Intel HD Audio is not detected (Dummy Output)
Hi, unfortunately my Intel HD Audio is not working currently.
Several info:
cat /proc/asound/cards
--- no soundcards ---
cat /proc/asound/devices
33: : timer
lspci
00:00.0 Host bridge: Intel Corporation Device 5904 (rev 02)
00:02.0 VGA compatible controller: Intel Corporation Device 5916 (rev 02)
00:04.0 Signal processing controller: Intel Corporation Skylake Processor Thermal Subsystem (rev 02)
00:08.0 System peripheral: Intel Corporation Skylake Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Device 9d58 (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Device 9d71 (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 07)
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
aplay -l
aplay: device_list:270: no soundcards found...
sudo aplay -l
lsmod | grep snd
snd_soc_skl 61440 0
snd_soc_skl_ipc 36864 1 snd_soc_skl
snd_soc_sst_ipc 16384 1 snd_soc_skl_ipc
snd_soc_sst_dsp 20480 1 snd_soc_skl_ipc
snd_hda_ext_core 20480 1 snd_soc_skl
snd_soc_sst_match 16384 1 snd_soc_skl
snd_soc_core 188416 1 snd_soc_skl
snd_compress 20480 1 snd_soc_core
snd_pcm_dmaengine 16384 1 snd_soc_core
ac97_bus 16384 1 snd_soc_core
snd_hda_intel 32768 0
snd_hda_codec 106496 1 snd_hda_intel
snd_hda_core 65536 4 snd_hda_intel,snd_hda_codec,snd_hda_ext_core,snd_soc_skl
snd_hwdep 16384 1 snd_hda_codec
snd_pcm 90112 7 snd_hda_intel,snd_hda_codec,snd_pcm_dmaengine,snd_hda_ext_core,snd_hda_core,snd_soc_skl,snd_soc_core
snd_timer 28672 1 snd_pcm
snd 69632 7 snd_compress,snd_hda_intel,snd_hwdep,snd_hda_codec,snd_timer,snd_soc_core,snd_pcm
soundcore 16384 1 snd
dmesg | grep -i -e audio -e snd
[ 12.499446] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 12.613040] snd_hda_intel 0000:00:1f.3: CORB reset timeout#1, CORBRP = 0
[ 12.614696] snd_hda_intel 0000:00:1f.3: no codecs found!
I will appreciate any help, thank you in advance.
could you check
lspci -vv | grep HD
sudo journalctl -b0 | grep snd_hda
lspci -vv | grep HD prints nothing.
May 29 02:30:02 berehp kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
May 29 02:30:02 berehp kernel: snd_hda_intel 0000:00:1f.3: CORB reset timeout#1, CORBRP = 0
May 29 02:30:02 berehp kernel: snd_hda_intel 0000:00:1f.3: no codecs found!
Also that could be helpful;
inxi -Fxz
System: Host: berehp Kernel: 4.9.13-1-MANJARO x86_64 (64 bit gcc: 6.3.1)
Desktop: Xfce 4.12.3 (Gtk 2.24.31) Distro: Manjaro Linux
Machine: Device: laptop System: HP product: HP Notebook v: Type1ProductConfigId
Mobo: HP model: 81DD v: KBC Version 69.08
UEFI: Insyde v: F.22 date: 11/04/2016
Battery BAT0: charge: 28.0 Wh 100.0% condition: 28.0/28.0 Wh (100%)
model: Hewlett-Packard Primary status: Full
CPU: Dual core Intel Core i5-7200U (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10852
clock speeds: max: 3100 MHz 1: 596 MHz 2: 562 MHz 3: 600 MHz
4: 676 MHz
Graphics: Card: Intel Device 5916 bus-ID: 00:02.0
Display Server: X.Org 1.19.2 driver: intel
Resolution: 1920x1080@60.01hz
GLX Renderer: Mesa DRI Intel HD Graphics 620 (Kabylake GT2)
GLX Version: 3.0 Mesa 17.0.1 Direct Rendering: Yes
Audio: Card Intel Device 9d71 driver: snd_hda_intel bus-ID: 00:1f.3
Sound: Advanced Linux Sound Architecture v: k4.9.13-1-MANJARO
Network: Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
driver: r8169 v: 2.3LK-NAPI port: 4000 bus-ID: 01:00.0
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac:
Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter
driver: rtl8723be port: 3000 bus-ID: 02:00.0
IF: wlp2s0 state: up mac:
Drives: HDD Total Size: 272.1GB (4.4% used)
ID-1: /dev/sda model: SanDisk_SD8SNAT size: 256.1GB
ID-2: USB /dev/sdb model: Cruzer_Blade size: 16.0GB
Partition: ID-1: / size: 225G used: 12G (6%) fs: ext4 dev: /dev/dm-0
Sensors: System Temperatures: cpu: 38.0C mobo: 0.0C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 174 Uptime: 8:35 Memory: 1640.1/7905.9MB
Init: systemd Gcc sys: 6.3.1
Client: Shell (bash 4.4.121) inxi: 2.3.8
Tried a full system upgrade, then downgrading kernel 4.9 to 4.4. After kernel downgrade Manjaro did not boot up, after selecting kernel 4.9, I got my audio back. It seems like it is not detecting plugging/unplugging headphones, I need to manually switch output audio route. Currently I have a “alsa-base.conf” file in /etc/modprobe.d which contains single line that
options snd-hda-intel model=laptop-hp
which seemed has no effect over any codec detection problem until downgrade-reboot-switch back to 4.9 event.
I will update this thread until I get it to working.
