It does find the occurrences of the file. So, the index is alright, I guess.
$ tracker3 status
Currently indexed: 55382 files, 5430 folders
Remaining space on database partition: 38.1?GB (26.88%)
All data miners are idle, indexing complete
52 recorded failures
The log looks good to me (deleted some lines, which stated that it found and processed other directories).
Mai 20 16:17:27 ${HOSTNAME} tracker-miner-f[96328]: Adding:'/usr/local/share/applications'
Mai 20 16:17:27 ${HOSTNAME} tracker-miner-f[96328]: Adding:'/usr/share/applications'
Mai 20 16:17:27 ${HOSTNAME} tracker-miner-f[96328]: Adding:'/home/${USER}/.local/share/applications'
Mai 20 16:17:27 ${HOSTNAME} tracker-miner-f[96328]: Not setting disk space, configuration is set to -1 (disabled)
Mai 20 16:17:27 ${HOSTNAME} tracker-miner-f[96328]: Current and previous locales match: 'de_DE.UTF-8'
Mai 20 16:17:27 ${HOSTNAME} systemd[2327]: Started Tracker file system data miner.
Mai 20 16:17:27 ${HOSTNAME} tracker-miner-f[96328]: Checking whether to crawl file system based on configured crawling interval:
Mai 20 16:17:27 ${HOSTNAME} tracker-miner-f[96328]: Maybe (depends on a clean last shutdown)
Mai 20 16:17:27 ${HOSTNAME} tracker-miner-f[96328]: Checking whether to force mtime checking during crawling (based on last clean shutdown):
Mai 20 16:17:27 ${HOSTNAME} tracker-miner-f[96328]: Yes
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: [Event Queues] New UPDATED event: file:///home/${USER}
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: [Event Queues] Setting up queue handlers...
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: [Event Queues] scheduled in idle
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: Notified files after 0,70 seconds
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: Found 52 directories, ignored 36 directories
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: Found 88 files, ignored 26 files
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: Notified files after 0,13 seconds
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: Found 2 directories, ignored 0 directories
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: Found 18 files, ignored 0 files
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: Processing file 'file:///home/${USER}'...
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: [Event Queues] cancelled: already one active
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: Notified files after 0,23 seconds
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: Found 1 directories, ignored 0 directories
Mai 20 16:17:43 ${HOSTNAME} tracker-miner-f[96328]: Found 2 files, ignored 0 files
Mai 20 16:17:47 ${HOSTNAME} tracker-miner-f[96328]: [Event Queues] New UPDATED event: file:///media/Daten/100-Pers%C3%B6nlich/10-Wissensverwaltung
Mai 20 16:17:47 ${HOSTNAME} tracker-miner-f[96328]: [Event Queues] Setting up queue handlers...
Mai 20 16:17:47 ${HOSTNAME} tracker-miner-f[96328]: [Event Queues] cancelled: already one active
Mai 20 16:17:47 ${HOSTNAME} tracker-miner-f[96328]: Processing file 'file:///media/Daten/100-Pers%C3%B6nlich/10-Wissensverwaltung'...
Mai 20 16:17:57 ${HOSTNAME} tracker-miner-f[96328]: Notified files after 12,82 seconds
Mai 20 16:17:57 ${HOSTNAME} tracker-miner-f[96328]: Found 5131 directories, ignored 30 directories
Mai 20 16:17:57 ${HOSTNAME} tracker-miner-f[96328]: Found 55117 files, ignored 356 files
Mai 20 16:17:57 ${HOSTNAME} tracker-miner-f[96328]: Notified files after 0,02 seconds
Mai 20 16:17:57 ${HOSTNAME} tracker-miner-f[96328]: Found 0 directories, ignored 0 directories
Mai 20 16:17:57 ${HOSTNAME} tracker-miner-f[96328]: Found 0 files, ignored 0 files
Mai 20 16:17:57 ${HOSTNAME} tracker-miner-f[96328]: Notified files after 0,29 seconds
Mai 20 16:17:57 ${HOSTNAME} tracker-miner-f[96328]: Found 1 directories, ignored 0 directories
Mai 20 16:17:57 ${HOSTNAME} tracker-miner-f[96328]: Found 236 files, ignored 1 files
Mai 20 16:17:58 ${HOSTNAME} tracker-miner-f[96328]: Notified files after 0,25 seconds
Mai 20 16:17:58 ${HOSTNAME} tracker-miner-f[96328]: Found 1 directories, ignored 0 directories
Mai 20 16:17:58 ${HOSTNAME} tracker-miner-f[96328]: Found 21 files, ignored 1 files
Mai 20 16:17:58 ${HOSTNAME} tracker-miner-f[96328]: [Event Queues] Setting up queue handlers...
Mai 20 16:17:58 ${HOSTNAME} tracker-miner-f[96328]: [Event Queues] scheduled in idle
Mai 20 16:17:58 ${HOSTNAME} tracker-miner-f[96328]: Flushing SPARQL buffer, reason: Queue handlers NONE
Mai 20 16:17:58 ${HOSTNAME} tracker-miner-f[96328]: (Sparql buffer) Finished array-update with 17 tasks
Mai 20 16:17:58 ${HOSTNAME} systemd[2327]: Starting Tracker metadata extractor...
Mai 20 16:17:58 ${HOSTNAME} systemd[2327]: Started Tracker metadata extractor.
I guess ↑ this is the main problem. Is there a way to lift the restriction to $HOME
Regards
