Hi,
I am having a strange problem with my laptop. Sometimes upon starting the laptop the Bluetooth and Wifi are not working. I need to restart the system to make them working.
This issue was there in Fedora also (I recently shifted from Fedora to Manjaro).
It is not a big deal, but is there any solution for this or I need to live with it till the new kernel comes up.
Please note that till Fedora 32, this Wifi/Bluetooth was not even supported, had to manually install the driver from Git repository. However the drivers were in-built on Ubuntu during same time frame (may be they were proprietary drivers).
Device details:
HP Laptop 15q-ds0xxx
RTL8723DE 802.11b/g/n PCIe Adapter
Kernel Version: 5.10.2-2
Let me know if any further details are required.
Please post the output of the following using Preformatted text </>:
inxi -Fazy
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = “”,
LC_ALL = (unset),
LC_ADDRESS = “en_IN.UTF-8”,
LC_IDENTIFICATION = “en_IN.UTF-8”,
LC_MEASUREMENT = “en_IN.UTF-8”,
LC_MONETARY = “en_IN.UTF-8”,
LC_NAME = “en_IN.UTF-8”,
LC_NUMERIC = “en_IN.UTF-8”,
LC_PAPER = “en_IN.UTF-8”,
LC_TELEPHONE = “en_IN.UTF-8”,
LC_TIME = “en_IN.UTF-8”,
LANG = “en_IN.UTF-8”
are supported and installed on your system.
perl: warning: Falling back to the standard locale (“C”).
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=340b9b90-88ca-427d-96ce-9f868f1d1995 rw quiet apparmor=1
security=apparmor resume=UUID=0c6cb59d-b9c3-443d-814c-c0cea764dcc7
udev.log_priority=3
Console: tty 2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
Type: Laptop System: HP product: HP Laptop 15q-ds0xxx
v: Type1ProductConfigId serial: Chassis: type: 10 serial:
Mobo: HP model: 84A6 v: 80.48 serial: UEFI: Insyde v: F.33
date: 07/31/2020
ID-1: BAT1 charge: 45.6 Wh condition: 45.6/42.3 Wh (108%) volts: 13.0/11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial:
status: Full
Device-1: hid-34:88:5d:e0:31:11-battery
model: Bluetooth Mouse M336/M337/M535 serial: N/A charge: N/A
status: Discharging
Info: Quad Core model: Intel Core i5-8250U socket: BGA1356 (U3E1)
note: check bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: A (10) microcode: E0 L1 cache: 256 KiB
L2 cache: 6 MiB L3 cache: 5.9 MiB
bogomips: 28808
Speed: 700 MHz min/max: 400/3400 MHz base/boost: 1700/8300 volts: 0.7 V
ext-clock: 100 MHz Core speeds (MHz): 1: 700 2: 700 3: 700 4: 700 5: 700
6: 700 7: 700 8: 700
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: Chicony HP TrueVision HD Camera type: USB driver: uvcvideo
bus ID: 1-5:2 chip ID: 04f2:b65d serial:
Display: server: X.Org 1.20.10 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.10.2-2-MANJARO
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 01:00.0
chip ID: 10ec:8168
IF: eno1 state: down mac:
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter vendor: Hewlett-Packard
driver: rtw_8723de v: N/A modules: rtw88_8723de port: 3000 bus ID: 02:00.0
chip ID: 10ec:d723
IF: wlo1 state: up mac:
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus ID: 00:17.0 chip ID: 8086.282a rev: 21
Local Storage: total: 1.36 TiB used: 772.25 GiB (55.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
family: Micron MX500 SSDs size: 465.76 GiB block size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s serial: rev: 023
temp: 33 C
SMART: yes state: enabled health: PASSED on: 102d 18h cycles: 1722
written: 46.37 TiB
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Crucial
model: CT1000MX 500SSD4 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B serial: rev: 0202
ID-1: / raw size: 448.49 GiB size: 440.46 GiB (98.21%)
used: 212.59 GiB (48.3%) fs: ext4 block size: 4096 B dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat block size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 16.97 GiB used: 2.2 MiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 38.0 C mobo: 29.8 C
Processes: 263 Uptime: 2h 12m wakeups: 2 Memory: 15.43 GiB
used: 2.72 GiB (17.6%) Init: systemd v: 247 Compilers: gcc: N/A Packages:
pacman: 1361 lib: 415 flatpak: 0 Shell: fish (sudo) v: 3.1.2 default: Bash
v: 5.1.0 running in: konsole inxi: 3.2.01
Please edit your post, highlight the text then use the Preformatted text </> button as I asked.
Done, sorry.
Hope this is what you wanted.
Yes, thank you. Not sure what’s going on with that locale error, but that’s a subject for another topic.
Let’s see if there’s any errors in the log. Please post the output of the following:
sudo dmesg | grep rtw
[ 3536.536418] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
da_core crc32_pclmul rtw88_core snd_hwdep ghash_clmulni_intel soundwire_bus aesni_intel mac80211 crypto_simd snd_soc_core cryptd glue_helper rapl intel_cstate snd_comp
ress ac97_bus i2c_algo_bit snd_pcm_dmaengine intel_uncore vfat fat cfg80211 snd_pcm joydev drm_kms_helper mousedev snd_timer r8169 pcspkr snd realtek mdio_devres rfkil
l mei_me i2c_i801 soundcore i2c_smbus libarc4 libphy cec mei intel_gtt syscopyarea processor_thermal_device sysfillrect intel_rapl_common sysimgblt tpm_crb intel_xhci_
usb_role_switch int340x_thermal_zone intel_pch_thermal roles fb_sys_fops intel_soc_dts_iosf wmi tpm_tis tpm_tis_core kxcjk_1013 tpm industrialio_triggered_buffer cm321
81 intel_vbtn kfifo_buf sparse_keymap video industrialio rng_core int3400_thermal hp_wireless acpi_thermal_rel mac_hid acpi_tad acpi_pad drm uinput sg fuse crypto_user
[ 3536.536508] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3536.536537] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3567.256607] WARNING: CPU: 5 PID: 0 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3567.256864] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3567.257235] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3567.257319] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3599.683124] WARNING: CPU: 5 PID: 0 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3599.683244] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3599.683434] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3599.683499] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3630.403047] WARNING: CPU: 5 PID: 22066 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3630.403160] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3630.403336] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3630.403396] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3652.326372] WARNING: CPU: 5 PID: 22065 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3652.326484] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3652.326660] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3652.326720] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3683.309703] WARNING: CPU: 5 PID: 22063 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3683.309814] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3683.309991] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3683.310050] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3714.029768] WARNING: CPU: 5 PID: 0 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3714.029888] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3714.030078] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3714.030142] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3746.459683] WARNING: CPU: 5 PID: 0 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3746.459731] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3746.459807] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3746.459834] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3777.176310] WARNING: CPU: 5 PID: 22060 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3777.176373] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3777.176489] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3777.176523] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3809.602994] WARNING: CPU: 5 PID: 90830 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3809.603083] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3809.603230] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3809.603279] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3832.352960] WARNING: CPU: 5 PID: 22069 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3832.353011] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3832.353092] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3832.353119] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3864.216311] WARNING: CPU: 5 PID: 22069 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3864.216396] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3864.216530] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3864.216576] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3896.642942] WARNING: CPU: 5 PID: 22066 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3896.642992] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3896.643072] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3896.643097] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3927.362943] WARNING: CPU: 5 PID: 22065 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3927.362999] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3927.363091] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3927.363121] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3958.082960] WARNING: CPU: 5 PID: 0 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3958.083023] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3958.083121] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3958.083153] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 3990.513228] WARNING: CPU: 5 PID: 0 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3990.513335] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 3990.513504] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 3990.513561] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 4012.376294] WARNING: CPU: 5 PID: 22060 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4012.376406] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 4012.376580] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4012.376639] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 4043.416287] WARNING: CPU: 5 PID: 22063 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4043.416400] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 4043.416576] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4043.416647] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 4074.136255] WARNING: CPU: 5 PID: 22061 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4074.136306] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 4074.136389] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4074.136418] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 4106.566232] WARNING: CPU: 5 PID: 22069 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4106.566286] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 4106.566370] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4106.566400] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 4138.989559] WARNING: CPU: 5 PID: 22060 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4138.989612] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 4138.989699] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4138.989728] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 4171.416227] WARNING: CPU: 5 PID: 22063 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4171.416296] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 4171.416409] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4171.416446] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 4192.349848] WARNING: CPU: 5 PID: 0 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4192.350104] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 4192.350476] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4192.350560] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 4224.323145] WARNING: CPU: 5 PID: 0 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4224.323709] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 4224.324083] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4224.324166] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 4255.042860] WARNING: CPU: 5 PID: 22065 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4255.042909] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 4255.042988] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4255.043014] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 4287.469565] WARNING: CPU: 5 PID: 22065 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4287.469690] soundwire_generic_allocation squashfs soundwire_cadence snd_hda_codec rtw88_8723de rtw88_8723d rtw88_pci loop kvm irqbypass crct10dif_pclmul i915 snd_h
[ 4287.469870] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4287.469930] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
If you search the internet for that, there are bunch of bug reports. Not sure what to make of it, unfortunately.
Thanks for your time.
Anyways I can live with it as it only requires a restart
I was playing with Solus 4.2 (Budgie) for a few days and strangely I found this issue not cropping up on Solus once.
But it crops up on all other distros I have used (Open SUSE (Tumbleweed), Fedora KDE, Manjaro, Arco, Kubuntu). Weird - is there a way to identify what they are doing differently and the same can be applied by Manjaro Team ?
BTW I am back to Manjaro KDE as Solus is too restrictive for my taste.
The driver is provided by the kernel, so all distros are using it. What kernel were you using in Solus?
Yes, that is why I was also surprised when the same problem did not occur on Solus.
Kernel Version: 5.10.15-172.current
My Kernel Version is 5.10.15-1-MANJARO as I have switched back to Manjaro KDE
