Interrupted system update left stale .old libraries on disk, causing broken binary links to outdated .so versions
I’ve ran a big update on my KDE Manjaro today via pacman GUI and it crashed. I then removed the /var/lib/pacman/db.lck file and ran sudo pacman -Syu. Also, apparently, the update is somehow related to the 6.14 → 6.15 kernel update, because I wasn’t able to complete it on 6.14 and had to boot 6.15.
After updating all the packages and rebooting, I noticed that telegram-desktop and spectacle are not launching because spectacle: error while loading shared libraries: libx265.so.212: cannot open shared object file: No such file or directory.
Latest x265 provides libx265.so.215.
I then ran find /usr/bin /usr/lib -type f -exec ldd {} + 2>/dev/null | grep 'not found' to find out what else is wrong and it output a bunch of other libs that are missing (?).
So is it something that I’ve messed up, is it a problem with some packages not being updated against the latest x265, or should I just wait for more updates?
Full system info
  Kernel: 6.15.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64
    root=UUID=ac37aa3b-2733-4f56-bcac-8fe141ddda25 rw radeon.si_support=0
    amdgpu.si_support=1 radeon.cik_support=0 amdgpu.cik_support=1 quiet
    splash resume=UUID=3598205a-fe30-4702-acdf-ba411c83570e
    udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.15.0
  Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
    UEFI: American Megatrends v: 3205 date: 08/14/2023
  Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
    status: discharging
  System RAM: total: 64 GiB available: 62.7 GiB used: 17.37 GiB (27.7%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 3600 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF3600C16D4/16GX serial: <filter>
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3601 min/max: 567/4955 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3601 2: 3601 3: 3601
    4: 3601 5: 3601 6: 3601 7: 3601 8: 3601 9: 3601 10: 3601 11: 3601 12: 3601
    13: 3601 14: 3601 15: 3601 16: 3601 17: 3601 18: 3601 19: 3601 20: 3601
    21: 3601 22: 3601 23: 3601 24: 3601 bogomips: 177607
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
    7800 XT] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-3
    code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
    empty: HDMI-A-1,HDMI-A-2,Writeback-1 bus-ID: 0d:00.0 chip-ID: 1002:747e
    class-ID: 0300
  Device-2: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 17ef:4831
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4520x1920 s-dpi: 96 s-size: 1195x508mm (47.05x20.00")
    s-diag: 1298mm (51.12")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,bottom-r
    model: Dell AW3423DWF serial: <filter> built: 2024 res: N/A dpi: 109
    gamma: 1.2 chroma: red: x: 0.710 y: 0.282 green: x: 0.243 y: 0.718 blue:
    x: 0.145 y: 0.051 white: x: 0.314 y: 0.329 size: 800x337mm (31.5x13.27")
    diag: 868mm (34.2") modes: 3440x1440, 2560x1440, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: DP-2 mapped: DisplayPort-1 pos: top-left model: Dell P2319H
    serial: <filter> built: 2021 res: mode: 1920x1080 hz: 60
    scale: 177% (0.5625) to: 1080x1920 dpi: 96 gamma: 1.2 chroma: red:
    x: 0.651 y: 0.337 green: x: 0.318 y: 0.612 blue: x: 0.149 y: 0.063 white:
    x: 0.314 y: 0.329 size: 509x286mm (20.04x11.26") diag: 584mm (23")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900,
    1280x800, 1152x864, 1280x720, 1024x768, 800x600, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
    navi32 LLVM 20.1.6 DRM 3.63 6.15.3-1-MANJARO) device-ID: 1002:747e
    memory: 15.62 GiB unified: no
  API: Vulkan v: 1.4.313 layers: 11 device: 0 type: discrete-gpu
    name: AMD Radeon RX 7800 XT driver: amd v: 2025.Q2.1 (LLPC)
    device-ID: 1002:747e surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 0d:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
  Device-4: Blue Microphones Yeti Nano
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-3:4 chip-ID: b58e:0005 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.15.3-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
    chip-ID: 10ec:818b class-ID: 0280
  IF: wlp6s0 state: down mac: <filter>
  Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-195eb586929b state: down mac: <filter>
  IF-ID-2: br-d1649514334b state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-3: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-4: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> virtual: nodad scope: link
  IF-ID-5: veth103344d state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-6: veth15bfde8 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-7: veth1962795 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-8: veth3834380 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-9: veth47d5fad state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-10: veth53908b8 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-11: veth649fe36 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-12: veth791ebf1 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-13: veth8a610a2 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-14: veth9031361 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-15: vetha394e0c state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-16: vetha9ee44b state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Info: services: NetworkManager, nginx, sshd, systemd-timesyncd
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0b05:190e
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 sub-v: d922 hci-v: 10 rev: dfc6 class-ID: 6c0104
  Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
    link-mode: peripheral accept service-classes: rendering, capturing, audio,
    telephony
  Local Storage: total: 1.82 TiB used: 716.25 GiB (38.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 40.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 42.9 C
    scheme: GPT
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
    used: 716.23 GiB (79.0%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:3
    label: N/A uuid: ac37aa3b-2733-4f56-bcac-8fe141ddda25
    used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2 label: N/A
    uuid: 1867-5BAC
  ID-1: swap-1 type: partition size: 8.8 GiB used: 26.1 MiB (0.3%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:4 label: swap
    uuid: 3598205a-fe30-4702-acdf-ba411c83570e
  ID-1: /dev/nvme0n1p1 maj-min: 259:5 size: 100 MiB fs: vfat label: N/A
    uuid: 0432-225D
  ID-2: /dev/nvme0n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:7 size: 930.85 GiB fs: ntfs label: N/A
    uuid: 3C1E37E81E379A3A
  ID-4: /dev/nvme0n1p4 maj-min: 259:8 size: 563 MiB fs: ntfs label: N/A
    uuid: 4458F44258F433F0
  Device-1: 1-3:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
  Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
    serial: <filter>
  Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-7.1:5 info: Logitech Logi Bolt Receiver
    type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 98mA chip-ID: 046d:c548 class-ID: 0300
  Device-2: 1-7.2:6 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Lenovo FHD Webcam type: video,audio
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 256mA
    chip-ID: 17ef:4831 class-ID: 0102 serial: <filter>
  Hub-5: 3-2:3 info: Realtek USB2.1 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5409
  Device-1: 3-2.5:5 info: Alienware HID Device type: HID
    chip-ID: 187c:100e class-ID: 0300
  Device-2: 3-3:4 info: Blue Microphones Yeti Nano type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    chip-ID: b58e:0005 class-ID: 0300 serial: <filter>
  Hub-6: 3-4:6 info: Realtek 4-Port USB 2.0 Hub ports: 4 rev: 2.1
  Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-8: 4-2:2 info: Realtek USB3.2 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0409
  Hub-9: 4-4:3 info: Realtek 4-Port USB 3.0 Hub ports: 2 rev: 3.1
  System Temperatures: cpu: 42.0 C mobo: 34.0 C gpu: amdgpu temp: 58.0 C
    mem: 72.0 C
  Fan Speeds (rpm): fan-1: 1136 fan-2: 727 fan-3: 554 fan-4: 0 fan-5: 0
    fan-6: 0 fan-7: 0 gpu: amdgpu fan: 0
  Packages: 2041 pm: pacman pkgs: 1991 libs: 473 tools: pamac pm: flatpak
    pkgs: 50
    1: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    2: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    4: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    5: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    7: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    8: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 569
  1: cpu: 31.4% command: steam pid: 336723 mem: 352.1 MiB (0.5%)
  2: cpu: 9.5% command: zen pid: 6756 mem: 941.4 MiB (1.4%)
  3: cpu: 7.8% command: zen pid: 496900 mem: 459.9 MiB (0.7%)
  4: cpu: 5.5% command: zen pid: 8555 mem: 1332.1 MiB (2.0%)
  5: cpu: 3.9% command: coolercontrold pid: 900 mem: 34.6 MiB (0.0%)
  Memory top: 5 of 569
  1: mem: 1332.1 MiB (2.0%) command: zen pid: 8555 cpu: 5.5%
  2: mem: 1132.6 MiB (1.7%) command: Telegram pid: 18409 cpu: 0.7%
  3: mem: 941.4 MiB (1.4%) command: zen pid: 6756 cpu: 9.5%
  4: mem: 899.3 MiB (1.4%) command: plasmashell pid: 5880 cpu: 0.2%
  5: mem: 743.0 MiB (1.1%) command: exe pid: 7639 cpu: 2.7%
  Processes: 569 Power: uptime: 5h 42m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.06 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.6 gcc: 15.1.1 alt: 13/14/14 Shell: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.38
Thank you.
I wonder if perhaps Spectacle didn’t upgrade (non-synchronised mirror?)
It should be at 1:6.3.5-1
Can’t reproduce. Sounds like you’re in an unsupported partial upgrade state. As @beermad mentioned, your mirror(s) could be out of date. See Pacman-mirrors - Manjaro
Interesting. You run the pamac (NOT PACMAN) GUI, it crashed. Usually it runs in the background since the update process is a systemd service. Now you removed the db.lck and ran pacman in parallel with pamac. Well done :+1: We can now speculate about what happened.
Possible scenario: If one has just booted and runs sudo pacman -Syu, it may say the db.lck file is present–because Pamac is running. Just wait until Pamac is done. :wink:
My version is exactly that
I have tried refreshing the mirrors, it doesn’t help
My guess (which could be wrong) is you have some foreign package installed–possibly from the AUR. This has happened before.
Please post the output of:
pacman -Qm
Please edit your topic title to be clear and concise about the issue you need help with. The current title is both inaccurate and misleading. No one else can reproduce the issue as stated.
Please see:
Unrelated to your issue, but I noticed your BIOS can (should?) be updated.
https://rog.asus.com/ca-en/motherboards/rog-strix/rog-strix-b550-f-gaming-model/helpdesk_bios/l
Thank you and sorry about the format. I don’t really know which title would be more appropriate but I’ve ran scanelf -r /usr/lib /usr/bin /usr/libexec -n -s NEEDED 2>/dev/null | grep libx265.so.212 and found that there were two .old libs (libheif and libavcodec) so I removed them, then did sudo ldconfig and it worked. There are a bunch more missing links though and I’m trying to figure out the correct way to solve this without reinstalling the system
Output for pacman -Qm
7-zip 24.09-1
Codux 15.15.0-1
attica-qt4 0.4.2-7
automoc4 0.9.88-9
chiaki 2.2.0-2
coolercontrol 2.1.0-1
coolercontrol-liqctld 2.1.0-1
coolercontrold 2.2.1-1
cryptkeeper 0.9.5-6
discord-update-skip-git r12.5f16a22-1
docker-backup 0.2.3-1
electron29-bin 29.4.6-2
gcc13 13.3.1+r432+gfc8bd63119c0-3
gcc13-libs 13.3.1+r432+gfc8bd63119c0-3
gconf 3.2.6+11+g07808097-13
gtkglext 1.2.0-20
kdelibs4support 5.116.0-2
kdesignerplugin 5.116.0-2
kemoticons 5.116.0-2
kencfs-plasma 2.0.3a-1
kfilemetadata5 5.116.0-2
khotkeys 5.27.11-1
khtml 5.115.0-1
kirigami-addons5 0.11.0-8
kjs 5.115.0-1
kpeople5 5.116.0-1
kpeoplevcard 0.1-2
kquickcharts5 5.115.0-1
krunner5 5.115.0-4
ksanecore5 24.08.3-1
lib32-libva-vdpau-driver 0.7.4-8
libavresample 4.4.1-1
libdbusmenu-qt4 0.9.3+16.04.20160218-1
libkcddb5 24.05.2-1
libksane5 24.08.3-1
libva-vdpau-driver 0.7.4-7
libxcomp 3.5.99.27-3
lug-helper 1:3.11-1
manjaro-hotfixes 2024.1-2
manjaro-settings-manager-kcm 0.5.7-21
minecraft-launcher 1:2.1.3-3
mkvextract-gtk 0.9.6-1
modemmanager-qt5 5.116.0-1
neofetch 7.1.0-2
nodejs-less 4.2.2-1
nx-x11 3.5.99.27-3
nxagent 3.5.99.27-3
ocenaudio-bin 3.14.11-1
opencollada 1:1.6.68-3
phonon-qt4 4.10.3-1
pipewire-module-xrdp 0.2-1
plasma-simplemenu 1.0.12-1
polkit-qt4 0.112.0+git20180107-2
postman-bin 11.49.4-1
python-apscheduler 3.11.0-1
python-async-timeout 5.0.1-1
python-dataclass-wizard 0.32.0-1
python-manjaro-sdk 1:0.1.1-1
python-pyrsistent 0.20.0-7
python-shiboken2 5.15.16-3
python2 2.7.18-11
qgpgme-qt5 1.23.2-7
qjson 0.9.0-4
qqc2-desktop-style5 5.116.1-1
qt4 4.8.7-38
qt5-datavis3d 5.15.16-3
redis 7.2.5-1
reiserfsprogs 3.6.27-5
simplescreenrecorder 0.4.4-3
spectre-meltdown-checker 0.46+26+gbd0c7c9-1
spotify 1:1.2.63.394-1
syncthing-gtk 0.9.4.5-1
systemd-kcm 1.2.1-8
teamviewer 15.66.5-1
ttf-harmonyos-sans 2024.06.19-3
v86d 0.1.10-13
vesktop 1.5.7-1
vkbasalt 0.3.2.10-1
vkbasalt-cli 3.1.1-3
web-installer-url-handler 2.3-1
x2godesktopsharing 3.2.0.0-1
x2goserver 4.1.0.6-1
What worries me is this:
A bunch of broken links
        libabsl_log_initialize.so.2501.0.0 => not found
        libabsl_die_if_null.so.2501.0.0 => not found
        libabsl_statusor.so.2501.0.0 => not found
        libabsl_log_internal_check_op.so.2501.0.0 => not found
        libabsl_log_internal_conditions.so.2501.0.0 => not found
        libabsl_log_internal_message.so.2501.0.0 => not found
        libabsl_log_internal_nullguard.so.2501.0.0 => not found
        libabsl_raw_hash_set.so.2501.0.0 => not found
        libabsl_hash.so.2501.0.0 => not found
        libabsl_status.so.2501.0.0 => not found
        libabsl_str_format_internal.so.2501.0.0 => not found
        libabsl_synchronization.so.2501.0.0 => not found
        libabsl_strings.so.2501.0.0 => not found
        libabsl_throw_delegate.so.2501.0.0 => not found
        libabsl_raw_logging_internal.so.2501.0.0 => not found
        libabsl_cord.so.2501.0.0 => not found
        libabsl_cordz_info.so.2501.0.0 => not found
        libabsl_cord_internal.so.2501.0.0 => not found
        libabsl_time.so.2501.0.0 => not found
        libabsl_time_zone.so.2501.0.0 => not found
        libabsl_spinlock_wait.so.2501.0.0 => not found
        libpackagekitqt6.so.1 => not found
        libxml2.so.2 => not found
        libell.so.0 => not found
        libgcr-base-3.so.1 => not found
        librrd.so.8 => not found
        libavcodec.so.60 => not found
        libavutil.so.58 => not found
        libhspell.so.0 => not found
        libaspell.so.15 => not found
        libvoikko.so.1 => not found
        libnuspell.so.5 => not found
        libmozsandbox.so => not found
        libgkcodecs.so => not found
        liblgpllibs.so => not found
        libmozsqlite3.so => not found
        libmozgtk.so => not found
        libmozwayland.so => not found
        libmozavutil.so => not found
        ntdll.so => not found
        win32u.so => not found
        libQt63DAnimation.so.6 => not found
        libQt63DCore.so.6 => not found
        libQt63DLogic.so.6 => not found
        libQt63DInput.so.6 => not found
        libQt6StateMachine.so.6 => not found
        libQt63DExtras.so.6 => not found
        libQt6Graphs.so.6 => not found
        libQt6SerialBus.so.6 => not found
        libQt6DataVisualization.so.6 => not found
        libQt6Location.so.6 => not found
        libQt6SerialPort.so.6 => not found
        libQt6GraphsWidgets.so.6 => not found
        libQt6RemoteObjects.so.6 => not found
        libQt6Scxml.so.6 => not found
        libQt6HttpServer.so.6 => not found
        libQt63DRender.so.6 => not found
        libQt6NetworkAuth.so.6 => not found
        libQt5Bluetooth.so.5 => not found
        libQt5Quick3D.so.5 => not found
        libQt5Nfc.so.5 => not found
        libwpg-0.3.so.3 => not found
        libmythes-1.2.so.0 => not found
        libjawt.so => not found
        libCoinMP.so.1 => not found
        libClpSolver.so.1 => not found
        libpackagekitqt5.so.1 => not found
        libcuda.so.1 => not found
        libucc.so.1 => not found
        libamdhip64.so.6 => not found
        libR.so => not found
        libLLVM.so.19.1 => not found
        libvtkFiltersTexture.so.1 => not found
        libvtkIOExport.so.1 => not found
        libvtkIOGeometry.so.1 => not found
        libvtkIOPLY.so.1 => not found
        libvtkInteractionStyle.so.1 => not found
        libvtkRenderingLOD.so.1 => not found
        libvtkRenderingOpenGL2.so.1 => not found
        libvtkRenderingFreeType.so.1 => not found
        libvtkIOCore.so.1 => not found
        libvtkIOImage.so.1 => not found
        libvtkImagingCore.so.1 => not found
        libvtkRenderingCore.so.1 => not found
        libvtkFiltersSources.so.1 => not found
        libvtkFiltersGeneral.so.1 => not found
        libvtkFiltersCore.so.1 => not found
        libvtkCommonExecutionModel.so.1 => not found
        libvtkCommonDataModel.so.1 => not found
        libvtkCommonTransforms.so.1 => not found
        libvtkCommonMath.so.1 => not found
        libvtkCommonCore.so.1 => not found
        libvtksys.so.1 => not found
        libJudy.so.1 => not found
        libcrack.so.2 => not found
        libfwupdplugin.so => not found
        libcbor.so.0.11 => not found
        libgcr-ui-3.so.1 => not found
        libopenslide.so.1 => not found
        libhd.so.23 => not found
        libspeechd.so.2 => not found
        libflite_cmu_us_kal16.so.1 => not found
        libflite.so.1 => not found
        libkworkspace5.so.5 => not found
        libappimage.so.1.0 => not found
        libsybdb.so.5 => not found
        libreplace-private-samba.so => not found
        libgenrand-private-samba.so => not found
        libsamba-debug-private-samba.so => not found
        libsecrets3-private-samba.so => not found
        libsamba-security-private-samba.so => not found
        libsamba3-util-private-samba.so => not found
        libgfapi.so.0 => not found
        libgladeui-2.so.13 => not found
        libao.so.4 => not found
        libwmflite-0.2.so.7 => not found
        libuhdr.so.1 => not found
        libqrcodegencpp.so.1 => not found
        libnma-gtk4.so.0 => not found
        libtiger.so.5 => not found
        libSDL_image-1.2.so.0 => not found
        libSDL-1.2.so.0 => not found
        libaribb25.so.0 => not found
        liblirc_client.so.0 => not found
        libprojectM.so.3 => not found
        libgoom2.so.0 => not found
        libnfs.so.16.2.0 => not found
        libliveMedia.so.116 => not found
        libgroupsock.so.30 => not found
        libBasicUsageEnvironment.so.2 => not found
        libUsageEnvironment.so.3 => not found
        libibmad.so.5 => not found
        libibumad.so.3 => not found
        libibverbs.so.1 => not found
        libnvidia-ml.so.1 => not found
        libmlx5.so.1 => not found
        librdmacm.so.1 => not found
        libscim-1.0.so.8 => not found
        libjvm.so => not found
        libffado.so.2 => not found
        libsystemd-shared-257.5-3.so => not found
        libsystemd-shared-257.6-1.so => not found
        libgpgmepp.so.6 => not found
        libgpgme.so.11 => not found
        liblitehtml.so.0 => not found
        libgps.so.31 => not found
        libmms.so.0 => not found
        libKF6Plotting.so.6 => not found
        libqt6keychain.so.1 => not found
Nothing stands out that should cause a problem with your reported issue. At least that’s ruled out. However, that means I’m at a complete loss. There is absolutely no reason your reported problem would happen if you are fully up to date with spectacle 1:6.3.5-1 and x265 4.1-1 installed.
While not directly related to your issue: Many of the packages in that aforementioned list are no longer in the repos or the AUR.
These packages were dropped from the Manjaro repos a long time ago. Remove them regardless:
  • manjaro-hotfixes
  • manjaro-settings-manager-kcm
  • spectre-meltdown-checker
  • v86d
  • web-installer-url-handler
After that, you can determine which other packages are unneeded. I know quite a few of them are orphans: old dependencies that are no longer required. Please see: System Maintenance: Check for orphans and dropped packages for more info.
Just noting that kernel 6.14 has reached EOL and has been removed from Manjaro repositories. This means 6.14 will no longer receive updates, so it’s a good idea to move to another kernel, in any case.
Kernel 6.12 (LTS) is generally a safe bet, unless you have specific reasons for desiring the latest-and-greatest kernel offerings.
