Hi,
I’m not sure where to report this.
I`ve been having some really bad wifi for a bit now. Some times the connection became incredibly slow, some times it was dropping all the time (and asking for the password - it was already filled, all I had to do is press enter).
Since today it was really bad, I went back to the 5.9 kernel. Seems like it is working fine.
My inxi -Fazy
output is this:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=38428a44-b44a-42e1-9b59-607ff13ab51a rw quiet udev.log_priority=3
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Laptop System: Dell product: Inspiron 7391 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0XJCMV v: A00 serial: <filter> UEFI: Dell v: 1.9.0
date: 07/10/2020
ID-1: BAT0 charge: 35.9 Wh condition: 35.9/45.0 Wh (80%) volts: 8.7/7.6
model: BYD DELL DGV249A type: Li-poly serial: <filter> status: Full
Device-1: hid-34:88:5d:67:b4:bb-battery model: Keyboard K380 serial: N/A
charge: N/A status: Discharging
Info: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: DE L2 cache: 6 MiB
bogomips: 33615
Speed: 800 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9b41
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-6:3 chip ID: 0bda:565a serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 2734x768 s-dpi: 96 s-size: 723x203mm (28.5x8.0")
s-diag: 751mm (29.6")
Monitor-1: eDP1 res: 1368x768 dpi: 120 size: 290x170mm (11.4x6.7")
diag: 336mm (13.2")
Monitor-2: HDMI1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1")
diag: 470mm (18.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Device-1: Intel vendor: Dell driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:02c8
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 3000
bus ID: 00:14.3 chip ID: 8086:02f0
Local Storage: total: 238.47 GiB used: 177.78 GiB (74.5%)
model: PC SN520 NVMe WDC 256GB size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: <filter> rev: 20200012
temp: 41.9 C
ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 177.78 GiB (76.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3878
Processes: 258 Uptime: 17m wakeups: 4 Memory: 7.56 GiB
used: 1.88 GiB (24.9%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1613 pacman: 1607 lib: 426 flatpak: 6 Shell: Zsh v: 5.8
running in: alacritty inxi: 3.2.02
