254:6 size: 4 GiB mapped: vg3-lvm_raid5_rimage_0 dev: sdd2
3: dm-8 maj-min: 254:8 size: 4 GiB mapped: vg3-lvm_raid5_rimage_1 dev: sde2
Meta:
1: dm-5 maj-min: 254:5 size: 4 MiB mapped: vg3-lvm_raid5_rmeta_0 dev: sdd2
2: dm-7 maj-min: 254:7 size: 4 MiB mapped: vg3-lvm_raid5_rmeta_1 dev: sde2
3: dm-9 maj-min: 254:9 size: 4 MiB mapped: vg3-lvm_raid5_rmeta_2 dev: sdh2
Device-3: thin_mirror0 maj-min: 254:25 type: lvm2 level: mirror
Info: stripes: 2 mismatches: 0 copied: 100% v-group: vg4 vg-size: 24.41 GiB
vg-free: 14.64 GiB
Components: Online:
1: dm-22 maj-min: 254:22 size: 4.88 GiB mapped: vg4-thin_mirror0_rimage_0
dev: sdh1
2: dm-24 maj-min: 254:24 size: 4.88 GiB mapped: vg4-thin_mirror0_rimage_1
dev: sdj1
Meta:
1: dm-21 maj-min: 254:21 size: 4 MiB mapped: vg4-thin_mirror0_rmeta_0
dev: sdh1
2: dm-23 maj-min: 254:23 size: 4 MiB mapped: vg4-thin_mirror0_rmeta_1
dev: sdj1
System supports mdraid: raid1 raid6 raid5 raid4
Device-4: md0 maj-min: 9:0 type: mdraid level: mirror status: active
state: clean size: 24.98 GiB
Info: report: 2/2 UU blocks: 26196992 chunk size: N/A super blocks: 1.2
Components: Online:
0: sdf maj-min: 8:80 size: 25 GiB state: active sync
1: sdg maj-min: 8:96 size: 25 GiB state: active sync
Spare:
2: sdi maj-min: 8:128 size: 25 GiB state: spare
Local Storage: total: raw: 340.19 GiB usable: 276.38 GiB lvm-free: 84.61 GiB
ID-1: /dev/sda maj-min: 8:0 vendor: VirtualBox model: VBOX HARDDISK
size: 40.19 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: VBd3607451-41a541bd rev: 1.0
SMART: no
ID-2: /dev/sdb maj-min: 8:16 vendor: VirtualBox model: VBOX HARDDISK
size: 25 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: VBb5407051-c69764d7 rev: 1.0
SMART: no
ID-3: /dev/sdc maj-min: 8:32 vendor: VirtualBox model: VBOX HARDDISK
serial: VBc4b6b2f6-4eb40f0f rev: 1.0
SMART: no
ID-4: /dev/sdd maj-min: 8:48 vendor: VirtualBox model: VBOX HARDDISK
serial: VB8d5f7ac2-dfdff49c rev: 1.0
SMART: no
ID-5: /dev/sde maj-min: 8:64 vendor: VirtualBox model: VBOX HARDDISK
serial: VBde128404-98e24d6f rev: 1.0
SMART: no
ID-6: /dev/sdf maj-min: 8:80 vendor: VirtualBox model: VBOX HARDDISK
serial: VBbeae7bc0-99a26ed8 rev: 1.0
SMART: no
ID-7: /dev/sdg maj-min: 8:96 vendor: VirtualBox model: VBOX HARDDISK
serial: VBbd6c1deb-58016f41 rev: 1.0
SMART: no
ID-8: /dev/sdh maj-min: 8:112 vendor: VirtualBox model: VBOX HARDDISK
serial: VBb4535226-dd865fc8 rev: 1.0
SMART: no
ID-9: /dev/sdi maj-min: 8:128 vendor: VirtualBox model: VBOX HARDDISK
serial: VBf19cf218-38c5f705 rev: 1.0
SMART: no
ID-10: /dev/sdj maj-min: 8:144 vendor: VirtualBox model: VBOX HARDDISK
serial: VB6ba6751b-ab1b1795 rev: 1.0
SMART: no
ID-11: /dev/sdk maj-min: 8:160 vendor: VirtualBox model: VBOX HARDDISK
serial: VB864d77ae-b60876e6 rev: 1.0
SMART: no
ID-12: /dev/sdl maj-min: 8:176 vendor: VirtualBox model: VBOX HARDDISK
serial: VBbdcf5f67-52d5d0eb rev: 1.0
SMART: no
ID-13: /dev/sdm maj-min: 8:192 vendor: VirtualBox model: VBOX HARDDISK
serial: VBef5e7de6-368cd338 rev: 1.0
SMART: no
