Inxi / pinxi ARM (or MIPS) testers appreciated
#41
pinxi -zv8 on Odroid C2, let me know if you need any further info!
System:    Host: odroidc2 Kernel: 3.14.79-odroidc2 aarch64 bits: 64 compiler: gcc v: 5.5.0 Console: N/A dm: N/A
           Distro: Armbian GNU/Linux 9 (stretch)
Machine:   Type: ARM Device System: ODROID-C2 rev: 020c
Battery:   ID-1: battery charge: N/A condition: N/A volts: 0.0/N/A model: N/A type: Li-ion serial: N/A
           status: Charging
Memory:    RAM: total: 1.68 GiB used: 606.0 MiB (35.3%)
           RAM Report: missing: Required program dmidecode not available
PCI Slots: ARM: No ARM data found for this feature.
CPU:       Topology: Quad Core model: N/A variant: cortex-a53 bits: 64 type: MCP arch: ARMv8 family: 8
           model-id: N/A stepping: 4 microcode: N/A bogomips: 0
           Speed: 1536 MHz min/max: 100/1536 MHz Core speeds (MHz): 1: 1536 2: 1536 3: 1536 4: 1536
           Features: asimd crc32 fp
           Vulnerabilities: No CPU vulnerability/bugs data available.
Graphics:  Device-1: amhdmitx driver: amhdmitx v: N/A bus ID: N/A chip ID: amlogic:amhdmitx
           Device-2: mali-450 driver: mali_utgard v: N/A bus ID: N/A chip ID: arm:d00c0000
           Device-3: odroid_hdmi driver: odroid_hdmi_snd v: N/A bus ID: N/A chip ID: sound_card:odroid_hdmi
           Display: server: No display server data found. Headless machine? tty: 179x49
Audio:     Device-1: amhdmitx driver: amhdmitx bus ID: N/A chip ID: amlogic:amhdmitx
           Device-2: odroid_hdmi driver: odroid_hdmi_snd bus ID: N/A chip ID: sound_card:odroid_hdmi
           Sound Server: ALSA v: k3.14.79-odroidc2
Network:   Device-1: gxbb-rgmii-dwmac driver: stmmaceth v: N/A port: N/A bus ID: N/A chip ID: amlogic:c9410000
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
           IP v6: <filter> type: temporary dynamic scope: global
           IP v6: <filter> type: temporary deprecated dynamic scope: global
           IP v6: <filter> type: mngtmpaddr noprefixroute scope: global
           IP v6: <filter> scope: link
           IF-ID-1: bond0 state: down mac: <filter>
           IF-ID-2: bonding_masters state: N/A speed: N/A duplex: N/A mac: N/A
Drives:    Local Storage: total: 1.85 TiB used: 111.61 GiB (5.9%)
           ID-1: /dev/mmcblk0 model: BGND3R size: 29.12 GiB block size: physical: 512 B logical: 512 B
           serial: <filter> scheme: MBR
           ID-2: /dev/sda type: USB vendor: Toshiba model: DT01ACA200 size: 1.82 TiB block size:
           physical: 512 B logical: 512 B rotation: 7200 rpm serial: <filter> scheme: MBR
RAID:      Message: No RAID data was found.
Partition: ID-1: / raw size: 28.83 GiB size: 28.35 GiB (98.36%) used: 4.94 GiB (17.4%) fs: ext4
           dev: /dev/mmcblk0p1 label: N/A uuid: 8cb90750-ea48-43f0-ac15-ce5eeb5a9aae
           ID-2: /home raw size: 1.10 TiB size: 1.09 TiB (98.34%) used: 106.67 GiB (9.6%) fs: ext4
           dev: /dev/sda2 label: USERS uuid: e3a43399-1768-420d-8958-e8434e6fd417
Unmounted: ID-1: /dev/sda1 size: 732.42 GiB fs: ext4 label: BACKUP uuid: 3b235458-2116-4851-96e0-fbb9cd15d7b3
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Hub: 1-1:2 info: Genesys Logic 4-port hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 05e3:0610
           Device-1: 1-1.2:4 info: TrekStor & KG type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
           speed: 480 Mb/s chip ID: 1e68:007d serial: <filter>
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Sensors:   System Temperatures: cpu: 41.0 C mobo: N/A
Repos:     Active apt repos in: /etc/apt/sources.list
           1: deb http://httpredir.debian.org/debian stretch main contrib non-free
           2: deb http://httpredir.debian.org/debian stretch-updates main contrib non-free
           3: deb http://httpredir.debian.org/debian stretch-backports main contrib non-free
           4: deb http://security.debian.org/ stretch/updates main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/armbian.list
           1: deb http://apt.armbian.com stretch main stretch-utils stretch-desktop
Processes: CPU top: 5
           1: cpu: 0.5% command: zsh pid: 20369 mem: 3.90 MiB (0.2%)
           2: cpu: 0.4% command: mosh-server pid: 20228 mem: 3.07 MiB (0.1%)
           3: cpu: 0.4% command: -zsh pid: 20229 mem: 3.43 MiB (0.1%)
           4: cpu: 0.3% command: [kworker/0:2] pid: 18223 mem: 0.00 MiB (0.0%)
           5: cpu: 0.2% command: haveged pid: 468 mem: 1.14 MiB (0.0%)
           Memory top: 5
           1: mem: 164.0 MiB (9.5%) command: mysqld pid: 902 cpu: 0.2%
           2: mem: 43.5 MiB (2.5%) command: apache2 pid: 10955 cpu: 0.0%
           3: mem: 37.8 MiB (2.2%) command: apache2 pid: 11310 cpu: 0.0%
           4: mem: 35.3 MiB (2.0%) command: apache2 pid: 10960 cpu: 0.0%
           5: mem: 34.9 MiB (2.0%) command: apache2 pid: 13084 cpu: 0.1%
Info:      Processes: 124 Uptime: 19d 23h 44m Init: systemd v: 232 runlevel: 5 Compilers: gcc: 6.3.0 alt: 4.9/6
           Shell: zsh v: 5.3.1 pinxi: 3.0.24-52
#42
Oh! It got the networking device, great!! I didn’t expect that to work, unexpected bonus from the recent updates. If I remember right, /proc/cpuinfo for the C2 doesn’t have machine data, so that missing data is not going to be available.
If you want to fire off a pinxi --debug 22 that would be good, the more datasets I have for ARM the better, just in case there are small variants in those devices I was not aware of.
#43
inxi 3.0.25 now done, with all these MIPS/ARM fixes, thanks for taking the time to debug and test.
