Hello i get the following errror when I start my laptop.
Failed to start light display manager
I need to login as root and run manualy
systemctl start lightdm
I formatted my PC after this error, but after a new installation and some reboots, the same error appears again!
Kernel: 5.18.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=db2a6472-1d41-440b-9c13-0c091b32af63 rw quiet
cryptdevice=UUID=263c4205-b77c-4ac8-b19c-74fa957982a3:luks-263c4205-b77c-4ac8-b19c-74fa957982a3
root=/dev/mapper/luks-263c4205-b77c-4ac8-b19c-74fa957982a3 apparmor=1
Desktop: Cinnamon v: 5.4.2 tk: GTK v: 3.24.34 vt: 7 dm: LightDM v: 1.30.0
Type: Laptop System: LENOVO product: 21A4 v: ThinkBook 15 G3 ACL
serial: <filter> Chassis: type: 10 v: ThinkBook 15 G3 ACL serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: GQCN20WW(V1.06) date: 04/29/2021
ID-1: BAT1 charge: 44.3 Wh (100.0%) condition: 44.3/45.0 Wh (98.5%)
volts: 13.1 min: 11.5
model: 0x43 0x65 0x6C 0x78 0x70 0x 0x4C 0x31 0x39 0x43 0x33 0x50 0x4500
type: Li-ion serial: <filter> status: full cycles: 6
RAM: total: 35.07 GiB used: 2.41 GiB (6.9%)
Array-1: capacity: 64 GiB slots: 2 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 32 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CT32G4SFD832A.M16FB serial: <filter>
Device-2: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Micron Technology
part-no: 4ATF1G64HZ-3G2E1 serial: N/A
Info: model: AMD Ryzen 5 5500U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/4056 boost: enabled
base/boost: 2100/4050 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
bogomips: 50328
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel arch: GCN 5.1
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:164c
class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 13d3:56ff class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xe48d built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_sof_amd_renoir
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.18.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 05:00.0 chip-ID: 10ec:8852 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Device-1: luks-263c4205-b77c-4ac8-b19c-74fa957982a3 maj-min: 254:0
type: LUKS dm: dm-0 size: 931.21 GiB
Components:
p-1: nvme1n1p2 maj-min: 259:6 size: 931.22 GiB
Local Storage: total: 1.38 TiB used: 9.92 GiB (0.7%)
model: PC SN530 SDBPMPZ-512G-1101 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21160001 temp: 32.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 931.21 GiB size: 915.52 GiB (98.32%) used: 9.92 GiB (1.1%)
fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
mapped: luks-263c4205-b77c-4ac8-b19c-74fa957982a3 label: N/A
uuid: db2a6472-1d41-440b-9c13-0c091b32af63
used: 440 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:5 label: NO_LABEL uuid: 7CE9-32B2
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 340.2 GiB fs: ntfs label: N/A
uuid: A67841217840F21B
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 136.72 GiB fs: ntfs
label: Data-NTFS uuid: 96629873629859B7
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: IMC Networks Integrated Camera type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c4b class-ID: 0000
Device-2: 3-4:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 320 Uptime: 49m wakeups: 3 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: pacman: 1111 lib: 295 flatpak: 0 Shell: Bash (su) v: 5.1.16
running-in: gnome-terminal inxi: 3.3.19
Thanks
