Introducing: manjaro32.org
i686
manjaro32
#21
@eugen-b: for the first approach you have to adopt to archlinux32 and add the manjaro32 repo on top. My approach is much more simpler by switching the branch and installing the additional keyring file from archlinux32.
#22
Absolutely if there’s a better approach then I’m all for it - this project was basically a way of trying to keep my 32-bit systems running Manjaro. :slight_smile:
#23
Here is the list of the keyring files currently on my server:
ls pool/*/{arch,manjaro}*keyring* | grep -v sig
pool/overlay-32/manjaro-keyring-20171027-1-any.pkg.tar.xz
pool/overlay/manjaro-keyring-20171027-1-any.pkg.tar.xz
pool/sync-32/archlinux32-keyring-20171113-1-any.pkg.tar.xz
pool/sync-32/archlinux32-keyring-transition-20170628-1-any.pkg.tar.xz
pool/sync-32/archlinux-keyring-20171020-1-any.pkg.tar.xz
pool/sync/archlinux-keyring-20171020-1-any.pkg.tar.xz
#24
Approach to switch to x32-unstable:
sudo sed -i -e 's|stable|x32-unstable|g' /etc/pacman.d/mirrorlist
sudo pacman -Syy
sudo pacman -S archlinux32-keyring-transition
sudo pacman -Suu
Mirror https://mirror.netzspielplatz.de is one of the few mirrors able to handle the extra 40.2 G we had added with Manjaro-32.
#25
Seems the current approach reduced our updated mirrors down to 4!
mirror-status
All others seems not able to handle the new size need due adding Manjaro-32. Ideas and thoughts about Manjaro-32 please here.
#26
Current differences on the new x32 branches:
:: Available branches:
 1) stable
 2) testing
 3) unstable
 4) x32-testing
 5) x32-unstable
:: First Branch index: 4
:: Second Branch index: 5
:: Compare branch 'x32-testing' with branch 'x32-unstable'.
   Continue? [Y/n]
:: Obtaining data...
 obtaining remote repository packages...
:: Different sync package(s) in repository community i686
                             PACKAGE          x32-testing         x32-unstable
                                 afl              2.52b-1              2.51b-1
                               arcus              3.0.3-1              2.7.0-1
                             arduino            1:1.8.3-1            1:1.8.5-1
                            audacity              2.2.0-1                    -
                             aws-cli           1.11.181-1           1.11.178-1
                                borg              1.1.2-2              1.1.1-1
              caja-extensions-common             1.18.2-1             1.18.1-1
                           caja-gksu             1.18.2-1             1.18.1-1
                caja-image-converter             1.18.2-1             1.18.1-1
                  caja-open-terminal             1.18.2-1             1.18.1-1
                         caja-sendto             1.18.2-1             1.18.1-1
                          caja-share             1.18.2-1             1.18.1-1
                      caja-wallpaper             1.18.2-1             1.18.1-1
                     caja-xattr-tags             1.18.2-1             1.18.1-1
                                calf             0.90.0-1             0.0.60-4
                              cddlib               094h-1               094h-2
               cldr-emoji-annotation             32.0.0-1            31.90.0-1
                               cmark             0.28.3-1             0.28.0-1
                           cmark-gfm      0.28.0.gfm.11-1                    -
                           cpp-hocon              0.1.6-1              0.1.5-2
                                cura              3.0.3-1              2.7.0-1
                          curaengine              3.0.3-1              2.7.0-2
               dbeaver-plugin-office              1.1.2-1              1.1.5-1
           dbeaver-plugin-svg-format              1.0.1-1              1.0.4-1
                          deepin-api             3.1.17-1             3.1.16-1
                   deepin-boot-maker              2.0.4-1            2.0.3.1-1
                     deepin-calendar              1.1.0-1             1.0.13-1
                        deepin-clone              0.0.6-1            0.0.5.1-1
               deepin-control-center              4.3.1-2              4.3.1-1
                       deepin-daemon              3.2.3-1              3.2.2-1
              deepin-desktop-schemas              3.2.0-1             3.1.19-1
                         deepin-dock              4.4.2-1              4.4.1-1
                 deepin-file-manager            1:4.4.1-1            1:4.4.0-1
                 deepin-image-viewer           1.2.16.2-1           1.2.16.1-1
                     deepin-launcher              4.2.2-1              4.2.1-1
                         deepin-menu              3.1.8-1              3.1.7-1
                        deepin-movie           1:2.9.95-1           1:2.9.94-1
                        deepin-music              3.1.7-1            3.1.6.2-1
                       deepin-picker                1.5-1                1.4-1
               deepin-qt5dxcb-plugin                1.1-1                1.0-1
              deepin-screen-recorder              2.6.4-1              2.6.3-1
                   deepin-screenshot           4.0.10.1-1             4.0.10-1
                   deepin-session-ui              4.1.0-2              4.1.0-1
               deepin-system-monitor              1.3.6-1              1.3.5-1
                     deepin-terminal              2.7.5-1              2.7.4-1
               deepin-voice-recorder              1.3.6-1              1.3.5-1
                          diffoscope                 88-1                 87-1
                         dns-lexicon             2.1.11-1             2.1.10-1
                      docker-compose             1.17.0-1             1.16.1-1
                             dot2tex              2.9.0-2              2.9.0-2
                            dropbear            2017.75-3            2017.75-2
                             dtkcore            1:2.0.5-1            1:2.0.2-2
                           dtkwidget              2.0.5-1            2.0.4.2-1
                               dtkwm              2.0.5-1              2.0.1-1
                            electrum              3.0.1-1              2.9.3-1
                         emby-server           3.2.36.0-1           3.2.34.0-1
                            engrampa             1.18.3-1             1.18.2-1
                              erlang             20.0.1-2               20.1-1
                     erlang-unixodbc             20.0.1-2               20.1-1
                              facter              3.9.2-1              3.8.0-2
                                fasm               1.72-1            1.71.60-3
                           filezilla             3.29.0-1             3.28.0-1
                    firefox-noscript              5.1.5-1              5.1.3-1
                              fossil                2.4-1                2.3-1
                                gcc6              6.4.1-4              6.4.1-3
                            gcc6-ada              6.4.1-4              6.4.1-3
                        gcc6-fortran              6.4.1-4              6.4.1-3
                            gcc6-gcj              6.4.1-4              6.4.1-3
                             gcc6-go              6.4.1-4              6.4.1-3
                           gcc6-libs              6.4.1-4              6.4.1-3
                           gcc6-objc              6.4.1-4              6.4.1-3
                                 ghc              8.2.1-3              8.2.1-1
                            ghc-libs              8.2.1-3              8.2.1-1
                          ghc-static              8.2.1-3              8.2.1-1
                           git-annex         6.20171026-2         6.20171026-1
                        gitlab-shell            1:5.9.4-1            2:5.9.3-1
                              gradle                4.3-1              4.2.1-1
                          gradle-doc                4.3-1              4.2.1-1
                          gradle-src                4.3-1              4.2.1-1
                              grails              3.3.1-1              3.3.0-1
                         grails-docs              3.3.1-1              3.3.0-1
                             hashcat            1:4.0.0-1            1:3.6.0-3
                 haskell-adjunctions               4.3-38               4.3-37
                       haskell-aeson            1.2.3.0-1            1.2.1.0-3
                haskell-aeson-compat            0.3.7.1-7            0.3.7.1-5
                haskell-aeson-pretty             0.8.5-14             0.8.5-11
         haskell-annotated-wl-pprint              0.7.0-5              0.7.0-4
               haskell-ansi-terminal            0.6.3.1-4            0.6.3.1-3
              haskell-ansi-wl-pprint            0.6.8.1-3            0.6.8.1-2
                       haskell-appar              0.1.4-5              0.1.4-4
               haskell-asn1-encoding             0.9.5-19             0.9.5-17
                  haskell-asn1-parse             0.9.4-30             0.9.4-28
                  haskell-asn1-types             0.3.2-26             0.3.2-24
                       haskell-async            2.1.1.1-4            2.1.1.1-3
                  haskell-attoparsec           0.13.2.0-4           0.13.2.0-3
          haskell-attoparsec-iso8601           1.0.0.0-14           1.0.0.0-13
                 haskell-auto-update              0.1.4-5              0.1.4-4
                 haskell-base-compat              0.9.3-4              0.9.3-3
                haskell-base-orphans                0.6-4                0.6-3
        haskell-base-unicode-symbols            0.2.2.4-5            0.2.2.4-4
           haskell-base16-bytestring            0.1.1.6-6            0.1.1.6-5
           haskell-base64-bytestring            1.0.0.1-9            1.0.0.1-8
                    haskell-basement              0.0.3-1              0.0.2-1
                  haskell-bifunctors              5.4.2-7              5.4.2-6
              haskell-bindings-uname                0.1-3                0.1-2
                    haskell-bitarray            0.0.1.1-4            0.0.1.1-3
               haskell-blaze-builder            0.4.0.2-6            0.4.0.2-5
                  haskell-blaze-html            0.9.0.1-3            0.9.0.1-2
                haskell-blaze-markup            0.8.0.0-3            0.8.0.0-2
                    haskell-byteable              0.1.1-6              0.1.1-5
                   haskell-byteorder              1.0.4-5              1.0.4-4
               haskell-cabal-doctest              1.0.3-1              1.0.2-3
                  haskell-call-stack              0.1.0-4              0.1.0-3
            haskell-case-insensitive           1.2.0.10-5           1.2.0.10-4
                      haskell-cereal            0.5.4.0-4            0.5.4.0-3
                  haskell-cipher-aes            0.2.11-24            0.2.11-22
               haskell-clientsession           0.9.1.2-27           0.9.1.2-25
                       haskell-clock              0.7.2-5              0.7.2-4
                       haskell-cmark              0.5.6-4              0.5.6-2
                   haskell-cmark-gfm              0.1.3-1                    -
                     haskell-cmdargs            0.10.18-1            0.10.17-3
                     haskell-comonad              5.0.2-3              5.0.2-2
                     haskell-conduit           1.2.12.1-1             1.2.12-1
         haskell-conduit-combinators             1.1.1-41             1.1.1-40
               haskell-conduit-extra              1.2.0-1             1.1.17-1
                  haskell-connection             0.2.8-29             0.2.8-27
               haskell-contravariant               1.4-19               1.4-18
                      haskell-cookie            0.4.2.1-8            0.4.2.1-7
                       haskell-cpphs             1.20.8-3             1.20.8-2
                   haskell-cprng-aes             0.6.1-26             0.6.1-24
                  haskell-crypto-api            0.13.2-12            0.13.2-11
         haskell-crypto-cipher-types             0.0.9-24             0.0.9-22
               haskell-crypto-random             0.0.9-26             0.0.9-24
                  haskell-cryptohash            0.11.9-34            0.11.9-32
              haskell-cryptohash-md5         0.11.100.1-4         0.11.100.1-3
             haskell-cryptohash-sha1         0.11.100.1-4         0.11.100.1-3
           haskell-cryptohash-sha256         0.11.100.1-4         0.11.100.1-3
                  haskell-cryptonite               0.24-7               0.24-5
          haskell-cryptonite-conduit             0.2.0-50             0.2.0-46
                    haskell-css-text           0.1.2.2-21           0.1.2.2-20
               haskell-data-accessor            0.2.2.7-5            0.2.2.7-4
      haskell-data-accessor-template           0.2.1.14-3           0.2.1.14-2
  haskell-data-accessor-transformers            0.2.1.7-5            0.2.1.7-4
                haskell-data-default            0.7.1.1-9            0.7.1.1-8
          haskell-data-default-class            0.1.2.0-5            0.1.2.0-4
haskell-data-default-instances-containers             0.0.1-17             0.0.1-16
haskell-data-default-instances-dlist             0.0.1-22             0.0.1-21
haskell-data-default-instances-old-locale             0.0.1-17             0.0.1-16
            haskell-deepseq-generics            0.2.0.0-4            0.2.0.0-3
                      haskell-digest            0.0.1.2-6            0.0.1.2-5
                haskell-distributive              0.5.3-3              0.5.3-2
                       haskell-dlist            0.8.0.3-3            0.8.0.3-2
                haskell-doctemplates           0.1.0.2-33           0.1.0.2-31
                   haskell-easy-file              0.2.1-5              0.2.1-4
                        haskell-echo              0.1.3-3              0.1.3-2
                     haskell-ed25519            0.0.5.0-5            0.0.5.0-4
                      haskell-either                4.5-1           4.4.1.1-31
                     haskell-entropy              0.3.8-3              0.3.8-2
                  haskell-exceptions              0.8.3-4              0.8.3-3
       haskell-extensible-exceptions           0.1.1.4-17           0.1.1.4-16
                       haskell-extra                1.6-2                1.6-1
                 haskell-fast-logger             2.4.10-5             2.4.10-4
                  haskell-file-embed           0.0.10.1-2           0.0.10.1-1
                    haskell-filelock            0.1.1.2-3            0.1.1.2-2
                   haskell-filemanip           0.3.6.3-10            0.3.6.3-9
                  haskell-foundation             0.0.16-1             0.0.15-1
                        haskell-free            4.12.4-38            4.12.4-37
                    haskell-fsnotify            0.2.1.1-3            0.2.1.1-2
            haskell-generic-deriving             1.11.2-4             1.11.2-3
                      haskell-gitrev              1.3.1-3              1.3.1-2
                        haskell-glob             0.7.14-5             0.7.14-4
            haskell-hackage-security            0.5.2.2-7            0.5.2.2-6
             haskell-haddock-library              1.4.5-3              1.4.5-2
                      haskell-hakyll           4.9.8.0-71           4.9.8.0-69
                    haskell-hashable            1.2.6.1-3            1.2.6.1-2
                    haskell-hastache             0.6.1-12             0.6.1-11
                    haskell-hinotify              0.3.9-5              0.3.9-4
                      haskell-hjsmin           0.2.0.2-15           0.2.0.2-14
                    haskell-hopenpgp            2.5.5-122            2.5.5-121
                   haskell-hourglass             0.2.10-5             0.2.10-4
                       haskell-hpack             0.18.1-7             0.18.1-3
                 haskell-hs-bibutils            6.2.0.1-1                5.5-6
                       haskell-hslua              0.4.1-6              0.4.1-5
                       haskell-hspec              2.4.4-5              2.4.4-3
                  haskell-hspec-core              2.4.4-5              2.4.4-3
              haskell-hspec-discover              2.4.4-3              2.4.4-2
          haskell-hspec-expectations              0.8.2-5              0.8.2-4
            haskell-hspec-smallcheck             0.4.2-15             0.4.2-13
                        haskell-http           4000.3.7-5           4000.3.7-4
               haskell-http-api-data           0.3.7.1-17           0.3.7.1-16
                 haskell-http-client            0.5.7.0-6            0.5.7.0-5
             haskell-http-client-tls           0.3.5.1-18           0.3.5.1-16
                haskell-http-conduit           2.2.3.2-22           2.2.3.2-17
                   haskell-http-date           0.0.6.1-30           0.0.6.1-29
                  haskell-http-types             0.9.1-14             0.9.1-13
                       haskell-http2             1.6.3-13             1.6.3-11
                       haskell-hunit            1.6.0.0-4            1.6.0.0-3
                         haskell-hxt           9.3.1.16-5           9.3.1.16-4
          haskell-hxt-charproperties            9.2.0.1-4            9.2.0.1-3
         haskell-hxt-regex-xmlschema            9.2.0.3-5            9.2.0.3-4
                 haskell-hxt-unicode            9.0.2.4-4            9.0.2.4-3
                     haskell-ieee754              0.8.0-4              0.8.0-3
          haskell-incremental-parser            0.2.5.2-1            0.2.5.1-4
          haskell-integer-logarithms              1.0.2-3              1.0.2-2
                     haskell-iproute              1.7.1-5              1.7.1-4
                        haskell-json             0.9.1-10              0.9.1-9
                 haskell-juicypixels            3.2.8.3-2            3.2.8.3-1
              haskell-kan-extensions              5.0.2-8              5.0.2-7
         haskell-language-javascript           0.6.0.10-4           0.6.0.10-3
                        haskell-lens             4.15.4-5             4.15.4-4
                       haskell-lexer              1.0.1-4              1.0.1-3
                 haskell-lifted-base           0.2.3.11-7           0.2.3.11-6
                      haskell-logict            0.6.0.2-4            0.6.0.2-3
              haskell-math-functions            0.2.1.0-5            0.2.1.0-4
                      haskell-memory             0.14.8-4             0.14.8-2
                   haskell-microlens            0.4.8.1-3            0.4.8.1-2
               haskell-microlens-mtl           0.1.11.0-4           0.1.11.0-3
                haskell-microlens-th            0.4.1.1-5            0.4.1.1-4
                  haskell-mime-types            0.1.0.7-6            0.1.0.7-5
                      haskell-mintty              0.1.1-3              0.1.1-2
                      haskell-mmorph              1.1.0-4              1.1.0-3
               haskell-monad-control            1.0.2.2-3            1.0.2.2-2
                haskell-monad-logger           0.3.25.1-5           0.3.25.1-2
                 haskell-monad-loops              0.4.3-6              0.4.3-5
                 haskell-monadrandom              0.5.1-5              0.5.1-4
            haskell-mono-traversable            1.0.4.0-1            1.0.2.1-2
                         haskell-mtl              2.2.1-9              2.2.1-8
                  haskell-mwc-random           0.13.6.0-4           0.13.6.0-3
                     haskell-network            2.6.3.2-4            2.6.3.2-3
                haskell-network-info            0.2.0.8-6            0.2.0.8-5
                 haskell-network-uri            2.6.1.0-7            2.6.1.0-6
                  haskell-old-locale           1.0.0.7-11           1.0.0.7-10
                    haskell-old-time           1.1.0.3-11           1.1.0.3-10
                haskell-open-browser            0.2.1.0-6            0.2.1.0-5
        haskell-optparse-applicative           0.14.0.0-2           0.14.0.0-1
             haskell-optparse-simple              0.0.4-1             0.0.3-60
                haskell-pandoc-types             1.17.2-3             1.17.1-2
                    haskell-parallel            3.2.1.1-4            3.2.1.1-3
                      haskell-parsec             3.1.11-6             3.1.11-5
                        haskell-path             0.6.1-11              0.6.1-9
                     haskell-path-io              1.3.3-7              1.3.3-5
                 haskell-path-pieces              0.2.1-9              0.2.1-8
                         haskell-pem              0.2.2-7              0.2.2-6
                  haskell-persistent              2.7.1-2              2.7.0-7
           haskell-persistent-sqlite              2.6.3-2             2.6.2-53
         haskell-persistent-template              2.5.3-3             2.5.2-56
                        haskell-pid1            0.1.2.0-3            0.1.2.0-2
                   haskell-polyparse               1.12-6               1.12-5
              haskell-prelude-extras            0.4.0.3-5            0.4.0.3-4
                 haskell-pretty-show             1.6.13-4             1.6.13-3
                   haskell-primitive            0.6.2.0-4            0.6.2.0-3
                 haskell-profunctors              5.2.1-5              5.2.1-4
            haskell-project-template             0.2.0-78             0.2.0-75
                    haskell-psqueues            0.2.4.0-1            0.2.3.0-2
                  haskell-quickcheck             2.10.1-1           2.10.0.1-2
               haskell-quickcheck-io              0.2.0-5              0.2.0-3
                      haskell-random                1.1-9                1.1-8
                  haskell-reflection              2.1.2-5              2.1.2-4
           haskell-regex-applicative              0.3.3-5              0.3.3-4
      haskell-regex-applicative-text            0.1.0.1-5            0.1.0.1-4
                  haskell-regex-base            0.93.2-29            0.93.2-28
                  haskell-regex-pcre             0.94.4-5             0.94.4-4
                  haskell-regex-tdfa              1.2.2-7              1.2.2-6
               haskell-resource-pool           0.2.3.2-21           0.2.3.2-20
                   haskell-resourcet             1.1.9-10              1.1.9-9
                       haskell-retry            0.7.4.3-1            0.7.4.2-3
                     haskell-rfc5051            0.1.0.3-6            0.1.0.3-5
              haskell-roman-numerals            0.5.1.5-7            0.5.1.5-6
                        haskell-safe             0.3.15-3             0.3.15-2
                  haskell-scientific            0.3.5.2-2            0.3.5.2-1
                   haskell-securemem             0.1.9-24             0.1.9-22
               haskell-semigroupoids              5.2.1-5              5.2.1-4
                  haskell-semigroups             0.18.3-5             0.18.3-4
                      haskell-setenv            0.1.1.3-6            0.1.1.3-5
                         haskell-sha            1.6.4.2-8            1.6.4.2-7
                 haskell-shakespeare             2.0.14-4             2.0.14-2
                    haskell-silently              1.2.5-6              1.2.5-5
             haskell-simple-sendfile             0.2.25-6             0.2.25-5
                       haskell-skein           1.0.9.4-12           1.0.9.4-11
                 haskell-skylighting           0.1.1.5-34           0.1.1.5-32
                  haskell-smallcheck              1.1.2-3              1.1.2-2
                       haskell-socks             0.5.5-10              0.5.5-9
                       haskell-split            0.2.3.2-4            0.2.3.2-3
                    haskell-src-exts             1.19.1-3             1.19.1-2
                    haskell-statevar            1.1.0.4-5            1.1.0.4-4
                         haskell-stm            2.4.4.1-6            2.4.4.1-5
                   haskell-stm-chans            3.0.0.4-7            3.0.0.4-6
                       haskell-store           0.4.3.2-10            0.4.3.2-5
                  haskell-store-core              0.4.1-5              0.4.1-4
           haskell-streaming-commons             0.1.18-4             0.1.18-3
                      haskell-strict              0.3.2-5              0.3.2-4
                haskell-stringsearch            0.3.6.6-5            0.3.6.6-4
                         haskell-syb                0.7-3                0.7-2
                      haskell-tagged              0.8.5-4              0.8.5-3
                     haskell-tagsoup             0.14.1-5             0.14.1-4
                         haskell-tar            0.5.0.3-5            0.5.0.3-4
                   haskell-temporary            1.2.1.1-3            1.2.1.1-2
                     haskell-texmath            0.9.4.4-3            0.9.4.2-1
                        haskell-text            1.2.2.2-4            1.2.2.2-3
                    haskell-text-icu           0.7.0.1-11           0.7.0.1-10
                haskell-text-metrics              0.3.0-2              0.3.0-1
                   haskell-tf-random               0.5-13               0.5-12
              haskell-th-abstraction            0.2.6.0-2            0.2.6.0-1
              haskell-th-expand-syns            0.4.3.0-5            0.4.3.0-4
                     haskell-th-lift              0.7.7-4              0.7.7-3
           haskell-th-lift-instances             0.1.11-7             0.1.11-6
                  haskell-th-orphans             0.13.4-4             0.13.4-3
               haskell-th-reify-many              0.1.8-4              0.1.8-3
                haskell-th-utilities           0.2.0.1-20           0.2.0.1-19
          haskell-time-locale-compat            0.1.1.3-4            0.1.1.3-3
                         haskell-tls              1.4.0-8              1.4.0-6
           haskell-transformers-base              0.4.4-8              0.4.4-7
         haskell-transformers-compat            0.5.1.4-6            0.5.1.4-5
          haskell-unicode-transforms              0.3.3-2              0.3.3-1
                    haskell-uniplate            1.6.12-18            1.6.12-17
                 haskell-unix-compat            0.4.3.1-4            0.4.3.1-3
                   haskell-unix-time              0.3.7-4              0.3.7-3
                    haskell-unliftio            0.1.1.0-1            0.1.0.0-5
               haskell-unliftio-core            0.1.0.0-2            0.1.0.0-1
        haskell-unordered-containers            0.2.8.0-7            0.2.8.0-6
              haskell-uri-bytestring           0.2.3.3-10            0.2.3.3-9
                 haskell-utf8-string            1.0.1.1-5            1.0.1.1-4
                  haskell-utility-ht             0.0.14-4             0.0.14-3
                        haskell-uuid             1.3.13-9             1.3.13-8
                  haskell-uuid-types              1.0.3-9              1.0.3-8
                       haskell-vault            0.3.0.7-6            0.3.0.7-5
                      haskell-vector           0.12.0.1-4           0.12.0.1-3
           haskell-vector-algorithms            0.7.0.1-9            0.7.0.1-8
             haskell-vector-th-unbox            0.2.1.6-6            0.2.1.6-5
                        haskell-void              0.7.2-4              0.7.2-3
                         haskell-wai           3.2.1.1-20           3.2.1.1-19
              haskell-wai-app-static          3.1.6.1-102           3.1.6.1-98
                   haskell-wai-extra          3.0.20.0-15          3.0.20.0-13
                  haskell-wai-logger             2.3.0-20             2.3.0-19
                        haskell-warp             3.2.13-9             3.2.13-7
                       haskell-word8              0.1.3-3              0.1.3-2
                        haskell-x509              1.7.2-7              1.7.2-5
                  haskell-x509-store              1.6.5-7              1.6.5-5
                 haskell-x509-system              1.6.6-7              1.6.6-5
             haskell-x509-validation              1.6.9-7              1.6.9-5
                         haskell-xml             1.3.14-9             1.3.14-8
                 haskell-xml-conduit              1.6.0-7              1.6.0-4
                   haskell-xml-types              0.3.6-9              0.3.6-8
                        haskell-yaml             0.8.24-1           0.8.23.3-7
                       haskell-yesod            1.4.5-114            1.4.5-113
                  haskell-yesod-core             1.4.37-8             1.4.37-2
                haskell-yesod-static           1.5.3.1-28           1.5.3.1-22
                 haskell-zip-archive            0.3.1.1-3            0.3.1.1-2
                        haskell-zlib            0.6.1.2-4            0.6.1.2-3
                               hiera              3.4.2-1              3.4.0-1
                             hindent            5.2.4.1-2            5.2.4.1-1
                         hledger-web                1.4-7                1.4-6
                               hlint             2.0.9-24             2.0.9-23
                      hopenpgp-tools            0.19.5-15            0.19.5-13
                               idesk              0.7.5-7              0.7.5-8
                                  io         2017.06.08-1         2017.06.09-1
                              iperf3                3.3-1                3.2-1
                             ipython              6.2.1-2              6.2.1-1
                             jenkins               2.89-1               2.87-1
                                jmol            14.24.1-1            14.22.1-1
                                knot              2.6.1-1              2.6.0-1
                          leatherman              1.3.0-1              1.2.1-1
                        libfilezilla             0.11.1-1             0.11.0-1
                             libgiac           1.4.9.19-1           1.2.3.57-1
                        libmediainfo              17.10-1             0.7.99-1
                  libreoffice-online            5.4.0.2-2            5.4.0.2-1
                      lua-filesystem            1.7.0.2-1              1.6.3-3
                    lua51-filesystem            1.7.0.2-1              1.6.3-3
                    lua52-filesystem            1.7.0.2-1              1.6.3-3
                          luxblend25                1.6-3                1.6-2
                                 lxc            1:2.1.1-1            1:2.1.0-2
                           mailutils                3.4-1                3.3-1
                               marco             1.18.2-1             1.18.1-2
                        mate-applets             1.18.2-1             1.18.1-2
                          mate-media             1.18.2-1             1.18.1-1
                               monit             5.25.0-1             5.24.0-1
                             nanomsg              1.1.0-1              1.0.0-1
                              neovim              0.2.1-2              0.2.0-2
                      nginx-mainline             1.13.6-1             1.13.5-1
                            openntpd              6.2p3-1              6.2p2-1
                              pandoc         1.19.2.1-122         1.19.2.1-113
                     pandoc-citeproc           0.11.1.3-1           0.11.1.1-1
                     pandoc-crossref           0.2.6.0-20           0.2.6.0-19
                                paps              0.7.0-1              0.6.8-6
                              parity              1.8.2-1              1.8.1-1
                               pcsxr             1.9.93-4             1.9.93-5
                         pdfshuffler              0.6.0-4                    -
                  perl-finance-quote               1.44-1               1.38-3
                         pidgin-sipe             1.23.0-1             1.22.1-1
                               pigar              0.7.1-1              0.7.0-1
                                poco           1.7.9_p1-1              1.7.9-1
                             pokerth              1.1.2-1             1.1.1-21
                              puppet              5.3.2-1              5.1.0-1
                    pyopencl-headers           1:2017.2-1           1:2017.2-2
                      python-aiohttp              2.3.2-1              2.2.5-1
              python-apache-libcloud              2.2.1-1              1.5.0-1
                     python-autobahn            17.10.1-1             17.9.3-1
                     python-botocore             1.7.39-1             1.7.36-1
                     python-colorlog              3.1.0-2              3.1.0-1
         python-cryptography-vectors              2.1.3-1              2.1.2-1
                      python-dropbox              8.4.1-1              8.4.0-1
              python-flake8-debugger              3.0.0-1              1.4.0-1
                           python-fs             2.0.15-1             2.0.12-1
                        python-gammu               2.10-1                2.9-1
                   python-hypothesis             3.36.0-1             3.33.1-1
             python-jsonrpclib-pelix              0.3.1-2                    -
                    python-multidict              3.3.2-1              3.3.0-1
                       python-pbkdf2                1.3-3                    -
                       python-pifpaf             1.11.1-1             1.10.5-1
                         python-pint              0.8.1-1                0.8-1
                       python-pipenv              8.3.2-1              8.2.7-2
                    python-pyftpdlib              1.5.3-1              1.5.2-1
                     python-pyopencl           1:2017.2-1           1:2017.2-2
                        python-pypdf               1.13-4                    -
                         python-pyro               4.63-1               4.62-1
                        python-qiniu              7.1.9-1              7.1.8-1
                         python-rpy2              2.9.1-1              2.9.0-1
                     python-selenium              3.7.0-1              3.6.0-1
                   python-simplejson             3.12.0-1             3.11.1-1
                   python-sqlalchemy             1.1.15-1             1.1.14-1
                        python-sympy              1.1.1-1                1.1-1
             python2-apache-libcloud              2.2.1-1              1.5.0-1
                    python2-autobahn            17.10.1-1             17.9.3-1
                    python2-colorlog              3.1.0-2              3.1.0-1
        python2-cryptography-vectors              2.1.3-1              2.1.2-1
                     python2-dropbox              8.4.1-1              8.4.0-1
             python2-flake8-debugger              3.0.0-1              1.4.0-1
                          python2-fs             2.0.15-1             2.0.12-1
                       python2-gammu               2.10-1                2.9-1
                  python2-hypothesis             3.36.0-1             3.33.1-1
            python2-jsonrpclib-pelix              0.3.1-2                    -
                    python2-m2crypto             0.27.0-1             0.26.0-2
                      python2-pbkdf2                1.3-3                1.3-2
                      python2-pifpaf             1.11.1-1             1.10.5-1
                       python2-pigar              0.7.1-1              0.7.0-1
                        python2-pint              0.8.1-1                0.8-1
                      python2-pipenv              8.3.2-1              8.2.7-2
                   python2-pyftpdlib              1.5.3-1              1.5.2-1
                    python2-pyopencl           1:2017.2-1           1:2017.2-2
                       python2-pypdf               1.13-4                    -
                        python2-pyro               4.63-1               4.62-1
                       python2-qiniu              7.1.9-1              7.1.8-1
                    python2-selenium              3.7.0-1              3.6.0-1
                  python2-simplejson             3.12.0-1             3.11.1-1
                  python2-sqlalchemy             1.1.15-1             1.1.14-1
                       python2-sympy              1.1.1-1                1.1-1
                                qmmp             1.1.12-1             1.1.10-1
                         qutebrowser              1.0.3-1              1.0.2-2
                            rabbitmq             3.6.13-1             3.6.12-1
                       rabbitmqadmin             3.6.13-1             3.6.12-1
                             remmina    1:1.2.0rcgit.24-1    1:1.2.0rcgit.22-1
                                rofi              1.3.1-2              1.4.2-1
                            ruby-atk              3.2.0-1              3.1.9-1
                  ruby-cairo-gobject              3.2.0-1              3.1.9-1
                        ruby-daemons              1.2.5-1              1.2.4-1
                    ruby-gdk_pixbuf2              3.2.0-1              3.1.9-1
                           ruby-gio2              3.2.0-1              3.1.9-1
                          ruby-glib2              3.2.0-1              3.1.9-1
          ruby-gobject-introspection              3.2.0-1              3.1.9-1
                          ruby-gpgme             2.0.14-1             2.0.13-1
                           ruby-gtk2              3.2.0-1              3.1.9-1
                           ruby-mail              2.7.0-2              2.6.6-1
                      ruby-mini_mime              0.1.4-1                    -
                          ruby-paint              2.0.1-1              2.0.0-3
                          ruby-pango              3.2.0-1              3.1.9-1
                           ruby-ronn              0.7.3-6              0.7.3-5
                          ruby-rspec              3.7.0-1              3.6.0-1
                     ruby-rspec-core              3.7.0-1              3.6.0-1
             ruby-rspec-expectations              3.7.0-1              3.6.0-1
                    ruby-rspec-mocks              3.7.0-1              3.6.0-1
                  ruby-rspec-support              3.7.0-1              3.6.0-1
                           ruby-sass              3.5.3-1              3.5.2-1
                                rust           1:1.21.0-2           1:1.21.0-1
                           rust-docs           1:1.21.0-2           1:1.21.0-1
                       sage-notebook              1.0.1-3              1.0.1-2
                            sagemath                8.0-9                7.6-7
                        sagemath-doc                8.0-1                7.6-1
                    sagemath-jupyter                8.0-9                7.6-7
                        sagemath-src                8.0-1                7.6-1
                           seamonkey             2.49.1-1               2.48-1
                         simple-obfs              0.0.4-1              0.0.3-2
                            smplayer            17.11.0-1            17.10.0-1
                       speedtest-cli              1.0.7-1              1.0.6-1
                              sqlmap             1.1.11-1             1.1.10-1
                               stack    1.5.99.20171022-5    1.5.99.20171022-2
                            startdde             3.1.18-1             3.1.17-1
                strip-nondeterminism              0.040-1              0.038-2
                     stylish-haskell           0.8.1.0-22           0.8.1.0-21
                        supertuxkart           0.9.3rc1-2           0.9.3rc1-1
                                sway             0.15.0-1             0.14.0-1
                          swi-prolog              7.6.1-1              7.4.2-1
                           tesseract            3.05.01-2            3.05.01-1
                            tigervnc              1.8.0-3              1.8.0-2
                           uglify-js              3.1.8-1              3.1.6-1
                             vagrant              2.0.1-1              2.0.0-2
                virtualbox-guest-iso              5.2.1-1              5.2.0-1
                                wine               2.20-1               2.19-1
                                 wlc             0.0.11-1             0.0.10-1
                            workrave            1.10.20-1            1.10.18-1
                                xcas           1.4.9.19-1           1.2.3.57-1
                          youtube-dl         2017.11.06-1         2017.10.20-1
                               aiccu                    -           20070115-6
                 appstream-generator                    -              0.6.4-1
                           arrayfire                    -              3.5.1-2
                              aspcud                    -              1.9.4-1
                            audience                    -            0.2.1.1-1
                       autoconf-2.64                    -               2.64-1
                               bazel                    -              0.7.0-1
                             beignet                    -              1.3.1-4
                               cargo                    -             0.20.0-1
                               cegui                    -              0.8.7-8
                              clingo                    -              5.2.1-1
                       coffee-script                    -             1.12.7-1
                      cryptominisat2                    -             2.9.11-1
                                cuda                    -            9.0.176-4
                               cudnn                    -              7.0.3-1
                              cudnn6                    -             6.0.21-2
                                 dcd                    -              0.9.1-2
          deepin-nautilus-properties                    -             3.14.3-1
               deepin-social-sharing                    -              1.1.4-1
                                dfmt                    -              0.5.0-4
                                 dmd                    -          1:2.074.0-1
                         dolphin-emu                    -              1:5.0-4
                         dtksettings                    -              0.1.6-1
                              dtools                    -            2.073.1-1
                                 dub                    -              1.3.0-1
                              embree                    -             2.17.0-1
                                 exa                    -              0.8.0-1
                     firefox-firebug                    -              2.0.8-1
                   flattr-icon-theme                    -                1.3-2
                              freevo                    -             1.9.0-14
                            fswebcam                    -           20140113-1
               gambas3-gb-db-sqlite2                    -              3.9.2-4
                                gcc5                    -              5.4.0-1
                                 gdc                    -              6.2.1-2
                   gecko-mediaplayer                    -              1.0.9-3
                             ghc-mod                    -           5.8.0.0-35
                 gimp-plugin-mathmap                    -              1.3.5-8
                            gir-to-d                    -             0.11.0-1
                              gitlab                    -             10.1.1-2
                       gitlab-gitaly                    -             0.50.0-1
                             grafana                    -              4.5.2-1
                              grumpy                    -                0.1-2
                   hardening-wrapper                    -                 10-2
                haskell-cabal-helper                    -            0.7.3.0-2
                     haskell-ghc-mod                    -            5.8.0.0-9
                 haskell-haddock-api                    -             2.17.4-1
                       haskell-hlint                    -              2.0.8-8
                      haskell-pandoc                    -          1.19.2.1-53
             haskell-pandoc-citeproc                    -          0.10.4.1-48
             haskell-pandoc-crossref                    -           0.2.5.0-39
                       haskell-stack                    -             1.4.0-51
                    hdf5-cpp-fortran                    -      1.10.0_patch1-2
                               herqq                    -              1.0.0-4
                            hfsprogs                    -            332.25-15
                          ironpython                    -              2.7.5-3
                            kaa-base                    -              0.6.0-5
                          kaa-imlib2                    -              0.2.3-6
                        kaa-metadata                    -              0.7.7-5
                                 ldc                    -            1:1.3.0-1
                    letshelp-certbot                    -              0.6.0-2
                         libgcrypt11                    -              1.5.6-1
                          libgphobos                    -              6.2.1-2
                    libgphobos-devel                    -              6.2.1-2
                          liblphobos                    -            1:1.3.0-1
                           libphobos                    -          1:2.074.0-1
                     libphobos-devel                    -          1:2.074.0-1
                        libqinfinity                    -   0.5.2git20140901-3
                    libretro-blastem                    -                940-1
                libretro-mupen64plus                    -               4427-1
                    libretro-reicast                    -               2550-1
                    libretro-shaders                    -                587-1
                     libvirt-python3                    -              3.2.0-1
                         lxqt-common                    -             0.11.2-1
                            mantisbt                    -              1.3.0-2
                              mcelog                    -              1:153-1
                          mit-scheme                    -                9.2-1
                            moc-tray                    -                0.4-3
                          mustache-d                    -              0.1.3-2
                          newsbeuter                    -                2.9-8
                        noise-player                    -            0.4.0.3-1
                             nopaste                    -                0.1-4
                                opam                    -              1.2.2-4
         openstack-guest-agents-unix                    -           1:1.39.1-1
                               opera                    -       48.0.2685.52-1
                             paxtest                    -             0.9.15-1
                    perl-test-simple                    -           1.302086-2
                               ponyc                    -             0.18.1-1
                              ppsspp                    -              1.4.2-2
                     ppsspp-headless                    -              1.4.2-2
                           ppsspp-qt                    -              1.4.2-2
                           pspshrink                    -              1.1.2-5
                                pulp                    -             11.0.2-1
                          purescript                    -            0.11.6-25
                               pypy3                    -              5.9.0-1
                    python-paramiko1                    -             1.16.0-3
                    python-py-bcrypt                    -                0.4-2
              python2-beautifulsoup3                    -              3.2.1-3
                    python2-geotypes                    -              0.7.0-7
                  python2-jsonrpclib                    -              0.1.7-2
                   python2-paramiko1                    -             1.16.0-3
                   python2-py-bcrypt                    -                0.4-2
             python2-pysqlite-legacy                    -              1.0.1-4
                    python2-xenstore                    -              0.0.2-4
                               qtemu                    -             1.0.5-11
                                qtfm                    -                5.9-3
                         qtscrobbler                    -               0.11-6
                            rblcheck                    -                1.5-3
                                 rkt                    -             1.29.0-1
                          rubyripper                    -             0.6.2-10
                            sensorfw                    -              0.9.4-1
                             shp2svg                    -              0.5.1-5
                               silly                    -              0.1.0-7
                              spring                    -              104.0-1
                              spyder                    -              3.1.4-2
                            sqlheavy                    -            1:0.1.1-1
                             sqlite2                    -             2.8.17-8
                   subsurface-marble                    -              4.6.4-1
                 sugar-activity-read                    -                118-1
                           synce-kde                    -               0.16-5
                        taskjuggler3                    -             3.5.0-13
                             topbeat                    -              1.3.1-1
                        ttf-overpass                    -                2.1-2
                               unifi                    -             5.4.16-1
                         urbanterror                    -            2:4.3.2-2
                    urbanterror-data                    -            2:4.3.2-2
                   vagrant-substrate                    -        726.d082972-2
                              vdrift                    -         2014.10.20-8
                         vdrift-data                    -       2:2014.10.20-2
                                wbar                    -              2.3.4-4
                  xe-guest-utilities                    -              6.2.0-2
                            xenstore                    -              6.2.0-2
                               xmind                    -             3.6.51-1
:: Different sync package(s) in repository core i686
                                 acl             2.2.52-4             2.2.52-3
                                attr             2.4.47-3             2.4.47-2
                            autoconf               2.69-4               2.69-4
                            automake             1.15.1-1             1.15.1-1
              ca-certificates-cacert           20140824-4           20140824-4
                           coreutils               8.28-1               8.27-1
                          cryptsetup              1.7.5-2              1.7.5-1
                                curl             7.56.1-1             7.55.1-2
                                dbus             1.12.0-1            1.10.24-1
                           dbus-docs             1.12.0-1            1.10.24-1
                       device-mapper           2.02.176-1           2.02.174-1
                           e2fsprogs             1.43.7-1             1.43.5-1
                               expat              2.2.4-1              2.2.3-1
                                file               5.32-1               5.31-1
                                 gcc              7.2.0-3              7.2.0-2
                             gcc-ada              7.2.0-3              7.2.0-2
                         gcc-fortran              7.2.0-3              7.2.0-2
                              gcc-go              7.2.0-3              7.2.0-2
                            gcc-libs              7.2.0-3              7.2.0-2
                            gcc-objc              7.2.0-3              7.2.0-2
                               glib2             2.54.2-2             2.54.1-1
                          glib2-docs             2.54.2-2             2.54.1-1
                               glibc               2.26-6               2.26-4
                              gnutls             3.5.16-1             3.5.15-1
                               hwids           20170715-1           20170715-1
                                 icu               59.1-2               59.1-1
                            iproute2             4.13.0-1             4.12.0-2
                        iproute2-doc             4.13.0-1             4.12.0-2
                                krb5             1.15.2-1             1.15.1-1
                           libgcrypt              1.8.1-1              1.8.0-1
                          libsystemd             235.38-1              235.0-1
                       libutil-linux               2.31-1             2.30.1-2
                   linux-api-headers             4.12.7-1             4.10.1-1
                                lvm2           2.02.176-1           2.02.174-1
                          mkinitcpio                 24-2                 23-2
                                nano              2.8.7-1              2.8.6-1
                              netctl               1.14-1               1.13-2
                             openssl            1.1.0.g-1            1.1.0.f-1
                            pciutils              3.5.5-1              3.5.4-1
                                perl             5.26.1-1             5.26.0-4
                              s-nail             14.9.5-1             14.9.3-1
                              sqlite             3.21.0-1             3.20.1-1
                     sqlite-analyzer             3.21.0-1             3.20.1-1
                          sqlite-doc             3.21.0-1             3.20.1-1
                          sqlite-tcl             3.21.0-1             3.20.1-1
                  systemd-sysvcompat             235.38-1              235.0-1
                             texinfo                6.5-1                6.4-1
                              tzdata              2017c-1              2017b-1
                 archlinux32-keyring                    -           20171113-1
      archlinux32-keyring-transition                    -           20170628-1
:: Different sync package(s) in repository extra i686
                                blas              3.7.1-2              3.7.1-1
                              breeze             5.11.3-1             5.11.2-1
                         breeze-grub             5.11.3-1             5.11.2-1
                         breeze-kde4             5.11.3-1             5.11.2-1
                               cairo             1.15.8-2            1.14.10-1
                               cblas              3.7.1-2              3.7.1-1
                            cervisia            17.08.1-1            17.08.2-1
                            chromium       62.0.3202.89-1       62.0.3202.75-1
                            composer              1.5.1-1              1.5.1-1
                                cups              2.2.6-1              2.2.5-1
                       docbook-dsssl               1.79-5               1.79-5
                        docbook-sgml                4.5-5                4.5-5
                      docbook-sgml31                3.1-2                3.1-2
                         docbook-xml                4.5-6                4.5-6
                         docbook-xsl             1.79.2-3             1.79.2-3
                                 feh             2.22.2-1               2.21-1
                          fontconfig             2.12.6-1             2.12.5-1
                           freetype2              2.8.1-1                2.8-2
                     freetype2-demos              2.8.1-1                2.8-2
                      freetype2-docs              2.8.1-1                    -
                               gajim             0.16.8-2             0.16.8-2
                                 git             2.15.0-1             2.14.2-1
                              gthumb              3.5.4-1              3.5.3-1
                             gtk-doc   1.26+10+g01844e7-1   1.26+10+g01844e7-1
               gtk-update-icon-cache            3.22.26-1            3.22.25-1
                                gtk3            3.22.26-1            3.22.25-1
                 gtk3-print-backends            3.22.26-1            3.22.25-1
                            harfbuzz              1.6.3-1              1.5.0-1
                        harfbuzz-icu              1.6.3-1              1.5.0-1
                         imagemagick           6.9.9.22-1           6.9.9.21-1
                     imagemagick-doc           6.9.9.22-1           6.9.9.21-1
                   kactivitymanagerd             5.11.3-1             5.11.2-1
               kde-applications-meta              17.08-1              17.08-1
                       kde-cli-tools             5.11.3-1             5.11.2-1
                      kde-gtk-config             5.11.3-1             5.11.2-1
           kde-meta-kdeaccessibility              17.08-1              17.08-1
                   kde-meta-kdeadmin              17.08-1              17.08-1
                    kde-meta-kdebase              17.08-1              17.08-1
                     kde-meta-kdeedu              17.08-1              17.08-1
                   kde-meta-kdegames              17.08-1              17.08-1
                kde-meta-kdegraphics              17.08-1              17.08-1
              kde-meta-kdemultimedia              17.08-1              17.08-1
                 kde-meta-kdenetwork              17.08-1              17.08-1
                     kde-meta-kdepim              17.08-1              17.08-1
                     kde-meta-kdesdk              17.08-1              17.08-1
                   kde-meta-kdeutils              17.08-1              17.08-1
                  kde-meta-kdewebdev              17.08-1              17.08-1
                         kdecoration             5.11.3-1             5.11.2-1
                    kdeplasma-addons             5.11.3-1             5.11.2-1
                                 kdf            17.08.2-1            17.08.1-1
                             kfloppy            17.08.2-1            17.08.1-1
                            khotkeys             5.11.3-1             5.11.2-1
                         kinfocenter             5.11.3-1             5.11.2-1
                           kmenuedit             5.11.3-1             5.11.2-1
                          knetattach             5.11.3-1             5.11.2-1
                               krita            3.3.2.1-1              3.3.1-2
                             kscreen             5.11.3-1             5.11.2-1
                       kscreenlocker             5.11.3-1             5.11.2-1
                           ksysguard             5.11.3-1             5.11.2-1
                           kuiserver             5.11.3-1             5.11.2-1
                         kwallet-pam             5.11.3-1             5.11.2-1
                kwayland-integration             5.11.3-1             5.11.2-1
                                kwin             5.11.3-1             5.11.2-1
                              lapack              3.7.1-2              3.7.1-1
                          lapack-doc              3.7.1-2                    -
                             lapacke              3.7.1-2              3.7.1-1
                              libclc  0.2.0+374+0c31bd5-1  0.2.0+360+3ab9165-1
                          libcryptui 3.12.2+24+gd5e5bc5-13.12.2+24+gd5e5bc59-1
                             libcups              2.2.6-1              2.2.5-1
                              libdrm             2.4.88-1             2.4.84-1
                          libkscreen             5.11.3-1             5.11.2-1
                        libksysguard             5.11.3-1             5.11.2-1
                        libpciaccess               0.14-1             0.13.5-1
                              libpng             1.6.34-2             1.6.30-1
                             libtiff              4.0.8-2              4.0.8-1
                   libva-mesa-driver             17.2.4-1             17.2.2-1
                            libvisio              0.1.6-1              0.1.5-4
                         libwbclient              4.7.1-1              4.7.0-1
                           libxfont2              2.0.2-1              2.0.1-1
                            man2html              3.0.1-5              3.0.1-5
                              maxima             5.41.0-2             5.40.0-3
                                mdds              1.3.0-1              1.2.3-1
                           memcached              1.5.3-1              1.5.1-1
                           mercurial              4.3.3-1              4.4.1-1
                                mesa             17.2.4-1             17.2.2-1
                          mesa-vdpau             17.2.4-1             17.2.2-1
                               milou             5.11.3-1             5.11.2-1
                      mkvtoolnix-cli             17.0.0-1             17.0.0-2
                      mkvtoolnix-gui             17.0.0-1             17.0.0-2
                             mutagen               1.39-1               1.38-1
              network-manager-applet              1.8.6-3              1.8.4-2
                nm-connection-editor              1.8.6-3              1.8.4-2
                         opencl-mesa             17.2.4-1             17.2.2-1
                              opencv              3.3.1-2              3.3.1-1
                      opencv-samples              3.3.1-2              3.3.1-1
                              oxygen             5.11.3-1             5.11.2-1
                         oxygen-kde4             5.11.3-1             5.11.2-1
                               pango            1.40.13-2            1.40.11-1
                      plasma-desktop             5.11.3-1             5.11.2-1
                  plasma-integration             5.11.3-1             5.11.2-1
                           plasma-nm             5.11.3-1             5.11.2-1
                           plasma-pa             5.11.3-1             5.11.2-1
                        plasma-vault             5.11.3-1             5.11.2-1
              plasma-wayland-session             5.11.3-1             5.11.2-1
                    plasma-workspace             5.11.3-1             5.11.2-1
                    polkit-kde-agent             5.11.3-1             5.11.2-1
                        poppler-data              0.4.8-1              0.4.8-1
                          powerdevil             5.11.3-1             5.11.2-1
                            protobuf              3.4.1-1              3.3.2-1
                   publicsuffix-list20170803.619.e8c69a6-120170804.619.e8c69a6-1
                              pyalpm              0.8.2-2              0.8.1-2
                        pyqt5-common              5.9.1-1                5.9-2
                              python              3.6.3-1              3.6.2-1
                        python-attrs             17.3.0-1             17.2.0-1
                    python-hyperlink             17.3.1-1             17.3.1-1
                         python-idna                2.6-1                2.6-1
                      python-mutagen               1.39-1               1.38-1
                        python-numpy             1.13.3-1             1.13.1-2
                     python-protobuf              3.4.1-1              3.3.2-1
                        python-pyqt5              5.9.1-1                5.9-2
                     python-requests             2.18.4-1             2.18.4-1
                   python-setuptools           1:36.6.0-1           1:36.5.0-1
                          python-sip             4.19.5-1             4.19.3-1
                      python-twisted             17.9.0-1             17.1.0-1
                      python-urllib3               1.22-1               1.22-1
                  python-urllib3-doc               1.22-1               1.22-1
                       python2-attrs             17.3.0-1             17.2.0-1
                   python2-hyperlink             17.3.1-1             17.3.1-1
                        python2-idna                2.6-1                2.6-1
                       python2-numpy             1.13.3-1             1.13.1-2
                    python2-protobuf              3.4.1-1              3.3.2-1
                       python2-pyqt5              5.9.1-1                5.9-2
                    python2-requests             2.18.4-1             2.18.4-1
                       python2-scour               0.36-1               0.36-1
                  python2-setuptools           1:36.6.0-1           1:36.5.0-1
                         python2-sip             4.19.5-1             4.19.3-1
                     python2-twisted             17.9.0-1             17.1.0-1
                     python2-urllib3               1.22-1               1.22-1
                               rsync              3.1.2-8              3.1.2-5
                               samba              4.7.1-1              4.7.0-1
                                sbcl              1.4.0-1             1.3.20-1
                               scour               0.36-1               0.36-1
                         sgml-common              0.6.3-5              0.6.3-5
                       smartmontools                6.6-1                6.5-2
                           smbclient              4.7.1-1              4.7.0-1
                              spglib             1.10.1-2             1.10.1-1
                              strace               4.19-1               4.18-1
                      systemsettings             5.11.3-1             5.11.2-2
                  telepathy-kde-meta              17.08-1              17.08-1
                        vulkan-intel             17.2.4-1             17.2.2-1
                       vulkan-radeon             17.2.4-1             17.2.2-1
                            wxmaxima            17.10.1-1            17.05.1-1
                       xorg-bdftopcf                1.1-1              1.0.5-1
                         xorg-server             1.19.5-1             1.19.3-3
                  xorg-server-common             1.19.5-1             1.19.3-3
                   xorg-server-devel             1.19.5-1             1.19.3-3
                    xorg-server-xdmx             1.19.5-1             1.19.3-3
                  xorg-server-xephyr             1.19.5-1             1.19.3-3
                   xorg-server-xnest             1.19.5-1             1.19.3-3
                    xorg-server-xvfb             1.19.5-1             1.19.3-3
                xorg-server-xwayland             1.19.5-1             1.19.3-3
                           archiso32                    -                 31-4
                            audacity                    -              2.1.3-1
                                 boo                    -            0.9.4.9-4
                              fsharp                    -             4.1.18-1
                        gettext-mono                    -           0.18.3.1-2
                             gnucash                    -             2.6.16-3
                        gnucash-docs                    -             2.6.16-1
                          goffice0.8                    -             0.8.17-3
                     gtk-sharp-beans                    -             2.14.0-3
                             hdf5_18                    -             1.8.18-1
                           katepart4                    -             4.14.3-6
               kdeaccessibility-kmag                    -            17.04.1-1
         kdeaccessibility-kmousetool                    -            17.04.1-1
                kdegames-kgoldrunner                    -            17.04.1-1
                       kdegames-kigo                    -            17.04.1-1
                   kdegames-konquest                    -            17.04.1-1
                   kdegames-kreversi                    -            17.04.1-1
                 kdegames-ksnakeduel                    -            17.04.1-1
                 kdegames-kspaceduel                    -            17.04.1-1
                    kdegames-ksudoku                    -            17.04.1-1
                    kdegames-kubrick                    -            17.04.1-1
                      kdegames-lskat                    -            17.04.1-1
                            kirigami                    -              1.1.0-2
                        konsolepart4                    -             4.14.3-8
                             lesstif                    -             0.95.2-6
           libkdeaccessibilityclient                    -              0.1.1-2
                       libqzeitgeist                    -              0.8.0-6
                   libtracker-sparql                    -             1.12.1-1
                            libxfont                    -              1.5.3-1
                          mono-basic                    -                4.6-2
                       mono-debugger                    -               2.10-3
                           mono-upnp                    -              0.1.2-2
                       mono-zeroconf                    -              0.9.0-4
                         monodevelop                    -         6.2.0.1778-2
                       qt5-webkit-ng                    -                tp5-4
                texlive-genericextra                    -         2016.43605-1
                     texlive-langcjk                    -             2014.0-1
                  texlive-plainextra                    -         2016.43137-1
                             valadoc                    -           1:0.36.0-2
                           webkitgtk                    -             2.4.11-6
                          webkitgtk2                    -             2.4.11-6
                               wxgtk                    -            3.0.3.1-1
                               xbase                    -              2.0.0-4
                                 xsp                    -                4.4-2
                            yp-tools                    -               2.14-3
                           ypbind-mt                    -               1.38-1
                              ypserv                    -               2.31-2
[Manjaro32] Getting rid of 32bit Manjaro based on Archlinux
#27
I thought we had two votes already where option for dropping 32bit completely won so our devs will be relieved from some burden.
Now I see all devs working on restoring 32bit functionality and applying resources for it (https://lists.manjaro.org/pipermail/manjaro-mirrors/Week-of-Mon-20171113/000046.html).
Am I missing something?
#28
Official i686 support has been dropped from Manjaro.
I started my own sub-project to build Manjaro’s packages for my own i686 machines.
We’ll see what happens next.
#29
Is it not always this way with the votes? :wink: :smiling_imp:
Seriously: It looks like Philip got an idea how to make it work and tries it now. It seems still to be at a point where it can be canceled.
#30
Divine intervention?
#31
old panasonic toughbook cf29 (2004) xfce 32 installed
saw yesterday inside the update 3d, just after removing manjaro and installed archbang… :cry:
restored today an image of may 2016…
after some time here I’m again
so basically, if I understand well I’ve just to ad the manjaro32 repos to pacman.conf and keep the others?
but I’m leaving after a week for a month and I can’t test the switch to arclinux32, maybe when I come back…
#32
I would recommend to try what Philip writes
His and Jonathon’s approaches are two different approaches.
#33
Only how the management is may differ. Building the package can be done as intended. I only try to make it better as I had a lot of issues with catching up with Arch. That is why boxit exists, to decide when it is right to sync from Arch and therefore update the whole distro.
#34
pacman -Su ndiswrapper-utils
pacman -Rncs linux413
#35
interested in this for an old intel atom netbook, any plans to offer an iso in future?
Or what is the easiest way to install this?
I guess, download the last manjaro 32 bit iso and then swap the repos?
Good work, keep it up, and thank you for doing this!
#36
The latest i686 ISOs are https://sourceforge.net/projects/manjarolinux/files/release/17.0.6/
For a how-to, please, read this topic carefully! There are currently two approaches.
#37
right now jonathon way seems to wok better for me, at least for my understanding
and capability…
removed ndiswrapper-utils and linux413
btw thanks to everybody’s effort for keeping my manjaro32 going on :smiley:
#38
The switch went well with the above commands on a newly installed bspwm system.
I was asked to remove archlinux32-keyring-transition and install archlinux32-keyring- instead what I did.
#39
You had one job :worried: damned if I know which way I need to migrate. manjaro32 xperimental32_2 x32 branches archlinux32 this is a complete clusterfuck :worried:
#40
This is a topic for Development. If you need some “pastoral care”, please, post in Newbie Corner. If you want to voice some rants post in Off-Topic.
