Hi guys,
today I woke up, grabbed my laptop and booted it up for work. But suddenly I experienced internet issues (colleagues on Discord said that I was speaking intermittently), but I thought it was a wifi issue. So I cabled the laptop, but the issue is still there.
The other devices, phone on wifi and the other cabled PC, running Windows 10, have no network issues.
Yesterday I did not update anything on Manjaro, today I tried to switch kernel, from 5.8 to 5.4LTS, but no luck.
inxi -Nazy
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 03:00.0
chip ID: 10ec:8168
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_pci v: N/A modules: rtwpci port: 3000
bus ID: 05:00.0 chip ID: 10ec:b822
ethtool eno1
netlink error: No such file or directory
Settings for eno1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Cannot get wake-on-lan settings: Operation not permitted
Current message level: 0x00000033 (51)
drv probe ifdown ifup
Link detected: yes
sudo journalctl -r -b 0 | grep r8169
set 30 10:52:58 PCABS kernel: r8169 0000:03:00.0 eno1: Link is Up - 1Gbps/Full - flow control rx/tx
set 30 10:44:41 PCABS kernel: r8169 0000:03:00.0 eno1: Link is Down
set 30 10:44:41 PCABS kernel: Generic FE-GE Realtek PHY r8169-300:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
set 30 10:44:40 PCABS kernel: r8169 0000:03:00.0 eno1: renamed from eth0
set 30 10:44:40 PCABS kernel: r8169 0000:03:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
set 30 10:44:40 PCABS kernel: r8169 0000:03:00.0 eth0: RTL8168h/8111h, e8:d8:d1:f8:36:2b, XID 541, IRQ 143
set 30 10:44:40 PCABS kernel: libphy: r8169: probed
set 30 10:44:40 PCABS kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
The issue comes and goes, I can surf the internet for a couple of seconds, then it’s like I have 0 speed (on speedtest it goes to 700/800/900 Mbps for 2 seconds, then it freezes, goes down, and back up to maximum).
