After updating to the latest version, Manjaro 21.2 (Qonos) the internet just stops working a couple of days later. I rolled back the update and then tried after a couple of days, but still, the same thing is happening. Right after the updating, it works fine but I don’t know what causes it suddenly stop working, where should I look for clues?
INXI
enp4s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 131.151.79.250 netmask 255.255.252.0 broadcast 131.151.79.255
inet6 fe80::8da1:daea:b347:8636 prefixlen 64 scopeid 0x20<link>
ether f4:8e:38:e8:03:f7 txqueuelen 1000 (Ethernet)
RX packets 2811 bytes 217341 (212.2 KiB)
RX errors 0 dropped 9 overruns 0 frame 0
TX packets 63 bytes 8018 (7.8 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 408 bytes 34575 (33.7 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 408 bytes 34575 (33.7 KiB)
wlp5s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.106.43.108 netmask 255.255.254.0 broadcast 10.106.43.255
inet6 fe80::cd86:21a7:ff46:b72d prefixlen 64 scopeid 0x20<link>
ether ac:2b:6e:88:33:03 txqueuelen 1000 (Ethernet)
RX packets 1552188 bytes 207335774 (197.7 MiB)
TX packets 2577790 bytes 3701700529 (3.4 GiB)
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=289e43c6-5a12-4548-b53b-0927e72f0eaa ro apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1
Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Dell product: Inspiron 7559 v: 1.3.1 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0H0CC0 v: A00 serial: <filter> UEFI: Dell v: 1.3.1
date: 12/02/2018
ID-1: BAT0 charge: 57.2 Wh (100.0%) condition: 57.2/76.1 Wh (75.1%)
volts: 12.8 min: 11.4 model: Dell type: Unknown serial: <filter>
status: Full
RAM: total: 15.49 GiB used: 2.35 GiB (15.2%)
Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: EA cache:
L2: 6 MiB bogomips: 41621
Speed: 810 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 810 2: 800 3: 813
4: 829 5: 835 6: 802 7: 824 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Dell driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 02:00.0
chip-ID: 10de:139b class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 1bcf:28b0 class-ID: 0e02
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: modesetting,nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 960M/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: Dell driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:3165 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
bus-ID: 1-5:4 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 577.55 GiB used: 215 GiB (37.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS120GMTS820S
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WDS500G2B0A
type: SSD serial: <filter> rev: 90WD scheme: GPT
ID-1: / raw-size: 94.5 GiB size: 92.46 GiB (97.84%) used: 61.81 GiB (66.9%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 289e43c6-5a12-4548-b53b-0927e72f0eaa
used: 25.6 MiB (8.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: C5B2-14B8
ID-3: /home raw-size: 200 GiB size: 195.8 GiB (97.90%)
used: 153.17 GiB (78.2%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 671243e1-17bc-4741-893f-13ef242b7872
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 17 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 95ed6940-cc2b-4518-a7b7-a7918d207e57
ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sdb2 maj-min: 8:18 size: 265.75 GiB fs: ntfs label: N/A
uuid: 923499A234998A3D
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-2:2 info: Lenovo 300 Wireless Compact Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 98mA
chip-ID: 17ef:60ac class-ID: 0301
Device-2: 1-3:5 info: Apple Aluminium Keyboard (ANSI) type: Keyboard,Mouse
driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 05ac:024f class-ID: 0301
Device-3: 1-4:3 info: Sunplus Innovation Integrated_Webcam_HD type: Video
Device-4: 1-5:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 54.0 C mobo: 29.8 C sodimm: SODIMM C gpu: nvidia
temp: 54 C
Fan Speeds (RPM): cpu: 0
Processes: 274 Uptime: 2h 2m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1721 pacman: 1688 lib: 426
flatpak: 23 snap: 10 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.08
