Internet Connection breaks up regularly - since update
Dell XPS 17 9720 System BIOS
Version      1.30.1
Release date  16 Jan 2025
Dell Technologies highly recommends applying this important update as soon as possible. The update contains critical bug fixes and changes to improve functionality, reliability, and stability of your Dell system. It may also include security fixes and other feature enhancements.
[/quote]
Yes, I noticed this last night and made the necessary installation. Firmware, UEFI etc. is since yesterday up to date! But unfortunately didn´t solve the problem. Today I had the problem again…
I am wiling to try, because the problem is still there.
Before I install iwd (Not installed yet) and add the file as well the extra lines to the file, do i need to delete what I created earlier with @Nachlese
/etc/modprobe.d/iwlwifi.conf
if these options didn’t change anything
which they apparently didn’t
then yes -
remove the file or put a # in front of the line to make it a comment which does nothing
Better to restore the state before the changes - especially if the changes didn’t improve things or change anything.
GUI ??? You men a graphical programm? I din´t find anything on my computer. I believe I need to install it extra? tlpui maybe?
stefan > DELL-XPS17 > pacman -Ss tlp
extra/tlp 1.7.0-1 [installed]
Linux Advanced Power Management
extra/tlp-rdw 1.7.0-1
Linux Advanced Power Management - Radio Device Wizard
extra/tlpui 1.7.1-1
A GTK user interface for TLP written in Python
Yes , everything is described very well in the conf file. I can take a look.
Thank you again…
Yes, that is what I meant.
