The sound from the internal speakers does not work at all. However, in the GUI it looks like it is working just fine and all other sound outputs lie headphones, HDMI, Bluetooth work just fine.
This is a fresh install of Manjaro KDE on my Acer Swift SF515-51T, LTS kernel 5.10.34-1 and trying other kernels shows similar behaviour, means not working.
The only difference is real time 5.9.1 kernel or older kernels below 5.4 where speakers work just fine.
Web is full of potential solutions, unfortunately none of them seems to work with kernel higher than 5.4 (including).
[ 3.460423] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 3.460447] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 3.491772] snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 3.491793] snd_soc_skl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 4.461260] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC256: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.461266] snd_hda_codec_realtek ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.461269] snd_hda_codec_realtek ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 4.461272] snd_hda_codec_realtek ehdaudio0D0: mono: mono_out=0x0
[ 4.461274] snd_hda_codec_realtek ehdaudio0D0: inputs:
[ 4.521632] snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
[ 4.521637] snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
The full ALSA log using kernel 5.10.34-1(speakers not working): can be found here
The full ALSA log kernel 5.9.1-10rt19 (speakers working) can be found here
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
(as that makes both our lives much easier)
No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed.
sound probems started with 5.4 including. what actually works is 5.9 real time kernel, but that one has other problems which are even worse for daily usage (touchpad and touchscreen not working after waking up from the sleep).
what is interesting is the comparison of working 5.9 with not working 5.10 lts (attached), I can hardly see any diference in alsa logs.
yeah, i saw this idea in other discussions, unfortunately not working for me.
there are three options that let me select speakers (internal, lfe and back), but still no sound after rebooting. other unconnected pings do not give option for any speakers. i will try different order and test.
I did a comparison of the two data sets for alsa-info.sh
( meld is easier than ‘pacdiff’ to see past the differences with timestamps)
Both data sets show the same kernel module in use - snd_soc_skl_hda_dsp
ALC256 pin configurations in !!HDA-Intel Codec information only show differences in the volume settings for speakers and headphones
For kernel v5.9 RT, onboard audio is shown as Card hw:0 'sofhdadsp'/'WL-SwiftSF515_51T-V1.03-Guinness_WL'
But on kernel v5.10 card is shown as Card hw:0 'sofhdadsp'/'sof-hda-dsp'
The data in !!All Loaded Modules shows significant differences
(non working) kernel v5.10 has 4 kernel modules for snd_soc
thx, appreciate the support. unfortunately still not working.
alsa log, after blackilisting snd_soc_skl and using latest kernel 5.13.RC1, shows same onboard audio 0 [sofhdadsp ]: sof-hda-dsp - sof-hda-dsp WL-SwiftSF515_51T-V1.03-Guinness_WL . as working kernel 5.9 RT.
