Hi, I’ve been trying to use some bluetooth headphones I Bought with my pc however I’ve experienced significant slow downs in internet speed from 40-50mbs down to almost nothing whenever I am listening to anything using it. I know this may just be a hardware issue but going around searching for a solution brought stuff such as adding iwlwifi with specific options but no luck. Is this some sort of hardware issue, or have I messed up with my drivers or something similar?
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5b460c42-da8c-408c-aabb-c0219c618b03 rw intel_iommu=on iommu=pt
quiet apparmor=1 security=apparmor
resume=UUID=906890ec-a2fe-4d48-b105-675cd28d0171 udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Dell product: Inspiron 3670 v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Dell model: 0H4VK7 v: A01 serial: <superuser required> UEFI: Dell
v: 1.5.9 date: 10/09/2018
RAM: total: 15.46 GiB used: 2.16 GiB (14.0%)
RAM Report:
Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
desc: 1x9 MiB
Speed (MHz): avg: 900 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900
bogomips: 33613
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0380
Device-2: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Gigabyte
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:21c4 class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.7x13.5")
s-diag: 693mm (27.3")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: NVIDIA TU116 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-3: Kingston HyperX SoloCast type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:2 chip-ID: 0951:170f
class-ID: 0300
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell Vostro 3470 driver: ath9k v: kernel bus-ID: 03:00.0
chip-ID: 168c:0036 class-ID: 0280
IP v6: <filter> type: dynamic mngtmpaddr scope: global
IP v6: <filter> scope: link
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:7
chip-ID: 0cf3:e005 class-ID: e001
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 1.38 TiB used: 744.56 GiB (52.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC45 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Intenso model: N/A
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B type: SSD
serial: <filter> rev: 0214 scheme: GPT
ID-1: / raw-size: 459.63 GiB size: 451.35 GiB (98.20%)
used: 262.86 GiB (58.2%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 5b460c42-da8c-408c-aabb-c0219c618b03
used: 304 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 0281-B4E3
ID-3: /run/media/nik/DATA raw-size: 931.39 GiB size: 931.39 GiB (100.00%)
used: 481.7 GiB (51.7%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: DATA
uuid: F2AC42B8AC42775F
ID-1: swap-1 type: partition size: 17.01 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: 906890ec-a2fe-4d48-b105-675cd28d0171
ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-6:2 info: Kingston HyperX SoloCast type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0951:170f class-ID: 0300
Device-2: 1-7:3 info: Logitech Gaming Mouse G300 type: Mouse,Keyboard
power: 200mA chip-ID: 046d:c246 class-ID: 0300
Device-3: 1-8:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-4: 1-9:5 info: Winbond ADXOK0119 type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 400mA chip-ID: 0416:a0f8 class-ID: 0301 serial: <filter>
Device-5: 1-14:7 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e005
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:2 info: JMicron / JMicron USA JMS578 SATA 6Gb/s
type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 152d:0578 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 27.8 C pch: 50.0 C mobo: N/A gpu: nvidia
temp: 51 C
Fan Speeds (RPM): cpu: 980 gpu: nvidia fan: 0%
Processes: 248 Uptime: 5m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1473 lib: 439
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole
inxi: 3.3.11
