Hi
Today i try to take a call troguh google hangouts but before join i can see that the image from the webcam was inverted.
How i canfix that?
The webcam info: USB2.0 0.3UVC WebCam USB2.0
Regards
Hi
How i canfix that?
Regards
Did you see the inversion of the image in Google Hangouts itself, or in an application that you used for checking the webcam image before connecting to Hangouts? If so, what application did you use?
Disclaimer: I have no experience with Google Hangouts, but I do have a little bit of experience with Zoom Meeting.
Not the best solution, but this could be helpful. (Instead of v4l2loopback-dkms
, you need to install v4l2loopback-dkms-git
from AUR.)
I see inverted the image in all application
I try with this solution but dont work. Another idea?
What do you expect to happen and what happens instead? I hope you understand that ādont workā is not an adequate description of a problem if you want to get help.
Its inverted because it sees you as another person facing you would seeā¦ Raise your right hand,but you see it on the Left? Thats exactly what someone else seeās when facing you.
