"Invalid URL" with manjaro-tools
manjaro-tools
#1
Hey,
I want to make a custom Manjaro build again. I already did it succesfull last year, so I know the basic concept.
But now that I tried again, I run into a different problem:
I can’t start the build process, because of a connection problem:
sudo buildiso -p xfce
error: failed retrieving file ‘core.db’ from mirror.netzspielplatz.de : SSL certificate problem: unable to get local issuer certificate
… and so on
My normal updating pacman etc. works without a problem. I tried setting a different mirror, but apparently the mirrorlist for manjaro-tools is different than for my normal manjaro system… now I found the list in:
/etc/manjaro-tools/manjaro-tools.conf
And I used a different mirror
build_mirror=ftp.tu-chemnitz.de/pub/linux/manjaro
Only to get the same error.
I am currently working my way through:
but it seems all related to the normal pacman update?
And this all works for me.
Any ideas?
Or should I mess more with my keyring etc.
Oh and in general. I just freshly installed this manjaro system with the latest official build, so I didn’t mess with anything so far.
#2
This is an issue with the server’s SSL certificate (try loading the URL in a browser). You (we) can’t fix this.
#3
I can do so without problems
#4
Yup, it’s fixed. And you only had to wait for an hour or so.
#5
PS: The above is a no-no. Don’t use sudo with buildiso, buildpkg, makepkg or any AUR helper.
#6
Ah yes, I only tried sudo as a standard error-solving approach.
(even though I know it is not allways the smart way …)
But I still get the same error
(and so far nothing of the other thread worked. I tried all the recommended methods)
#7
Ok, I tried everything I could think of.
Still the same:
normal update - works
accessing the server directly - works
buildiso -p xfce
fails with
error: url ‘ftp.tu-chemnitz.de/pub/linux/manjaro/stable/core/x86_64/core.db’ is invalid
error: failed to update core (invalid url for server)
#8
Server address
You need to supply the full internet address
build_mirror=ftp://ftp.tu-chemnitz.de/pub/linux/manjaro
or
build_mirror=http://ftp.tu-chemnitz.de/pub/linux/manjaro
or
build_mirror=https://mirror.netzspielplatz.de/manjaro/packages
manjaro-tools.conf
Do not modify the files in /etc/manjaro-tools but copy the folder to your home
cp -R /etc/manjaro-tools ~/.config
Modify the file ~/.config/manjaro-tools/manjaro-tools.conf
iso-profiles
If you want to modify an iso-profile copy the folder to your home folder
cp -R /usr/share/manjaro-tools/iso-profiles ~/manjaro-iso-profiles
Modify your copies as needed. To make buildiso use your modified versions add a file in your local manjaro-tools folder and name it iso-profiles.conf
touch ~/.config/manjaro-tools/iso-profiles.conf
Add the following content matching your local profiles dir
run_dir=/home/$USER/manjaro-iso-profiles
#9
Oh, also war es doch ein temporärer Fehler …
Danke ! :grinning:
