iwlwifi firmware is failing. Its all random
iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
here is the dump for >> sudo dmesg | grep iwlwifi
dmesg dump
Current Kernel : 6.2
Different kernel i tried but have same problem : 5.15 LTS , 6.1 LTS , 6.2
Olli
May 6, 2023, 5:56pm
2
please use the option “preformatted text” and paste it inside there.
[sudo] password for kahtras:
[ 3.997951] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 4.071268] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 4.071273] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 4.071275] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 4.071277] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 4.071279] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 4.071281] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 4.071282] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 4.071284] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 4.071286] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 4.071287] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 4.071289] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 4.071291] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 4.071292] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 4.071294] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 4.071296] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 4.071297] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 4.071299] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 4.071761] iwlwifi 0000:00:14.3: loaded firmware version 46.ea3728ee.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[ 4.562747] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz, REV=0x312
[ 4.612679] iwlwifi 0000:00:14.3: base HW address: 90:78:41:e3:06:f7, OTP minor version: 0x4
[ 4.684857] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[ 2218.915808] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 2218.916168] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2218.916170] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
[ 2218.916172] iwlwifi 0000:00:14.3: Loaded firmware version: 46.ea3728ee.0 9000-pu-b0-jf-b0-46.ucode
[ 2218.916173] iwlwifi 0000:00:14.3: 0x00000034 | NMI_INTERRUPT_WDG
[ 2218.916175] iwlwifi 0000:00:14.3: 0x000022F3 | trm_hw_status0
[ 2218.916176] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 2218.916177] iwlwifi 0000:00:14.3: 0x0048961A | branchlink2
[ 2218.916179] iwlwifi 0000:00:14.3: 0x0047905E | interruptlink1
[ 2218.916180] iwlwifi 0000:00:14.3: 0x0000D07C | interruptlink2
[ 2218.916181] iwlwifi 0000:00:14.3: 0x0001B832 | data1
[ 2218.916182] iwlwifi 0000:00:14.3: 0x000003FF | data2
[ 2218.916183] iwlwifi 0000:00:14.3: 0x000003FF | data3
[ 2218.916184] iwlwifi 0000:00:14.3: 0x6A801600 | beacon time
[ 2218.916185] iwlwifi 0000:00:14.3: 0x8ACB29E3 | tsf low
[ 2218.916187] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 2218.916188] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 2218.916189] iwlwifi 0000:00:14.3: 0x2212456B | time gp2
[ 2218.916190] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 2218.916191] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 2218.916192] iwlwifi 0000:00:14.3: 0xEA3728EE | uCode version minor
[ 2218.916193] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 2218.916194] iwlwifi 0000:00:14.3: 0x00C89002 | board version
[ 2218.916195] iwlwifi 0000:00:14.3: 0x0B99001C | hcmd
[ 2218.916197] iwlwifi 0000:00:14.3: 0xA2EA2002 | isr0
[ 2218.916198] iwlwifi 0000:00:14.3: 0x01000000 | isr1
[ 2218.916199] iwlwifi 0000:00:14.3: 0x0800580A | isr2
[ 2218.916200] iwlwifi 0000:00:14.3: 0x40417D8D | isr3
[ 2218.916201] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 2218.916202] iwlwifi 0000:00:14.3: 0x0B99001C | last cmd Id
[ 2218.916203] iwlwifi 0000:00:14.3: 0x0001B832 | wait_event
[ 2218.916204] iwlwifi 0000:00:14.3: 0x0000B04B | l2p_control
[ 2218.916219] iwlwifi 0000:00:14.3: 0x00001C00 | l2p_duration
[ 2218.916220] iwlwifi 0000:00:14.3: 0x00000003 | l2p_mhvalid
[ 2218.916221] iwlwifi 0000:00:14.3: 0x00000085 | l2p_addr_match
[ 2218.916222] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 2218.916223] iwlwifi 0000:00:14.3: 0x15120642 | timestamp
[ 2218.916224] iwlwifi 0000:00:14.3: 0x00008840 | flow_handler
[ 2218.916360] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2218.916361] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
[ 2218.916363] iwlwifi 0000:00:14.3: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL
[ 2218.916364] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 2218.916365] iwlwifi 0000:00:14.3: 0xC0088A3A | umac branchlink2
[ 2218.916366] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink1
[ 2218.916367] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink2
[ 2218.916368] iwlwifi 0000:00:14.3: 0x00000800 | umac data1
[ 2218.916369] iwlwifi 0000:00:14.3: 0xC0084458 | umac data2
[ 2218.916370] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 2218.916371] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 2218.916372] iwlwifi 0000:00:14.3: 0xEA3728EE | umac minor
[ 2218.916373] iwlwifi 0000:00:14.3: 0x22124584 | frame pointer
[ 2218.916374] iwlwifi 0000:00:14.3: 0xC088627C | stack pointer
[ 2218.916375] iwlwifi 0000:00:14.3: 0x00CD019C | last host cmd
[ 2218.916376] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 2218.916413] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 2218.916414] iwlwifi 0000:00:14.3: 0x00002323 | IML/ROM error/state
[ 2218.916446] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM data1
[ 2218.916461] iwlwifi 0000:00:14.3: Fseq Registers:
[ 2218.916470] iwlwifi 0000:00:14.3: 0x42878416 | FSEQ_ERROR_CODE
[ 2218.916478] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 2218.916486] iwlwifi 0000:00:14.3: 0x420C0F41 | FSEQ_CNVIO_INIT_VERSION
[ 2218.916495] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 2218.916503] iwlwifi 0000:00:14.3: 0xCF80F5DF | FSEQ_TOP_CONTENT_VERSION
[ 2218.916511] iwlwifi 0000:00:14.3: 0xDE91F59F | FSEQ_ALIVE_TOKEN
[ 2218.916520] iwlwifi 0000:00:14.3: 0x61B642DE | FSEQ_CNVI_ID
[ 2218.916528] iwlwifi 0000:00:14.3: 0x83BB9275 | FSEQ_CNVR_ID
[ 2218.916536] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 2218.916547] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 2218.916557] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 2218.916598] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 2218.916608] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 2292.944004] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 2292.944374] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2292.944375] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
[ 2292.944377] iwlwifi 0000:00:14.3: Loaded firmware version: 46.ea3728ee.0 9000-pu-b0-jf-b0-46.ucode
[ 2292.944378] iwlwifi 0000:00:14.3: 0x00004428 | ADVANCED_SYSASSERT
[ 2292.944380] iwlwifi 0000:00:14.3: 0x0080A2F0 | trm_hw_status0
[ 2292.944381] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 2292.944382] iwlwifi 0000:00:14.3: 0x0048961A | branchlink2
[ 2292.944383] iwlwifi 0000:00:14.3: 0x0047905E | interruptlink1
[ 2292.944384] iwlwifi 0000:00:14.3: 0x0000D084 | interruptlink2
[ 2292.944385] iwlwifi 0000:00:14.3: 0x0001917E | data1
[ 2292.944386] iwlwifi 0000:00:14.3: 0x000003FF | data2
[ 2292.944387] iwlwifi 0000:00:14.3: 0x000003FF | data3
[ 2292.944388] iwlwifi 0000:00:14.3: 0xAF803453 | beacon time
[ 2292.944389] iwlwifi 0000:00:14.3: 0x8F34BB92 | tsf low
[ 2292.944390] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 2292.944391] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 2292.944392] iwlwifi 0000:00:14.3: 0x044AC9CB | time gp2
[ 2292.944393] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 2292.944394] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 2292.944395] iwlwifi 0000:00:14.3: 0xEA3728EE | uCode version minor
[ 2292.944396] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 2292.944397] iwlwifi 0000:00:14.3: 0x00C89002 | board version
[ 2292.944398] iwlwifi 0000:00:14.3: 0x0B57001C | hcmd
[ 2292.944399] iwlwifi 0000:00:14.3: 0xA68A3002 | isr0
[ 2292.944400] iwlwifi 0000:00:14.3: 0x01048000 | isr1
[ 2292.944400] iwlwifi 0000:00:14.3: 0x0800180A | isr2
[ 2292.944401] iwlwifi 0000:00:14.3: 0x4043FDCF | isr3
[ 2292.944402] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 2292.944403] iwlwifi 0000:00:14.3: 0x0B56001C | last cmd Id
[ 2292.944404] iwlwifi 0000:00:14.3: 0x0001917E | wait_event
[ 2292.944405] iwlwifi 0000:00:14.3: 0x000000C4 | l2p_control
[ 2292.944406] iwlwifi 0000:00:14.3: 0x00420020 | l2p_duration
[ 2292.944407] iwlwifi 0000:00:14.3: 0x00000007 | l2p_mhvalid
[ 2292.944408] iwlwifi 0000:00:14.3: 0x00000081 | l2p_addr_match
[ 2292.944409] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 2292.944410] iwlwifi 0000:00:14.3: 0x15120642 | timestamp
[ 2292.944411] iwlwifi 0000:00:14.3: 0x0000C888 | flow_handler
[ 2292.944560] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2292.944562] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
[ 2292.944564] iwlwifi 0000:00:14.3: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL
[ 2292.944565] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 2292.944567] iwlwifi 0000:00:14.3: 0xC0088A3A | umac branchlink2
[ 2292.944569] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink1
[ 2292.944571] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink2
[ 2292.944572] iwlwifi 0000:00:14.3: 0x00000800 | umac data1
[ 2292.944573] iwlwifi 0000:00:14.3: 0xC0084458 | umac data2
[ 2292.944576] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 2292.944577] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 2292.944579] iwlwifi 0000:00:14.3: 0xEA3728EE | umac minor
[ 2292.944580] iwlwifi 0000:00:14.3: 0x044AC9E6 | frame pointer
[ 2292.944581] iwlwifi 0000:00:14.3: 0xC088627C | stack pointer
[ 2292.944582] iwlwifi 0000:00:14.3: 0x00E5014E | last host cmd
[ 2292.944582] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 2292.944619] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 2292.944620] iwlwifi 0000:00:14.3: 0x00002324 | IML/ROM error/state
[ 2292.944651] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM data1
[ 2292.944666] iwlwifi 0000:00:14.3: Fseq Registers:
[ 2292.944675] iwlwifi 0000:00:14.3: 0x42878416 | FSEQ_ERROR_CODE
[ 2292.944683] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 2292.944692] iwlwifi 0000:00:14.3: 0x420C0F41 | FSEQ_CNVIO_INIT_VERSION
[ 2292.944700] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 2292.944708] iwlwifi 0000:00:14.3: 0xCF80F5DF | FSEQ_TOP_CONTENT_VERSION
[ 2292.944717] iwlwifi 0000:00:14.3: 0xDE91F59F | FSEQ_ALIVE_TOKEN
[ 2292.944725] iwlwifi 0000:00:14.3: 0x61B642DE | FSEQ_CNVI_ID
[ 2292.944733] iwlwifi 0000:00:14.3: 0x83BB9275 | FSEQ_CNVR_ID
[ 2292.944742] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 2292.944752] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 2292.944763] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 2292.944812] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 2292.944830] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 2296.827275] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 2296.827628] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2296.827629] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
[ 2296.827631] iwlwifi 0000:00:14.3: Loaded firmware version: 46.ea3728ee.0 9000-pu-b0-jf-b0-46.ucode
[ 2296.827633] iwlwifi 0000:00:14.3: 0x00002B7E | ADVANCED_SYSASSERT
[ 2296.827635] iwlwifi 0000:00:14.3: 0x051022F3 | trm_hw_status0
[ 2296.827637] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 2296.827638] iwlwifi 0000:00:14.3: 0x0048961A | branchlink2
[ 2296.827640] iwlwifi 0000:00:14.3: 0x0047905E | interruptlink1
[ 2296.827641] iwlwifi 0000:00:14.3: 0x00000000 | interruptlink2
[ 2296.827643] iwlwifi 0000:00:14.3: 0x0000FE84 | data1
[ 2296.827644] iwlwifi 0000:00:14.3: 0xE8396000 | data2
[ 2296.827645] iwlwifi 0000:00:14.3: 0x07ECE000 | data3
[ 2296.827646] iwlwifi 0000:00:14.3: 0x04803851 | beacon time
[ 2296.827648] iwlwifi 0000:00:14.3: 0x8F6FFC8D | tsf low
[ 2296.827649] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 2296.827650] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 2296.827651] iwlwifi 0000:00:14.3: 0x001C75F9 | time gp2
[ 2296.827653] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 2296.827654] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 2296.827655] iwlwifi 0000:00:14.3: 0xEA3728EE | uCode version minor
[ 2296.827657] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 2296.827658] iwlwifi 0000:00:14.3: 0x00C89002 | board version
[ 2296.827660] iwlwifi 0000:00:14.3: 0x0000001C | hcmd
[ 2296.827664] iwlwifi 0000:00:14.3: 0x00023800 | isr0
[ 2296.827666] iwlwifi 0000:00:14.3: 0x00048000 | isr1
[ 2296.827667] iwlwifi 0000:00:14.3: 0x08001802 | isr2
[ 2296.827668] iwlwifi 0000:00:14.3: 0x404174C3 | isr3
[ 2296.827669] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 2296.827671] iwlwifi 0000:00:14.3: 0x0B82001C | last cmd Id
[ 2296.827672] iwlwifi 0000:00:14.3: 0x0001917E | wait_event
[ 2296.827673] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 2296.827675] iwlwifi 0000:00:14.3: 0x00481C00 | l2p_duration
[ 2296.827676] iwlwifi 0000:00:14.3: 0x0000003F | l2p_mhvalid
[ 2296.827678] iwlwifi 0000:00:14.3: 0x00000080 | l2p_addr_match
[ 2296.827679] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 2296.827681] iwlwifi 0000:00:14.3: 0x15120642 | timestamp
[ 2296.827682] iwlwifi 0000:00:14.3: 0x00009834 | flow_handler
[ 2296.827831] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2296.827833] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
[ 2296.827835] iwlwifi 0000:00:14.3: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL
[ 2296.827837] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 2296.827838] iwlwifi 0000:00:14.3: 0xC0088A3A | umac branchlink2
[ 2296.827840] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink1
[ 2296.827841] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink2
[ 2296.827842] iwlwifi 0000:00:14.3: 0x00000800 | umac data1
[ 2296.827844] iwlwifi 0000:00:14.3: 0xC0084458 | umac data2
[ 2296.827845] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 2296.827847] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 2296.827848] iwlwifi 0000:00:14.3: 0xEA3728EE | umac minor
[ 2296.827860] iwlwifi 0000:00:14.3: 0x001C7614 | frame pointer
[ 2296.827861] iwlwifi 0000:00:14.3: 0xC088627C | stack pointer
[ 2296.827862] iwlwifi 0000:00:14.3: 0x0068010C | last host cmd
[ 2296.827864] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 2296.827897] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 2296.827898] iwlwifi 0000:00:14.3: 0x00002324 | IML/ROM error/state
[ 2296.827928] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM data1
[ 2296.827944] iwlwifi 0000:00:14.3: Fseq Registers:
[ 2296.827952] iwlwifi 0000:00:14.3: 0x42878416 | FSEQ_ERROR_CODE
[ 2296.827961] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 2296.827969] iwlwifi 0000:00:14.3: 0x420C0F41 | FSEQ_CNVIO_INIT_VERSION
[ 2296.827977] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 2296.827986] iwlwifi 0000:00:14.3: 0xCF80F5DF | FSEQ_TOP_CONTENT_VERSION
[ 2296.827994] iwlwifi 0000:00:14.3: 0xDE91F59F | FSEQ_ALIVE_TOKEN
[ 2296.828002] iwlwifi 0000:00:14.3: 0x61B642DE | FSEQ_CNVI_ID
[ 2296.828011] iwlwifi 0000:00:14.3: 0x83BB9275 | FSEQ_CNVR_ID
[ 2296.828019] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 2296.828030] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 2296.828040] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 2296.828087] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 2296.828109] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 2299.076099] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 2299.076466] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2299.076468] iwlwifi 0000:00:14.3: Transport status: 0x0000004B, valid: 6
[ 2299.076470] iwlwifi 0000:00:14.3: Loaded firmware version: 46.ea3728ee.0 9000-pu-b0-jf-b0-46.ucode
[ 2299.076471] iwlwifi 0000:00:14.3: 0x00000034 | NMI_INTERRUPT_WDG
[ 2299.076473] iwlwifi 0000:00:14.3: 0x00A022F0 | trm_hw_status0
[ 2299.076474] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 2299.076475] iwlwifi 0000:00:14.3: 0x0048961A | branchlink2
[ 2299.076476] iwlwifi 0000:00:14.3: 0x0047905E | interruptlink1
[ 2299.076477] iwlwifi 0000:00:14.3: 0x00006CD0 | interruptlink2
[ 2299.076479] iwlwifi 0000:00:14.3: 0x0001B578 | data1
[ 2299.076480] iwlwifi 0000:00:14.3: 0x000003FF | data2
[ 2299.076481] iwlwifi 0000:00:14.3: 0x000003FF | data3
[ 2299.076482] iwlwifi 0000:00:14.3: 0x00801A2A | beacon time
[ 2299.076483] iwlwifi 0000:00:14.3: 0x8AED860F | tsf low
[ 2299.076484] iwlwifi 0000:00:14.3: 0x00000001 | tsf hi
[ 2299.076485] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 2299.076486] iwlwifi 0000:00:14.3: 0x00039407 | time gp2
[ 2299.076487] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 2299.076488] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 2299.076489] iwlwifi 0000:00:14.3: 0xEA3728EE | uCode version minor
[ 2299.076491] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 2299.076492] iwlwifi 0000:00:14.3: 0x00C89002 | board version
[ 2299.076493] iwlwifi 0000:00:14.3: 0x0000001C | hcmd
[ 2299.076494] iwlwifi 0000:00:14.3: 0x000230C0 | isr0
[ 2299.076495] iwlwifi 0000:00:14.3: 0x00040000 | isr1
[ 2299.076496] iwlwifi 0000:00:14.3: 0x08201802 | isr2
[ 2299.076497] iwlwifi 0000:00:14.3: 0x4041FDC1 | isr3
[ 2299.076498] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 2299.076499] iwlwifi 0000:00:14.3: 0x0031011D | last cmd Id
[ 2299.076500] iwlwifi 0000:00:14.3: 0x0001B578 | wait_event
[ 2299.076501] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 2299.076502] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
[ 2299.076503] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 2299.076504] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 2299.076505] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 2299.076506] iwlwifi 0000:00:14.3: 0x15120642 | timestamp
[ 2299.076507] iwlwifi 0000:00:14.3: 0x00003054 | flow_handler
[ 2299.076649] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2299.076649] iwlwifi 0000:00:14.3: Transport status: 0x0000004B, valid: 7
[ 2299.076651] iwlwifi 0000:00:14.3: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL
[ 2299.076652] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 2299.076653] iwlwifi 0000:00:14.3: 0xC0088A3A | umac branchlink2
[ 2299.076654] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink1
[ 2299.076655] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink2
[ 2299.076656] iwlwifi 0000:00:14.3: 0x00000800 | umac data1
[ 2299.076657] iwlwifi 0000:00:14.3: 0xC0084458 | umac data2
[ 2299.076658] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 2299.076659] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 2299.076660] iwlwifi 0000:00:14.3: 0xEA3728EE | umac minor
[ 2299.076661] iwlwifi 0000:00:14.3: 0x00039421 | frame pointer
[ 2299.076662] iwlwifi 0000:00:14.3: 0xC088627C | stack pointer
[ 2299.076664] iwlwifi 0000:00:14.3: 0x0034014E | last host cmd
[ 2299.076665] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 2299.076702] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 2299.076703] iwlwifi 0000:00:14.3: 0x00002323 | IML/ROM error/state
[ 2299.076734] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM data1
[ 2299.076750] iwlwifi 0000:00:14.3: Fseq Registers:
[ 2299.076758] iwlwifi 0000:00:14.3: 0x42878416 | FSEQ_ERROR_CODE
[ 2299.076766] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 2299.076775] iwlwifi 0000:00:14.3: 0x420C0F41 | FSEQ_CNVIO_INIT_VERSION
[ 2299.076783] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 2299.076791] iwlwifi 0000:00:14.3: 0xCF80F5DF | FSEQ_TOP_CONTENT_VERSION
[ 2299.076800] iwlwifi 0000:00:14.3: 0xDE91F59F | FSEQ_ALIVE_TOKEN
[ 2299.076808] iwlwifi 0000:00:14.3: 0x61B642DE | FSEQ_CNVI_ID
[ 2299.076816] iwlwifi 0000:00:14.3: 0x83BB9275 | FSEQ_CNVR_ID
[ 2299.076825] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 2299.076835] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 2299.076846] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 2299.076886] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 2299.076895] iwlwifi 0000:00:14.3: Firmware error during reconfiguration - reprobe!
[ 2299.076913] iwlwifi 0000:00:14.3: FW error in SYNC CMD ADD_STA
[ 2299.076990] iwl_trans_txq_send_hcmd+0x33d/0x450 [iwlwifi c86be1ad9ef928e27a2db3c7661e0b6ad287c66f]
[ 2299.077020] iwl_trans_send_cmd+0x98/0x100 [iwlwifi c86be1ad9ef928e27a2db3c7661e0b6ad287c66f]
[ 2299.077350] Modules linked in: rfcomm ccm nvidia_drm(POE) nvidia_modeset(POE) nvidia(POE) qrtr cmac algif_hash algif_skcipher af_alg bnep snd_sof_pci_intel_cnl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils soundwire_bus snd_soc_skl snd_hda_codec_realtek snd_soc_hdac_hda snd_hda_codec_generic snd_hda_ext_core ledtrig_audio snd_soc_sst_ipc iwlmvm intel_tcc_cooling snd_soc_sst_dsp snd_soc_acpi_intel_match x86_pkg_temp_thermal intel_powerclamp snd_soc_acpi coretemp mac80211 snd_soc_core kvm_intel vfat snd_compress ac97_bus mousedev libarc4 joydev fat btusb snd_hda_codec_hdmi kvm snd_pcm_dmaengine btrtl irqbypass i915 btbcm crct10dif_pclmul crc32_pclmul btintel snd_hda_intel polyval_clmulni iwlwifi polyval_generic snd_intel_dspcfg gf128mul snd_intel_sdw_acpi uvcvideo ghash_clmulni_intel btmtk snd_hda_codec videobuf2_vmalloc sha512_ssse3 processor_thermal_device_pci_legacy
[ 2299.077657] WARNING: CPU: 10 PID: 3549 at drivers/net/wireless/intel/iwlwifi/mvm/mac80211.c:3369 iwl_mvm_mac_sta_state+0x871/0x880 [iwlmvm]
[ 2299.077674] Modules linked in: rfcomm ccm nvidia_drm(POE) nvidia_modeset(POE) nvidia(POE) qrtr cmac algif_hash algif_skcipher af_alg bnep snd_sof_pci_intel_cnl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils soundwire_bus snd_soc_skl snd_hda_codec_realtek snd_soc_hdac_hda snd_hda_codec_generic snd_hda_ext_core ledtrig_audio snd_soc_sst_ipc iwlmvm intel_tcc_cooling snd_soc_sst_dsp snd_soc_acpi_intel_match x86_pkg_temp_thermal intel_powerclamp snd_soc_acpi coretemp mac80211 snd_soc_core kvm_intel vfat snd_compress ac97_bus mousedev libarc4 joydev fat btusb snd_hda_codec_hdmi kvm snd_pcm_dmaengine btrtl irqbypass i915 btbcm crct10dif_pclmul crc32_pclmul btintel snd_hda_intel polyval_clmulni iwlwifi polyval_generic snd_intel_dspcfg gf128mul snd_intel_sdw_acpi uvcvideo ghash_clmulni_intel btmtk snd_hda_codec videobuf2_vmalloc sha512_ssse3 processor_thermal_device_pci_legacy
[ 2299.078005] iwlwifi 0000:00:14.3: Failed to send MAC context (action:2): -5
[ 2299.078013] iwlwifi 0000:00:14.3: Failed to send MAC context (action:2): -5
[ 2299.078015] iwlwifi 0000:00:14.3: failed to update MAC 26:11:18:5e:39:a6
[ 2299.078018] iwlwifi 0000:00:14.3: Couldn't send TIME_EVENT_CMD: -5
[ 2299.078020] iwlwifi 0000:00:14.3: mcast filter cmd error. ret=-5
[ 2299.078021] iwlwifi 0000:00:14.3: Failed to synchronize multicast groups update
[ 2299.078034] WARNING: CPU: 10 PID: 3549 at drivers/net/wireless/intel/iwlwifi/mvm/mac80211.c:2491 iwl_mvm_bss_info_changed+0x402/0x6e0 [iwlmvm]
[ 2299.078049] Modules linked in: rfcomm ccm nvidia_drm(POE) nvidia_modeset(POE) nvidia(POE) qrtr cmac algif_hash algif_skcipher af_alg bnep snd_sof_pci_intel_cnl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils soundwire_bus snd_soc_skl snd_hda_codec_realtek snd_soc_hdac_hda snd_hda_codec_generic snd_hda_ext_core ledtrig_audio snd_soc_sst_ipc iwlmvm intel_tcc_cooling snd_soc_sst_dsp snd_soc_acpi_intel_match x86_pkg_temp_thermal intel_powerclamp snd_soc_acpi coretemp mac80211 snd_soc_core kvm_intel vfat snd_compress ac97_bus mousedev libarc4 joydev fat btusb snd_hda_codec_hdmi kvm snd_pcm_dmaengine btrtl irqbypass i915 btbcm crct10dif_pclmul crc32_pclmul btintel snd_hda_intel polyval_clmulni iwlwifi polyval_generic snd_intel_dspcfg gf128mul snd_intel_sdw_acpi uvcvideo ghash_clmulni_intel btmtk snd_hda_codec videobuf2_vmalloc sha512_ssse3 processor_thermal_device_pci_legacy
[ 2299.078348] iwlwifi 0000:00:14.3: failed to update power mode
[ 2299.078351] iwlwifi 0000:00:14.3: Failed to send MAC context (action:2): -5
[ 2299.078354] iwlwifi 0000:00:14.3: Failed to send MAC context (action:2): -5
[ 2299.078356] iwlwifi 0000:00:14.3: Failed to send MAC context (action:2): -5
[ 2299.078358] iwlwifi 0000:00:14.3: Failed to send MAC context (action:2): -5
[ 2299.078392] iwlwifi 0000:00:14.3: set key failed
[ 2299.078406] iwlwifi 0000:00:14.3: set key failed
[ 2299.078409] iwlwifi 0000:00:14.3: Failed to trigger RX queues sync (-5)
[ 2299.078411] iwlwifi 0000:00:14.3: Failed to trigger RX queues sync (-5)
[ 2299.104773] iwlwifi 0000:00:14.3: LED command failed: -5
[ 2299.104793] iwlwifi 0000:00:14.3: LED command failed: -5
[ 2299.154807] iwlwifi 0000:00:14.3: Failed to send flush command (-5)
[ 2299.154813] iwlwifi 0000:00:14.3: Failed to disable queue 2 (ret=-5)
[ 2299.154815] iwlwifi 0000:00:14.3: Failed to remove station. Id=2
[ 2299.154816] iwlwifi 0000:00:14.3: Failed sending remove station
[ 2299.154819] iwlwifi 0000:00:14.3: Failed to send binding (action:3): -5
[ 2299.154821] iwlwifi 0000:00:14.3: PHY ctxt cmd error. ret=-5
[ 2299.154824] iwlwifi 0000:00:14.3: Failed to remove MAC context: -5
[ 2299.154827] iwlwifi 0000:00:14.3: mcast filter cmd error. ret=-5
[ 2299.154829] iwlwifi 0000:00:14.3: Failed to synchronize multicast groups update
[ 2299.154843] iwlwifi 0000:00:14.3: Failed to send MAC context (action:2): -5
[ 2299.154845] iwlwifi 0000:00:14.3: failed to update MAC 26:11:18:5e:39:a6
[ 2299.154847] iwlwifi 0000:00:14.3: failed to update power mode
[ 2299.154863] iwlwifi 0000:00:14.3: Failed to send flush command (-5)
[ 2299.154864] iwlwifi 0000:00:14.3: flush request fail
[ 2299.154878] iwlwifi 0000:00:14.3: iwl_trans_wait_tx_queues_empty bad state = 0
[ 2299.154883] iwlwifi 0000:00:14.3: Failed to trigger RX queues sync (-5)
[ 2299.154898] iwlwifi 0000:00:14.3: Failed to send MAC context (action:2): -5
[ 2299.154915] WARNING: CPU: 10 PID: 80 at drivers/net/wireless/intel/iwlwifi/mvm/mac80211.c:3403 iwl_mvm_mac_sta_state+0x501/0x880 [iwlmvm]
[ 2299.154937] Modules linked in: rfcomm ccm nvidia_drm(POE) nvidia_modeset(POE) nvidia(POE) qrtr cmac algif_hash algif_skcipher af_alg bnep snd_sof_pci_intel_cnl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils soundwire_bus snd_soc_skl snd_hda_codec_realtek snd_soc_hdac_hda snd_hda_codec_generic snd_hda_ext_core ledtrig_audio snd_soc_sst_ipc iwlmvm intel_tcc_cooling snd_soc_sst_dsp snd_soc_acpi_intel_match x86_pkg_temp_thermal intel_powerclamp snd_soc_acpi coretemp mac80211 snd_soc_core kvm_intel vfat snd_compress ac97_bus mousedev libarc4 joydev fat btusb snd_hda_codec_hdmi kvm snd_pcm_dmaengine btrtl irqbypass i915 btbcm crct10dif_pclmul crc32_pclmul btintel snd_hda_intel polyval_clmulni iwlwifi polyval_generic snd_intel_dspcfg gf128mul snd_intel_sdw_acpi uvcvideo ghash_clmulni_intel btmtk snd_hda_codec videobuf2_vmalloc sha512_ssse3 processor_thermal_device_pci_legacy
[ 2299.155515] ? __iwl_err+0x170/0x180 [iwlwifi c86be1ad9ef928e27a2db3c7661e0b6ad287c66f]
[ 2299.155678] iwl_drv_stop+0x38/0xf0 [iwlwifi c86be1ad9ef928e27a2db3c7661e0b6ad287c66f]
[ 2299.155693] iwl_pci_remove+0x1a/0x30 [iwlwifi c86be1ad9ef928e27a2db3c7661e0b6ad287c66f]
[ 2299.155824] Modules linked in: rfcomm ccm nvidia_drm(POE) nvidia_modeset(POE) nvidia(POE) qrtr cmac algif_hash algif_skcipher af_alg bnep snd_sof_pci_intel_cnl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils soundwire_bus snd_soc_skl snd_hda_codec_realtek snd_soc_hdac_hda snd_hda_codec_generic snd_hda_ext_core ledtrig_audio snd_soc_sst_ipc iwlmvm intel_tcc_cooling snd_soc_sst_dsp snd_soc_acpi_intel_match x86_pkg_temp_thermal intel_powerclamp snd_soc_acpi coretemp mac80211 snd_soc_core kvm_intel vfat snd_compress ac97_bus mousedev libarc4 joydev fat btusb snd_hda_codec_hdmi kvm snd_pcm_dmaengine btrtl irqbypass i915 btbcm crct10dif_pclmul crc32_pclmul btintel snd_hda_intel polyval_clmulni iwlwifi polyval_generic snd_intel_dspcfg gf128mul snd_intel_sdw_acpi uvcvideo ghash_clmulni_intel btmtk snd_hda_codec videobuf2_vmalloc sha512_ssse3 processor_thermal_device_pci_legacy
[ 2299.156282] ? __iwl_err+0x170/0x180 [iwlwifi c86be1ad9ef928e27a2db3c7661e0b6ad287c66f]
[ 2299.156446] iwl_drv_stop+0x38/0xf0 [iwlwifi c86be1ad9ef928e27a2db3c7661e0b6ad287c66f]
[ 2299.156462] iwl_pci_remove+0x1a/0x30 [iwlwifi c86be1ad9ef928e27a2db3c7661e0b6ad287c66f]
[ 2299.156575] iwlwifi 0000:00:14.3: Failed to send MAC context (action:2): -5
[ 2299.156577] iwlwifi 0000:00:14.3: failed to update MAC 26:11:18:5e:39:a6
[ 2299.156591] WARNING: CPU: 10 PID: 80 at drivers/net/wireless/intel/iwlwifi/mvm/mac80211.c:2414 iwl_mvm_bss_info_changed+0x6ce/0x6e0 [iwlmvm]
[ 2299.156605] Modules linked in: rfcomm ccm nvidia_drm(POE) nvidia_modeset(POE) nvidia(POE) qrtr cmac algif_hash algif_skcipher af_alg bnep snd_sof_pci_intel_cnl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils soundwire_bus snd_soc_skl snd_hda_codec_realtek snd_soc_hdac_hda snd_hda_codec_generic snd_hda_ext_core ledtrig_audio snd_soc_sst_ipc iwlmvm intel_tcc_cooling snd_soc_sst_dsp snd_soc_acpi_intel_match x86_pkg_temp_thermal intel_powerclamp snd_soc_acpi coretemp mac80211 snd_soc_core kvm_intel vfat snd_compress ac97_bus mousedev libarc4 joydev fat btusb snd_hda_codec_hdmi kvm snd_pcm_dmaengine btrtl irqbypass i915 btbcm crct10dif_pclmul crc32_pclmul btintel snd_hda_intel polyval_clmulni iwlwifi polyval_generic snd_intel_dspcfg gf128mul snd_intel_sdw_acpi uvcvideo ghash_clmulni_intel btmtk snd_hda_codec videobuf2_vmalloc sha512_ssse3 processor_thermal_device_pci_legacy
[ 2299.157027] ? __iwl_err+0x170/0x180 [iwlwifi c86be1ad9ef928e27a2db3c7661e0b6ad287c66f]
[ 2299.157187] iwl_drv_stop+0x38/0xf0 [iwlwifi c86be1ad9ef928e27a2db3c7661e0b6ad287c66f]
[ 2299.157203] iwl_pci_remove+0x1a/0x30 [iwlwifi c86be1ad9ef928e27a2db3c7661e0b6ad287c66f]
[ 2299.157259] iwlwifi 0000:00:14.3: Failed to remove station. Id=0
[ 2299.157261] iwlwifi 0000:00:14.3: failed to remove AP station
[ 2299.157262] iwlwifi 0000:00:14.3: Failed to send MAC context (action:2): -5
[ 2299.157264] iwlwifi 0000:00:14.3: failed to update MAC 26:11:18:5e:39:a6 (clear after unassoc)
[ 2299.157265] iwlwifi 0000:00:14.3: Failed to synchronize multicast groups update
[ 2299.157270] iwlwifi 0000:00:14.3: failed to update power mode
[ 2299.157275] iwlwifi 0000:00:14.3: Failed to send binding (action:3): -5
[ 2299.157277] iwlwifi 0000:00:14.3: Failed to send MAC context (action:2): -5
[ 2299.157278] iwlwifi 0000:00:14.3: failed to update MAC 26:11:18:5e:39:a6
[ 2299.157281] iwlwifi 0000:00:14.3: PHY ctxt cmd error. ret=-5
[ 2299.157282] iwlwifi 0000:00:14.3: iwl_trans_wait_tx_queues_empty bad state = 0
[ 2299.178183] iwlwifi 0000:00:14.3: Failed to remove MAC context: -5
[ 2299.178192] iwlwifi 0000:00:14.3: Failed to disable queue 1 (ret=-5)
[ 2299.178194] iwlwifi 0000:00:14.3: Failed to remove station. Id=1
[ 2299.178195] iwlwifi 0000:00:14.3: Failed sending remove station
[ 2299.440463] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 2299.440467] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 2299.440469] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 2299.440470] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 2299.440471] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 2299.440472] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 2299.440474] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 2299.440475] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 2299.440476] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 2299.440477] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 2299.440478] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 2299.440479] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 2299.440480] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 2299.440481] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 2299.440482] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 2299.440483] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 2299.440484] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 2299.440764] iwlwifi 0000:00:14.3: loaded firmware version 46.ea3728ee.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[ 2299.443718] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz, REV=0x312
[ 2299.494325] iwlwifi 0000:00:14.3: base HW address: 90:78:41:e3:06:f7, OTP minor version: 0x4
[ 2299.747098] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 2299.747458] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2299.747460] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
[ 2299.747462] iwlwifi 0000:00:14.3: Loaded firmware version: 46.ea3728ee.0 9000-pu-b0-jf-b0-46.ucode
[ 2299.747464] iwlwifi 0000:00:14.3: 0x00000034 | NMI_INTERRUPT_WDG
[ 2299.747466] iwlwifi 0000:00:14.3: 0x002022F0 | trm_hw_status0
[ 2299.747467] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 2299.747468] iwlwifi 0000:00:14.3: 0x00021C04 | branchlink2
[ 2299.747469] iwlwifi 0000:00:14.3: 0x000235A2 | interruptlink1
[ 2299.747470] iwlwifi 0000:00:14.3: 0x0000D320 | interruptlink2
[ 2299.747472] iwlwifi 0000:00:14.3: 0x0000D326 | data1
[ 2299.747473] iwlwifi 0000:00:14.3: 0x000003FF | data2
[ 2299.747474] iwlwifi 0000:00:14.3: 0x000003FF | data3
[ 2299.747475] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 2299.747476] iwlwifi 0000:00:14.3: 0x0003FD49 | tsf low
[ 2299.747477] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 2299.747478] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 2299.747479] iwlwifi 0000:00:14.3: 0x0003FD4A | time gp2
[ 2299.747481] iwlwifi 0000:00:14.3: 0x00000009 | uCode revision type
[ 2299.747482] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 2299.747483] iwlwifi 0000:00:14.3: 0xEA3728EE | uCode version minor
[ 2299.747484] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 2299.747485] iwlwifi 0000:00:14.3: 0x18C89002 | board version
[ 2299.747486] iwlwifi 0000:00:14.3: 0x000F016A | hcmd
[ 2299.747487] iwlwifi 0000:00:14.3: 0x82023080 | isr0
[ 2299.747488] iwlwifi 0000:00:14.3: 0x10884000 | isr1
[ 2299.747489] iwlwifi 0000:00:14.3: 0x28201802 | isr2
[ 2299.747490] iwlwifi 0000:00:14.3: 0x404001DC | isr3
[ 2299.747491] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 2299.747492] iwlwifi 0000:00:14.3: 0x000F016A | last cmd Id
[ 2299.747494] iwlwifi 0000:00:14.3: 0x0000D326 | wait_event
[ 2299.747495] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 2299.747496] iwlwifi 0000:00:14.3: 0x00000020 | l2p_duration
[ 2299.747497] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 2299.747498] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 2299.747499] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 2299.747500] iwlwifi 0000:00:14.3: 0x15120642 | timestamp
[ 2299.747501] iwlwifi 0000:00:14.3: 0x00000830 | flow_handler
[ 2299.747650] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2299.747652] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
[ 2299.747653] iwlwifi 0000:00:14.3: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL
[ 2299.747655] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 2299.747657] iwlwifi 0000:00:14.3: 0xC0088A3A | umac branchlink2
[ 2299.747659] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink1
[ 2299.747661] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink2
[ 2299.747662] iwlwifi 0000:00:14.3: 0x00000800 | umac data1
[ 2299.747664] iwlwifi 0000:00:14.3: 0xC0084458 | umac data2
[ 2299.747665] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 2299.747667] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 2299.747669] iwlwifi 0000:00:14.3: 0xEA3728EE | umac minor
[ 2299.747670] iwlwifi 0000:00:14.3: 0x0003FD68 | frame pointer
[ 2299.747672] iwlwifi 0000:00:14.3: 0xC088627C | stack pointer
[ 2299.747674] iwlwifi 0000:00:14.3: 0x000F016A | last host cmd
[ 2299.747675] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 2299.747713] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 2299.747714] iwlwifi 0000:00:14.3: 0x00002324 | IML/ROM error/state
[ 2299.747745] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM data1
[ 2299.747760] iwlwifi 0000:00:14.3: Fseq Registers:
[ 2299.747769] iwlwifi 0000:00:14.3: 0x42878416 | FSEQ_ERROR_CODE
[ 2299.747777] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 2299.747786] iwlwifi 0000:00:14.3: 0x420C0F41 | FSEQ_CNVIO_INIT_VERSION
[ 2299.747794] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 2299.747802] iwlwifi 0000:00:14.3: 0xCF80F5DF | FSEQ_TOP_CONTENT_VERSION
[ 2299.747811] iwlwifi 0000:00:14.3: 0xDE91F59F | FSEQ_ALIVE_TOKEN
[ 2299.747819] iwlwifi 0000:00:14.3: 0x61B642DE | FSEQ_CNVI_ID
[ 2299.747827] iwlwifi 0000:00:14.3: 0x83BB9275 | FSEQ_CNVR_ID
[ 2299.747836] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 2299.747846] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 2299.747857] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 2299.747898] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 2299.747945] iwlwifi 0000:00:14.3: Failed to run INIT calibrations: -5
[ 2299.747950] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 2301.465968] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -5
[ 2301.479522] iwlwifi 0000:00:14.3: retry init count 0
[ 2301.482173] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz, REV=0x312
[ 2301.532770] iwlwifi 0000:00:14.3: base HW address: 90:78:41:e3:06:f7, OTP minor version: 0x4
[ 2301.733468] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 2301.733836] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2301.733838] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
[ 2301.733841] iwlwifi 0000:00:14.3: Loaded firmware version: 46.ea3728ee.0 9000-pu-b0-jf-b0-46.ucode
[ 2301.733844] iwlwifi 0000:00:14.3: 0x00000034 | NMI_INTERRUPT_WDG
[ 2301.733846] iwlwifi 0000:00:14.3: 0x000022F0 | trm_hw_status0
[ 2301.733847] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 2301.733848] iwlwifi 0000:00:14.3: 0x00021C04 | branchlink2
[ 2301.733849] iwlwifi 0000:00:14.3: 0x000235A2 | interruptlink1
[ 2301.733851] iwlwifi 0000:00:14.3: 0x0001FF1C | interruptlink2
[ 2301.733852] iwlwifi 0000:00:14.3: 0x0000D326 | data1
[ 2301.733853] iwlwifi 0000:00:14.3: 0x000003FF | data2
[ 2301.733854] iwlwifi 0000:00:14.3: 0x000003FF | data3
[ 2301.733855] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 2301.733856] iwlwifi 0000:00:14.3: 0x00033312 | tsf low
[ 2301.733857] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 2301.733858] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 2301.733859] iwlwifi 0000:00:14.3: 0x00033312 | time gp2
[ 2301.733860] iwlwifi 0000:00:14.3: 0x00000009 | uCode revision type
[ 2301.733861] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 2301.733863] iwlwifi 0000:00:14.3: 0xEA3728EE | uCode version minor
[ 2301.733864] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 2301.733865] iwlwifi 0000:00:14.3: 0x18C89002 | board version
[ 2301.733866] iwlwifi 0000:00:14.3: 0x000F016A | hcmd
[ 2301.733867] iwlwifi 0000:00:14.3: 0x00022080 | isr0
[ 2301.733868] iwlwifi 0000:00:14.3: 0x10800000 | isr1
[ 2301.733869] iwlwifi 0000:00:14.3: 0x28201802 | isr2
[ 2301.733870] iwlwifi 0000:00:14.3: 0x404001C0 | isr3
[ 2301.733871] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 2301.733872] iwlwifi 0000:00:14.3: 0x000F016A | last cmd Id
[ 2301.733873] iwlwifi 0000:00:14.3: 0x0000D326 | wait_event
[ 2301.733875] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 2301.733876] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
[ 2301.733877] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 2301.733878] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 2301.733879] iwlwifi 0000:00:14.3: 0x0000008F | lmpm_pmg_sel
[ 2301.733880] iwlwifi 0000:00:14.3: 0x15120642 | timestamp
[ 2301.733881] iwlwifi 0000:00:14.3: 0x00000830 | flow_handler
[ 2301.734030] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2301.734032] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
[ 2301.734034] iwlwifi 0000:00:14.3: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL
[ 2301.734035] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 2301.734036] iwlwifi 0000:00:14.3: 0xC0088A3A | umac branchlink2
[ 2301.734037] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink1
[ 2301.734039] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink2
[ 2301.734040] iwlwifi 0000:00:14.3: 0x00000800 | umac data1
[ 2301.734041] iwlwifi 0000:00:14.3: 0xC0084458 | umac data2
[ 2301.734042] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 2301.734043] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 2301.734044] iwlwifi 0000:00:14.3: 0xEA3728EE | umac minor
[ 2301.734045] iwlwifi 0000:00:14.3: 0x00033330 | frame pointer
[ 2301.734046] iwlwifi 0000:00:14.3: 0xC088627C | stack pointer
[ 2301.734047] iwlwifi 0000:00:14.3: 0x000F016A | last host cmd
[ 2301.734048] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 2301.734085] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 2301.734086] iwlwifi 0000:00:14.3: 0x00002324 | IML/ROM error/state
[ 2301.734117] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM data1
[ 2301.734133] iwlwifi 0000:00:14.3: Fseq Registers:
[ 2301.734141] iwlwifi 0000:00:14.3: 0x42878416 | FSEQ_ERROR_CODE
[ 2301.734150] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 2301.734158] iwlwifi 0000:00:14.3: 0x420C0F41 | FSEQ_CNVIO_INIT_VERSION
[ 2301.734166] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 2301.734174] iwlwifi 0000:00:14.3: 0xCF80F5DF | FSEQ_TOP_CONTENT_VERSION
[ 2301.734183] iwlwifi 0000:00:14.3: 0xDE91F59F | FSEQ_ALIVE_TOKEN
[ 2301.734191] iwlwifi 0000:00:14.3: 0x61B642DE | FSEQ_CNVI_ID
[ 2301.734207] iwlwifi 0000:00:14.3: 0x83BB9275 | FSEQ_CNVR_ID
[ 2301.734221] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 2301.734232] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 2301.734243] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 2301.734284] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 2301.734300] iwlwifi 0000:00:14.3: Failed to run INIT calibrations: -5
[ 2301.734305] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 2303.457671] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -5
[ 2303.471173] iwlwifi 0000:00:14.3: retry init count 1
[ 2303.473420] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz, REV=0x312
[ 2303.524375] iwlwifi 0000:00:14.3: base HW address: 90:78:41:e3:06:f7, OTP minor version: 0x4
[ 2303.776594] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 2303.776954] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2303.776955] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
[ 2303.776957] iwlwifi 0000:00:14.3: Loaded firmware version: 46.ea3728ee.0 9000-pu-b0-jf-b0-46.ucode
[ 2303.776958] iwlwifi 0000:00:14.3: 0x00000034 | NMI_INTERRUPT_WDG
[ 2303.776959] iwlwifi 0000:00:14.3: 0x002022F0 | trm_hw_status0
[ 2303.776960] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 2303.776961] iwlwifi 0000:00:14.3: 0x00021C04 | branchlink2
[ 2303.776962] iwlwifi 0000:00:14.3: 0x000235A2 | interruptlink1
[ 2303.776963] iwlwifi 0000:00:14.3: 0x0000D320 | interruptlink2
[ 2303.776964] iwlwifi 0000:00:14.3: 0x0000D326 | data1
[ 2303.776965] iwlwifi 0000:00:14.3: 0x000003FF | data2
[ 2303.776966] iwlwifi 0000:00:14.3: 0x000003FF | data3
[ 2303.776966] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 2303.776967] iwlwifi 0000:00:14.3: 0x0003FBA9 | tsf low
[ 2303.776968] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 2303.776969] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 2303.776970] iwlwifi 0000:00:14.3: 0x0003FBAA | time gp2
[ 2303.776971] iwlwifi 0000:00:14.3: 0x00000009 | uCode revision type
[ 2303.776972] iwlwifi 0000:00:14.3: 0x0000002E | uCode version major
[ 2303.776973] iwlwifi 0000:00:14.3: 0xEA3728EE | uCode version minor
[ 2303.776973] iwlwifi 0000:00:14.3: 0x00000312 | hw version
[ 2303.776974] iwlwifi 0000:00:14.3: 0x18C89002 | board version
[ 2303.776975] iwlwifi 0000:00:14.3: 0x000F016A | hcmd
[ 2303.776976] iwlwifi 0000:00:14.3: 0x80023080 | isr0
[ 2303.776977] iwlwifi 0000:00:14.3: 0x10800000 | isr1
[ 2303.776978] iwlwifi 0000:00:14.3: 0x28201802 | isr2
[ 2303.776979] iwlwifi 0000:00:14.3: 0x404001DC | isr3
[ 2303.776979] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 2303.776980] iwlwifi 0000:00:14.3: 0x000F016A | last cmd Id
[ 2303.776981] iwlwifi 0000:00:14.3: 0x0000D326 | wait_event
[ 2303.776982] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 2303.776983] iwlwifi 0000:00:14.3: 0x00000020 | l2p_duration
[ 2303.776984] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 2303.776984] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 2303.776985] iwlwifi 0000:00:14.3: 0x0000000D | lmpm_pmg_sel
[ 2303.776986] iwlwifi 0000:00:14.3: 0x15120642 | timestamp
[ 2303.776987] iwlwifi 0000:00:14.3: 0x00000830 | flow_handler
[ 2303.777135] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 2303.777136] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
[ 2303.777137] iwlwifi 0000:00:14.3: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL
[ 2303.777138] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 2303.777139] iwlwifi 0000:00:14.3: 0xC0088A3A | umac branchlink2
[ 2303.777140] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink1
[ 2303.777141] iwlwifi 0000:00:14.3: 0xC0084458 | umac interruptlink2
[ 2303.777141] iwlwifi 0000:00:14.3: 0x00000800 | umac data1
[ 2303.777142] iwlwifi 0000:00:14.3: 0xC0084458 | umac data2
[ 2303.777143] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[ 2303.777144] iwlwifi 0000:00:14.3: 0x0000002E | umac major
[ 2303.777145] iwlwifi 0000:00:14.3: 0xEA3728EE | umac minor
[ 2303.777146] iwlwifi 0000:00:14.3: 0x0003FBC8 | frame pointer
[ 2303.777146] iwlwifi 0000:00:14.3: 0xC088627C | stack pointer
[ 2303.777147] iwlwifi 0000:00:14.3: 0x000F016A | last host cmd
[ 2303.777148] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 2303.777189] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 2303.777190] iwlwifi 0000:00:14.3: 0x00002323 | IML/ROM error/state
[ 2303.777221] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM data1
[ 2303.777237] iwlwifi 0000:00:14.3: Fseq Registers:
[ 2303.777245] iwlwifi 0000:00:14.3: 0x42878416 | FSEQ_ERROR_CODE
[ 2303.777254] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 2303.777262] iwlwifi 0000:00:14.3: 0x420C0F41 | FSEQ_CNVIO_INIT_VERSION
[ 2303.777270] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 2303.777279] iwlwifi 0000:00:14.3: 0xCF80F5DF | FSEQ_TOP_CONTENT_VERSION
[ 2303.777287] iwlwifi 0000:00:14.3: 0xDE91F59F | FSEQ_ALIVE_TOKEN
[ 2303.777295] iwlwifi 0000:00:14.3: 0x61B642DE | FSEQ_CNVI_ID
[ 2303.777304] iwlwifi 0000:00:14.3: 0x83BB9275 | FSEQ_CNVR_ID
[ 2303.777312] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[ 2303.777322] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 2303.777333] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 2303.777374] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 2303.777421] iwlwifi 0000:00:14.3: Failed to run INIT calibrations: -5
[ 2303.777425] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 2305.508259] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -5
[ 2305.521463] iwlwifi 0000:00:14.3: retry init count 2```
j8a
May 6, 2023, 7:28pm
4
Hi @kahtras ,
I wonder whether you could post the output of the following terminal command, in order to give you a hint. When I searched in the forum for the wifi card they were multiple solutions depending on the hardware of the machine.
inxi -Fazy
You can also search yourself an see what it is the best answer to your particular problem.
Regards,
output of inxi -Fazy
Kernel: 5.15.108-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=d22606d0-04d4-4486-9e44-72c3294fa307 rw quiet splash apparmor=1
security=apparmor resume=UUID=79cff705-3cad-464c-ac83-09e69e5e93f8
udev.log_priority=3
Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
Mobo: HP model: 8575 v: 21.17 serial: <superuser required> UEFI: AMI
v: F.27 date: 03/22/2023
ID-1: BAT0 charge: 49.4 Wh (97.1%) condition: 50.9/50.9 Wh (100.0%)
volts: 13.2 min: 11.6 model: HP Primary type: Li-ion serial: N/A
status: charging
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4328 high: 4500 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 4401 2: 4433 3: 4298
4: 4500 5: 4401 6: 4287 7: 4174 8: 3888 9: 4398 10: 4285 11: 4399 12: 4478
bogomips: 62431
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
ports: active: none off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 530.41.03
alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none off: DP-2
empty: HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 05c8:03bc class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915,nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-2 mapped: DP-0 note: disabled pos: primary
model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2022 res: 1920x1080
hz: 144 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled model: AU Optronics 0x23ed
built: 2018 res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX
1650/PCIe/SSE2 direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
API: ALSA v: k5.15.108-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: enp0s20f0u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Device-2: OPPO SM8150_Plus-MTP _SN:CC9C6EAA type: USB driver: rndis_host
v: kernel bus-ID: 1-2:12 chip-ID: 22d9:276a class-ID: 0a00 serial: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 704.24 GiB used: 101.9 GiB (14.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: AGHA4101 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 023 scheme: GPT
ID-1: / raw-size: 212.57 GiB size: 208.18 GiB (97.93%)
used: 101.89 GiB (48.9%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 1.02 GiB size: 1.02 GiB (99.80%)
used: 312 KiB (0.0%) fs: vfat dev: /dev/sda5 maj-min: 8:5
ID-1: swap-1 type: partition size: 8.01 GiB used: 10.8 MiB (0.1%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 64.0 C pch: 67.0 C mobo: N/A gpu: nvidia temp: 48 C
Processes: 341 Uptime: 2h 59m wakeups: 9 Memory: 15.43 GiB
used: 3.17 GiB (20.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1280 libs: 317 tools: gnome-software,pamac,yay pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.26
I have tried downgrading iwlwifi firmware >> no help
disable certain settings on wifi card >> no help
options iwlwifi 11n_disable=1
options iwlwifi swcrypto=0
options iwlwifi bt_coex_active=0
options iwlwifi power_save=0
options iwlwifi uapsd_disable=1
options iwlmvm power_scheme=1
Tried changing kernels. Updated the bios version to latest. >> no help
I am getting a donor wifi chip (intel AX210NGW) from a friend and will try it out on my system, this will confirm if my hardware is faulty or its firmware problem. >> pending (will update this)
Everything was fine until Thursday. I was running kernel 5.15 LTS / gnome. But my disk was full, So i performed a fresh installation using latest ISO that shipped with kernel 6.1 LTS. Since then i am facing this wifi issue. I tried downgrading to kernel 5.15 LTS its of no help. Power profiles don’t work on kernel 6.1 but works on 5.15 and 6.2. As for wifi its not working
sudo modprobe -rv iwlmvm & sudo modprobe iwlwifi
using above command i don’t need to restart my system for wifi connectivity. (Partial fix)
still its annoying to do it every time wifi fails.
Three separate ideas …
Power off cold boot may help.
Done a system upgrade since the ISO install?
Maybe downgrade the package with the iwlwifi driver? As a temporary diagnostic.
Have you tried loading the modules at boot? See section 2.1 here:
https://wiki.archlinux.org/title/Kernel_module
Olli
May 7, 2023, 4:35am
8
hello @kahtras
the 9560 has some hints. i owe such a module too and the problem is that there are different firmware-versions existing. please use the package manager and search for (it’s in the aur packages)
“iwlwifi-next”
this will upgrade the firmware of the 9560-module. please install this first to make sure the module is up-to-date. check if this solves your problem. my experience is the following:
the module combines a wifi and bluetooth device and they interfere. you can adjust several kernel options to adjust this behaviour, but first update the firmware and check it first. doing firmware updates and changes of the options at the same time isn’t a good. too much changes at the same time isn’t a good advice.
I will try cold boot.
No new packages / just downgraded the kernel to 5.15 as power profiles were not working with 6.1
tried downgrading iwlwifi driver no help
Hello Everyone,
I am closing this thread as WiFi is working fine. WiFi only crashing when i am playing games via steam (csgo / dota2). Going for CAT 6A cable and will route it to my desk. Hope in future updates this will get fixed.
Thank you Everyone for support.
system
Closed
May 9, 2023, 11:20pm
11
