Intel AX210 - no Bluetooth
Hi,
I am using a Dell Wyse Thinclient and installed a Intel AX210 M.2 Card. Wifi works fine, but no bluetooth.
inxi -Fazy gives me no Bluetooth section at all.
With lsusb, I do not see the device
[fernseher@fernseher-wyse5070thinclient ~]$ lsusb
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub
Bus 001 Device 003: ID 0bda:5415 Realtek Semiconductor Corp. 2-Port USB 2.0 Hub
Bus 001 Device 004: ID 046d:c534 Logitech, Inc. Nano Receiver
Bus 001 Device 006: ID 1997:2466 Shenzhen Riitek Technology Co., Ltd Wireless Receiver
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp. Hub
Bus 002 Device 003: ID 0bda:0415 Realtek Semiconductor Corp. 2-Port
So I guess that it is not recognized on the hardware level, right? Maybe the dell Wyse does not support USB on the m.2 connector, but the original Wifi module must also use USB for BLuetooth, I guess?
I also clicked trough the bios to see if there is a setting but could not find any.
I see that this is going a bit of topic for manjaro, but maybe somebody here can help me out?
Hi @Simon6785 ,
Please, read this old post and consider to try install an older kernel, in order to solve your problem.
Bluetooth not working: not default controller available - #4 by Cenwen
Hope it help,
Regards
but shouldn’t I see any usb device even with a newer kernel?
The device is a m.2 card - I assume it is listed on the PCI bus
lspci
