Internet suddenly disappeared on manjaro. Other devices are working properly. The connection icon is green, but sites do not open or download updates via sudo pacman -Syyu
(gives errors)
Internet connection is there:
sudo systemctl status systemd-networkd
systemd-networkd.service - Network Configuration
Loaded: loaded (/usr/lib/systemd/system/systemd-networkd.service; disabled>
Active: active (running) since Thu 2023-01-26 07:26:57 EST; 1min 45s ago
sudo systemctl status NetworkManager.service
NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; p>
Active: active (running) since Thu 2023-01-26 07:26:09 EST; 3min 16s ago
I’ve tried changing the DNS settings, but that doesn’t work.
ifconfig
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.62 netmask 255.255.255.0 broadcast 192.168.1.255
ether 00:90:21:90:20:3b txqueuelen 1000 (Ethernet)
RX packets 542 bytes 441034 (430.6 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 319 bytes 28329 (27.6 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 16 memory 0x55200000-55220000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 108 bytes 8648 (8.4 KiB)
TX packets 108 bytes 8648 (8.4 KiB)
I tried rebooting the router, it didn’t help. I will be glad for any help!
