Hello everybody,
I am trying to conduct Samba sharing between 2 Manjaro XFCE systems. I want to be able to mainly write on computer A from computer B. The reason is, the HDD on computer B has got corrupted and I have to recover some important files from it. I have to use Photorec on computer B and select computer A as the destination where Photorec can save the recovered files.
I have connected both systems with Ethernet directly without using any router. I do have router but, since the two computers got connected readily without it and computer A is readable and browsable from computer B, I thought why unnecessarily increase another hardware layer. The Samba-share on computer A is visible from computer B. I can browse through folders. I can read files. However, I can not write to that folder from computer B.
I did the following editing to the file /etc/samba/smb.conf on computer A. Inserted the below, inside the /etc/samba/smb.conf file at the end of that file.
[MySambaShare]
comment = My Samba share
path = /samba
writable = yes
browseable = no
create mask = 0700
directory mask = 0700
read only = no
guest ok = no
After doing this, I issued the following commands on computer A;
$ sudo systemctl stop samba
$ sudo groupadd -r sambausers
$ sudo usermod -aG sambausers Username
$ sudo smbpasswd -a Username
New SMB password:
Retype new SMB password:
Added user Username.
$ sudo mkdir /samba
$ sudo chown -R :sambausers /samba
$ sudo chmod 1770 /samba
$ sudo systemctl enable --now smb
$ sudo systemctl enable --now nmb
$ sudo systemctl restart smb.service
$ systemctl status smb
● smb.service - Samba SMB Daemon
Loaded: loaded (/usr/lib/systemd/system/smb.service; enabled; vendor prese>
Active: active (running) since Sun 2021-04-11 16:16:57 IST; 1h 6min ago
Docs: man:smbd(8)
man:samba(7)
man:smb.conf(5)
Main PID: 966 (smbd)
Status: “smbd: ready to serve connections…”
Tasks: 4 (limit: 4405)
Memory: 17.7M
CGroup: /system.slice/smb.service
├─ 966 /usr/bin/smbd --foreground --no-process-group
├─1011 /usr/bin/smbd --foreground --no-process-group
├─1012 /usr/bin/smbd --foreground --no-process-group
└─1095 /usr/bin/smbd --foreground --no-process-group
Apr 11 16:16:51 xxxxxxxxxx systemd[1]: Starting Samba SMB Daemon…
Apr 11 16:16:57 xxxxxxxxxx systemd[1]: Started Samba SMB Daemon.
Apr 11 16:16:57 xxxxxxxxxx smbd[966]: [2021/04/11 16:16:57.624279, 0] …/…/li>
Apr 11 16:16:57 xxxxxxxxxx smbd[966]: daemon_ready: daemon ‘smbd’ finished st>
lines 1-20/20 (END)
$ systemctl status nmb
● nmb.service - Samba NMB Daemon
Loaded: loaded (/usr/lib/systemd/system/nmb.service; enabled; vendor prese>
Active: active (running) since Sun 2021-04-11 16:16:51 IST; 1h 6min ago
Docs: man:nmbd(8)
man:samba(7)
man:smb.conf(5)
Main PID: 687 (nmbd)
Status: “nmbd: ready to serve connections…”
Tasks: 1 (limit: 4405)
Memory: 16.7M
CGroup: /system.slice/nmb.service
└─687 /usr/bin/nmbd --foreground --no-process-group
Apr 11 16:16:26 xxxxxxxxxx nmbd[687]: NOTE: NetBIOS name resolution is not su>
Apr 11 16:16:51 xxxxxxxxxx nmbd[687]: [2021/04/11 16:16:51.826402, 0] …/…/li>
Apr 11 16:16:51 xxxxxxxxxx nmbd[687]: daemon_ready: daemon ‘nmbd’ finished st>
Apr 11 16:16:51 xxxxxxxxxx systemd[1]: Started Samba NMB Daemon.
Apr 11 16:17:14 xxxxxxxxxx nmbd[687]: [2021/04/11 16:17:14.855452, 0] …/…/so>
Apr 11 16:17:14 xxxxxxxxxx nmbd[687]: *****
Apr 11 16:17:14 xxxxxxxxxx nmbd[687]: Samba name server xxxxxxxxxx is now a l>
lines 1-23…skipping…
Loaded: loaded (/usr/lib/systemd/system/nmb.service; enabled; vendor preset: disabled)
Docs: man:nmbd(8)
man:samba(7)
man:smb.conf(5)
Memory: 16.7M
Apr 11 16:16:26 xxxxxxxxxx nmbd[687]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Apr 11 16:16:51 xxxxxxxxxx nmbd[687]: [2021/04/11 16:16:51.826402, 0] …/…/lib/util/become_daemon.c:135(daemon_ready)
Apr 11 16:16:51 xxxxxxxxxx nmbd[687]: daemon_ready: daemon ‘nmbd’ finished starting up and ready to serve connections
Apr 11 16:17:14 xxxxxxxxxx nmbd[687]: [2021/04/11 16:17:14.855452, 0] …/…/source3/nmbd/nmbd_become_lmb.c:398(become_local_master_st>
Apr 11 16:17:14 xxxxxxxxxx nmbd[687]: Samba name server xxxxxxxxxx is now a local master browser for workgroup WORKGROUP on subnet 1>
lines 1-23/23 (END)
$ testparm
Load smb config files from /etc/samba/smb.conf
lp_load_ex: Max protocol NT1 is less than min protocol SMB2.
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
#Global parameters
[global]
client min protocol = SMB2
dns proxy = No
log file = /var/log/samba/%m.log
map to guest = Bad Password
max log size = 1000
name resolve order = lmhosts bcast host wins
obey pam restrictions = Yes
pam password change = Yes
passwd chat = NewUNIXpassword %n\n ReTypenewUNIXpassword* %n\n passwd:allauthenticationtokensupdatedsuccessfully*
passwd program = /usr/bin/passwd %u
security = USER
server min protocol = SMB3
server role = standalone server
unix password sync = Yes
usershare allow guests = Yes
usershare max shares = 100
usershare path = /var/lib/samba/usershare
idmap config * : backend = tdb
force create mode = 0070
force directory mode = 0070
[homes]
browseable = No
comment = Home Directories
create mask = 0700
valid users = %S
[printers]
browseable = No
comment = All Printers
create mask = 0700
path = /var/spool/samba
printable = Yes
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
[MySambaShare]
browseable = No
create mask = 0700
path = /samba
read only = No
I did not do anything on the computer B which is booted from the Manjaro OS installed on the USB. It simply readily got connected and the Samba-share on computer A is readable and browsable and I had to do nothing. It is just not letting write on the computer A from computer B.
Kindly throw some light over why this is happening and how I could resolve this issue.
Any efforts towards this is greatly appreciated.
Thanks and warm regards.
