I have been trying to install the drivers for Brother DCP-T220 printer. The drivers are not available in AUR library. Earlier I was on Manjaro Gnome in which I was able to install using the Driver Installation tool. But in Manjaro XFCE, when I go through the process of installing, it throws an error:
bash linux-brprinter-installer-2.2.3-1 DCP-T220
Rpm or dpkg is required.
rmdir: failed to remove ββ: No such file or directory
I even tried using the Print Settings option but the drivers were not available there too.
I was able to build using the guide listed below. I used the .deb method.
https://wiki.archlinux.org/title/Packaging_Brother_printer_drivers
Can you explain the process of making the file. I am getting an error because of the empty md5sums row. How to know the correct value to fill.
I donβt know the answer to that question. If you know that the source is credible, you can, at your own risk (slight) use md5sums=(βSKIPβ) in your PKGBUILD.
makepkg -cs --skipchecksums
I did try βskipβ value them it threw an error. I could later found the value from the downloaded .deb file.
Thank you
