After the recent update that pushed through a few days ago, I’ve been having intermittent applications freezes, that seem to last 20-40 seconds. Sometimes I’ll get several in a matter of minutes, other times I’ll go over an hour without seeing any freezing. When an application freezes, my taskbar panels appear to freeze with it, as the system clock will stop for the duration. However, despite this I can typically use the other applications that aren’t frozen normally for the duration. I’ve tried using both the 5.11 kernel as well as the 5.10 kernel, the problem appears to persist with both. What might I be able to do to mitigate this?
System info:
Kernel: 5.10.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=f20341a5-d063-49ab-b805-4c49d1494a57 rw quiet apparmor=1
security=apparmor resume=UUID=76ccb886-6c3d-4ec1-8470-d15a850477c6
udev.log_priority=3
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: Z87X-D3H v: N/A serial: <filter>
Chassis: type: 3 serial: <filter>
Mobo: Gigabyte model: Z87X-D3H-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F9 date: 08/25/2014
RAM: total: 7.73 GiB used: 4.68 GiB (60.5%)
Info: Quad Core model: Intel Core i5-4670K bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 L2 cache: 6 MiB
bogomips: 27146
Speed: 3508 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 3508 2: 3679
3: 3592 4: 3657
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology
xtpr
Type: l1tf
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: eVga.com. driver: nvidia
v: 460.56 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:13c2
class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 95 s-size: 1027x292mm (40.4x11.5")
s-diag: 1068mm (42")
Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.0x11.3") diag: 584mm (23")
Monitor-2: DVI-D-0 res: 1920x1080 hz: 60 dpi: 96
OpenGL: renderer: GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
class ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fbb
class ID: 0403
Device-3: Antlion Audio Antlion Wireless Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-9.1:5 chip ID: 2f96:0100
class ID: 0300
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 3-9.2:8 chip ID: 046d:0825 class ID: 0102 serial: <filter>
Device-5: FiiO K3 type: USB driver: snd-usb-audio bus ID: 3-10.4:14
chip ID: 2972:0047 class ID: fe01
Sound Server: ALSA v: k5.10.19-1-MANJARO
Device-1: Intel Ethernet I217-V vendor: Gigabyte driver: e1000e v: kernel
port: f040 bus ID: 00:19.0 chip ID: 8086:153b class ID: 0200
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k
v: kernel port: e000 bus ID: 03:00.0 chip ID: 168c:0030 class ID: 0280
IF-ID-1: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Message: No Bluetooth data was found.
Local Storage: total: 7.97 TiB used: 3.01 TiB (37.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 6B0Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 EVO 500GB
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: BB6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM001-1CH164
size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC24 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST6000DM003-2CY186
size: 5.46 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5425 rpm serial: <filter> rev: 0001 scheme: GPT
Optical-1: /dev/sr0 vendor: PIONEER model: BD-RW BDR-208D rev: 1.10
dev-links: cdrom
Features: speed: 125 multisession: yes audio: yes dvd: yes
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw size: 456.66 GiB size: 448.5 GiB (98.21%)
used: 166.03 GiB (37.0%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: f20341a5-d063-49ab-b805-4c49d1494a57
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 24.4 MiB (8.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: D9DD-AE21
ID-3: /media/Multimedia-2TB1 raw size: 1.78 TiB size: 1.78 TiB (100.00%)
used: 594.56 GiB (32.5%) fs: ntfs dev: /dev/sdc2 maj-min: 8:34
label: Multimedia-2TB1 uuid: 9E0C0F420C0F14C5
ID-4: /media/Multimedia-6TB1 raw size: 5.46 TiB size: 5.41 TiB (99.19%)
used: 2.1 TiB (38.7%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49
label: Multimedia-6TB1 uuid: a7f97c08-8984-4100-9e73-cb531cca871c
ID-5: /run/media/anris/F4F415DDF415A2C2 raw size: 237.91 GiB
size: 237.91 GiB (100.00%) used: 179.83 GiB (75.6%) fs: ntfs dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: F4F415DDF415A2C2
ID-1: swap-1 type: partition size: 8.8 GiB used: 1.13 GiB (12.9%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 76ccb886-6c3d-4ec1-8470-d15a850477c6
ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 450 MiB fs: ntfs label: N/A
uuid: 6A98D5F198D5BC2F
ID-3: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: ntfs label: System Reserved
uuid: 6EFEC50EFEC4CF8F
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
speed: 480 Mb/s chip ID: 8087:8008 class ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8000 class ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Device-1: 3-8:2 info: Alcor Micro Multi Flash Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 058f:6366 class ID: 0806 serial: <filter>
Hub-6: 3-9:3 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
chip ID: 045b:0209 class ID: 0900
Device-1: 3-9.1:5 info: Antlion Audio Antlion Wireless Microphone
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
rev: 1.1 speed: 12 Mb/s chip ID: 2f96:0100 class ID: 0300
Device-2: 3-9.2:8 info: Logitech Webcam C270 type: Video,Audio
Hub-7: 3-10:4 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 3-10.4:14 info: FiiO K3 type: Audio driver: snd-usb-audio
interfaces: 3 rev: 2.0 speed: 480 Mb/s chip ID: 2972:0047 class ID: fe01
Device-2: 3-13:6 info: ROCCAT Kone Pure Owl-Eye type: Mouse,Keyboard
chip ID: 1e7d:2dcd class ID: 0300
Device-3: 3-14:9 info: Logitech Gaming Keyboard G610 type: Keyboard,HID
chip ID: 046d:c338 class ID: 0300 serial: <filter>
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003 class ID: 0900
Hub-9: 4-5:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 045b:0210 class ID: 0900
Hub-10: 4-6:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 58 C
Processes: 265 Uptime: 16h 58m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: 1535 apt: 0 pacman: 1521 lib: 439
flatpak: 0 snap: 14 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.3.01
Journalctl entries:
journalctl --catalog --priority=3 --boot=-1
-- Journal begins at Mon 2020-10-12 13:13:35 EDT, ends at Fri 2021-03-12 13:58:12 EST. --
Mar 11 01:58:44 anri-pc systemd-udevd[267]: /etc/udev/rules.d/20-hw1.rules:13 Unknown group 'plugdev', ignoring
Mar 11 01:58:44 anri-pc systemd-udevd[267]: /etc/udev/rules.d/20-hw1.rules:15 Unknown group 'plugdev', ignoring
Mar 11 01:58:44 anri-pc systemd-udevd[267]: /etc/udev/rules.d/20-hw1.rules:16 Invalid key/value pair, ignoring.
Mar 11 01:58:44 anri-pc systemd-udevd[267]: /etc/udev/rules.d/20-hw1.rules:34 Unknown group 'plugdev', ignoring
Mar 11 01:58:44 anri-pc systemd-udevd[267]: /etc/udev/rules.d/20-hw1.rules:35 Unknown group 'plugdev', ignoring
Mar 11 01:58:44 anri-pc kernel:
Mar 11 01:58:45 anri-pc kernel: usb 3-10.4: device descriptor read/64, error -32
Mar 11 01:58:47 anri-pc kernel: usb 3-10.4: device not accepting address 11, error -71
Mar 11 01:58:47 anri-pc kernel: usb 3-10.4: device not accepting address 12, error -71
Mar 11 01:58:47 anri-pc kernel: usb 3-10-port4: unable to enumerate USB device
Mar 11 01:58:48 anri-pc kernel: usb 3-10.4: device descriptor read/64, error -32
Mar 11 01:58:49 anri-pc kernel: usb 3-10.4: device descriptor read/64, error -32
Mar 11 01:58:50 anri-pc kernel: usb 3-10.4: device descriptor read/64, error -32
Mar 11 01:58:51 anri-pc kernel: usb 3-10.4: device not accepting address 15, error -71
Mar 11 01:58:52 anri-pc kernel: usb 3-10.4: device not accepting address 16, error -71
Mar 11 01:58:52 anri-pc kernel: usb 3-10-port4: unable to enumerate USB device
Mar 11 01:58:53 anri-pc kernel: usb 3-10.4: device descriptor read/64, error -32
Mar 11 01:58:54 anri-pc kernel: usb 3-10.4: device descriptor read/64, error -32
Mar 11 01:58:55 anri-pc kernel: usb 3-10.4: device descriptor read/64, error -32
Mar 11 01:58:56 anri-pc kernel: usb 3-10.4: device not accepting address 19, error -71
Mar 11 01:58:57 anri-pc kernel: usb 3-10.4: device not accepting address 20, error -71
Mar 11 01:58:57 anri-pc kernel: usb 3-10-port4: unable to enumerate USB device
Mar 11 01:58:58 anri-pc kernel: usb 3-10.4: device descriptor read/64, error -32
Mar 11 01:59:06 anri-pc kernel: ata3: COMRESET failed (errno=-16)
Mar 11 01:59:08 anri-pc kwin_x11[944]: kwin_xkbcommon: XKB: Couldn't process include statement for 'us(\0)'
Mar 11 01:59:08 anri-pc kwin_x11[944]: kwin_xkbcommon: XKB: Abandoning symbols file "(unnamed)"
Mar 11 01:59:08 anri-pc kwin_x11[944]: kwin_xkbcommon: XKB: Failed to compile xkb_symbols
Mar 11 01:59:08 anri-pc kwin_x11[944]: kwin_xkbcommon: XKB: Failed to compile keymap
Mar 11 01:59:10 anri-pc python[1078]: backintime (anris/1): ERROR: Back In Time is not configured!
Mar 11 01:59:16 anri-pc kernel: ata3: COMRESET failed (errno=-16)
Mar 11 01:59:35 anri-pc pulseaudio[1055]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed ou>
Mar 11 02:00:12 anri-pc kernel: ata3.00: exception Emask 0x0 SAct 0x8000000 SErr 0x50000 action 0x6 frozen
