Last night I was working on the PC just fine, rebooted from Plasma to my windows drive. When I came back, the Intel i211 NIC vanished and only my 2.5Gbit interface is showing. Both of these are on the board (X570-E).
There were no updates between reboot last night, no updates available. Windows works fine with both NIC, so it’s not a bad interface.
Looking for help in figuring out how to get it back, ideally without a format, even though it’s fairly painless, I want to find the cause vs nuclear.
Cheers
Edit: They all seem to come up. Realtek works fine, wifi works fine as well
lspci | egrep -i --color 'network|ethernet|wireless|wi-fi'
06:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller
08:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
inxi --admin --verbosity=7 --filter --no-host --width 22 ✘
Kernel: 5.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=d388f54a-3c20-437f-aa23-84796a407aab rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4021
date: 08/09/2021
RAM: total: 31.32 GiB used: 2.63 GiB (8.4%)
RAM Report:
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2900 high: 3594 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3591 2: 3594
3: 2873 4: 2871 5: 2876 6: 2875 7: 2871 8: 2870 9: 2484 10: 2233 11: 2789
12: 2229 13: 3588 14: 3591 15: 2874 16: 2874 17: 2868 18: 3590 19: 2235
20: 2231 21: 2558 22: 2580 23: 3592 24: 2866 bogomips: 177326
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-2,DP-3 empty: HDMI-A-1 bus-ID: 0e:00.0 chip-ID: 1002:731f
class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4481x2520 s-dpi: 96 s-size: 1185x666mm (46.65x26.22")
s-diag: 1359mm (53.52")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-left
model: Dell S2721DGF serial: <filter> built: 2021 res: 2560x1440 dpi: 109
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: middle-c
model: LG (GoldStar) ULTRAWIDE serial: <filter> built: 2016 res: 2560x1080
dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15") diag: 869mm (34.2")
modes: max: 2560x1080 min: 720x400
Monitor-3: DP-3 mapped: DisplayPort-2 pos: bottom-r model: Dell U2311H
serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL:
renderer: AMD Radeon RX 5700 (navi10 LLVM 13.0.1 DRM 3.44 5.17.9-1-MANJARO)
v: 4.6 Mesa 22.0.4 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 11:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech USB Headset type: USB driver: snd-usb-audio
bus-ID: 3-1:2 chip-ID: 046d:0a01 class-ID: 0102
Sound Server-1: ALSA v: k5.17.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
**Network:**
** Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2**
** speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280**
** IF: wlp6s0 state: up mac: <filter>**
** IP v4: <filter> type: dynamic noprefixroute scope: global**
** broadcast: <filter>**
** IP v6: <filter> type: noprefixroute scope: link**
** Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel**
** pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0**
** chip-ID: 10ec:8125 class-ID: 0200**
** IF: enp7s0 state: up speed: 2500 Mbps duplex: full mac: <filter>**
** Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel**
** pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0**
** chip-ID: 8086:1539 class-ID: 0200**
** IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>**
** IP v4: <filter> type: noprefixroute scope: global broadcast: <filter>**
** WAN IP: <filter>**
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:7
Local Storage: total: 4.38 TiB used: 1.9 TiB (43.4%)
System Temperatures: cpu: 30.0 C mobo: 36.0 C gpu: amdgpu temp: 32.0 C
mem: 36.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 65535
Processes: 481 Uptime: 1m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1431 pacman: 1428 lib: 431
flatpak: 3 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.16
As you can see, enp8s0 state: up, but it’s not coming up in the GUI and I can’t seem to change it’s settings / access it.
