I’m trying to get virtual terminals working on my computer, that is, the ability to hit ctrl-alt-f3
and get a nice text-mode terminal. On kernel 5.15.120-1, this is exactly what happens! Problem solved!
On newer terminals, from 6.0 through 6.3, this does not happen. It returns me to the boot log screen which is displaying the /dev/nvme0n1p2: clean,
message. Hitting enter does nothing; changing to other terminals does nothing; with the exception of ctrl-alt-f2
which cheerily drops me back in the GUI.
I would like actual virtual terminals.
I’m not sure what information here might be useful. In the absence of good ideas, here’s an inxi dump:
> inxi -Fazy
Kernel: 5.15.120-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=5c10c4bd-3163-4c75-87aa-2ca4d0df4d05 rw quiet
udev.log_priority=3 iommu=pt
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop System: Gigabyte product: B650M AORUS ELITE AX v: -CF
serial: <superuser required>
Mobo: Gigabyte model: B650M AORUS ELITE AX v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F6a
date: 05/18/2023
Info: model: AMD Ryzen 9 7950X bits: 64 type: MT MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3014 high: 4981 min/max: 3000/5880 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4981 2: 2857
3: 2754 4: 2812 5: 2880 6: 2778 7: 2758 8: 2775 9: 2994 10: 2994 11: 2992
12: 2994 13: 2994 14: 2992 15: 2993 16: 2994 17: 3755 18: 2867 19: 3019
20: 2907 21: 2865 22: 2874 23: 2834 24: 2871 25: 2994 26: 2993 27: 2984
28: 2994 29: 2992 30: 2987 31: 2993 32: 2998 bogomips: 287572
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: eVga.com.
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1e81 class-ID: 0300
Device-2: AMD Raphael vendor: Gigabyte driver: N/A arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 10:00.0 chip-ID: 1002:164e class-ID: 0300
Device-3: Valve 3D Camera driver: uvcvideo type: USB rev: 3.2 speed: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.1:3 chip-ID: 28de:2400 class-ID: 0e02
serial: <filter>
Device-4: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4.2.2:15
chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 5760x2680 s-dpi: 86 s-size: 1702x792mm (67.01x31.18")
s-diag: 1877mm (73.91")
Monitor-1: DP-3 pos: bottom-l res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-2: DP-4 pos: primary,top-center res: 2560x1600 hz: 60 dpi: 101
size: 641x400mm (25.24x15.75") diag: 756mm (29.75") modes: N/A
Monitor-3: HDMI-0 pos: bottom-r res: 1280x1024 hz: 60 dpi: 86
size: 376x301mm (14.8x11.85") diag: 482mm (18.96") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX 2080
SUPER/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f8 class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1
chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Valve VR Radio driver: cdc_acm,hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.3.2:5
chip-ID: 28de:2102 class-ID: 0a00 serial: <filter>
Device-5: Valve VR Radio & HMD Mic driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.3.3:6
chip-ID: 28de:2102 class-ID: 0102 serial: <filter>
Device-6: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
API: ALSA v: k5.15.120-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: N/A modules: mt7921e pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 0d:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF-ID-1: br-003f6cfda017 state: down mac: <filter>
IF-ID-2: br-14c0a2a1859a state: down mac: <filter>
IF-ID-3: br-329d1eb5f232 state: down mac: <filter>
IF-ID-4: br-632c89a21363 state: down mac: <filter>
IF-ID-5: br-b0b038dd53df state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-6: br-b8ec5c39e582 state: down mac: <filter>
IF-ID-7: br0 state: down mac: <filter>
IF-ID-8: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-9: veth0cfc5bf state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-10: veth24383d7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: virbr0 state: down mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 3-4.4.1:14 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 20.01 TiB used: 7.59 TiB (37.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS3140 4TB SSD
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: CS314314 temp: 39.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM000-1F2168
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CC52 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD140EDGZ-11B1PA0 size: 12.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 0A85 scheme: GPT
ID-1: / raw-size: 3.64 TiB size: 3.58 TiB (98.40%) used: 885.52 GiB (24.2%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile32g
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 47 C
Processes: 580 Uptime: 6m wakeups: 2 Memory: total: 64 GiB
available: 61.96 GiB used: 5.74 GiB (9.3%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1783 pm: pacman pkgs: 1730 libs: 470 tools: pamac pm: flatpak
pkgs: 39 pm: snap pkgs: 14 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.28
I’ve looked through dmesg and boy is there a lot of stuff in there but nothing that seems applicable. Suggestions welcome, though!
As an addendum, and the reason I’m coming back to this, Wayland exhibits behavior that may be related; on 5.15 it simply appears to crash and return to user login, on versions above it drops straight into to the same boot log screen. In that case I can’t figure out a way to return to anything usable and end up having to hard-reboot the computer, which I always hate doing. In this case, the one suspicious thing is that dmesg suggests that wayland is using the amdgpu
driver, which it should not be using. I’m not sure how to fix this, nor am I entirely sure this is the same problem.
