[求助]无法安装intel+nVidia混合驱动
在安装video- hybrid -intel-nvidia-bumblebee后,重启时无法开机。并且风扇狂转。
电脑是华硕FX53VD
显卡是Intel 630 和 GTX1050
有什么解决方法吗?
欢迎来到论坛
Welcome at the forum,
看看这里
have a look here:
https://wiki.manjaro.org/index.php?title=Configure_Graphics_Cards
你好
Hello,
我尝试过使用sudo mhwd -a pci nonfree 0300或者sudo mhwd -i pci video- hybrid -intel-nvidia-bumblebee安装驱动
I tried installing the driver using sudo mhwd -a pci nonfree 0300 or sudo mhwd -i pci video- hybrid -intel-nvidia-bumblebee
但是在重启时依然会出现卡死的情况
But when I restart, the computer will be stuck.
我觉得你的命令中有一个错字。
先试试这个
I think you have a typo in the command, try this one first:
video-hybrid-intel-nvidia-bumblebee
另外,请输入
Also, please enter
sudo mhwd -li
and
sudo mhwd -l -d --pci
并在此处发布输出。
and post output here.
这个链接也值得一读:
It's also worth reading this link:
~ sudo mhwd -li
Installed PCI configs:
     network-r8168            2016.04.20                true            PCI
~ sudo mhwd -l -d --pci
PCI Device: /devices/pci0000:00/0000:00:1c.3/0000:03:00.0 (0200:10ec:8168)
Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
INSTALLED:
ATTACHED: PCI
VERSION: 2016.04.20
INFO: RealTek RTL-8168 Gigabit Ethernet driver
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0200
VENDORIDS: 1186 10ec
AVAILABLE:
ATTACHED: PCI
VERSION: 2016.04.20
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0200
PCI Device: /devices/pci0000:00/0000:00:01.0/0000:01:00.0 (0302:10de:1c8d)
Display controller nVidia Corporation GP107M [GeForce GTX 1050 Mobile]
AVAILABLE:
ATTACHED: PCI
VERSION: 2018.08.09
INFO: Hybrid bumblebee solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 8
FREEDRIVER: false
DEPENDS: -
CONFLICTS: video-intel video-nvidia video-nvidia-304xx video-nvidia-340xx video-nvidia-390xx video-hybrid-intel-nvidia-390xx-bumblebee video-hybrid-intel-nouveau-bumblebee
CLASSIDS: 0300 0302 0300
VENDORIDS: 10de 8086
ATTACHED: PCI
VERSION: 2018.08.09
PRIORITY: 7
FREEDRIVER: false
DEPENDS: -
CONFLICTS: video-intel video-nvidia video-nvidia-304xx video-nvidia-340xx video-nvidia-390xx video-hybrid-intel-nvidia-bumblebee video-hybrid-intel-nouveau-bumblebee
ATTACHED: PCI
VERSION: 2018.08.09
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
CONFLICTS: video-hybrid-intel-nvidia-bumblebee video-hybrid-intel-nvidia-390xx-bumblebee video-nvidia-304xx video-nvidia-340xx video-nvidia-390xx
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2018.08.09
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:591b)
Display controller Intel Corporation
AVAILABLE:
ATTACHED: PCI
VERSION: 2018.08.09
PRIORITY: 8
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2018.08.09
PRIORITY: 7
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
我在进入LiveCD的时候有尝试过添加acpi_osi=! acpi_osi="Windows 2009"的方法,但是它不起作用。
我是通过修改nouveau.modeset=0进入LiveCD的。
这个是我手误了。。。但是我是在manjaro-settings-manager中安装驱动的。
标准程序是:
Standard procedure would be:
$ sudo mhwd -i pci video-hybrid-intel-nvidia-bumblebee
在这里您可以看到当前没有安装驱动程序。
Here you can see that currently no driver was installed.
video-linux是可以使用的,就是闭源驱动无法安装。
好的,我刚看到这个。 如果可能的话,将英语放在下面会很高兴。
OK, I've just seen this. Would be nice to put English below, if possible.
仍然,最好的尝试从终端安装驱动程序。
Still, the best would trying to install the driver from terminal.
我可以安装上video-hybrid-intel-nvidia-bumblebee驱动程序
I can install the video-hybrid-intel-nvidia-bumblebee driver.
但是在重启之后,会无法进入图形界面,并且风扇声音很大
But after I restarted the computer, I would not be able to enter the graphical interface and the fan sound was very loud.
并且我在tty界面中执行sudo mhwd -r pci video-hybrid-intel-nvidia-bumblebee时电脑会卡死
When I execute sudo mhwd -r pci video-hybrid-intel-nvidia-bumblebee in the tty interface, the computer will get stuck
好的,试试这组命令:
OK, try this set of commands in TTY (using ctrl+alt+F2, return with ctrl+alt+F1)
$ sudo mhwd -r pci video-hybrid-intel-nvidia-bumblebee
$ sudo pacman -S virtualgl lib32-virtualgl lib32-primus primus
$ sudo mhwd -a pci nonfree 0300
$ sudo gpasswd -a {user] bumblebee
#用您的实际用户名替换{user}
#replace {user} with your actual user name
$ sudo systemctl enable bumblebeed
然后重启。
Then reboot.
还是和之前一样
the same as last time
执行后驱动安装上了 但是重启后会卡死
The driver is installed, but the computer is stuck after rebooting
可能是你有一种类型的笔记本电脑,即使使用现场媒体也无法在没有特殊干预步骤的情况下启动。
It could be that you have a type of laptop that won't boot without special intervening steps even with the live media.
对不起,我不确定我能帮助你。
I'm not sure I can help you with that, sorry.
没关系 在禁用nouveau后 我可以使用video-linux运行manjaro
It doesn't matter.After adding nouveau to the blacklist.I can run manjaro with video-linux.
那很棒!
That's great!
Have you tried any kernel parameters, like acpi something? They are helping many similar nvidia cases.
I used "acpi_osi=! acpi_osi="Windows 2009"".But it seems to have no effect。
