d7rk
20 February 2021 10:10
1
Hi,
I’m having what looks like the same problem as other posts here, but they do not seem to have been solved or their solution do not work for me.
As mentioned in the subject, I have an Intel AX2000 chip (not a dongle) that I’ve added a while back to my desktop computer to get wifi and bluetooth. However, while the wifi has been working very well, the bluetooth has never worked.
I have tried kernels 5.4 and 5.10.
Gnome settings indicates No bluetooth found
Bluetoothctl indicates: No default controller available
After a (blind) sudo modprobe btusb
read about elsewhere I’ve managed to start bluetooth in systemctl, which now reports:
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2021-02-20 09:45:48 GMT; 13min ago
Docs: man:bluetoothd(8)
Main PID: 3154 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 19049)
Memory: 968.0K
CGroup: /system.slice/bluetooth.service
└─3154 /usr/lib/bluetooth/bluetoothd
Feb 20 09:45:48 v-work bluetoothd[3154]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalConnect” in group “Controller”
Feb 20 09:45:48 v-work bluetoothd[3154]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowConnect” in group “Controller”
Feb 20 09:45:48 v-work bluetoothd[3154]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in group “Controller”
Feb 20 09:45:48 v-work bluetoothd[3154]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in group “Controller”
Feb 20 09:45:48 v-work bluetoothd[3154]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
Feb 20 09:45:48 v-work bluetoothd[3154]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Controller”
Feb 20 09:45:48 v-work bluetoothd[3154]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
Feb 20 09:45:48 v-work systemd[1]: Started Bluetooth service.
Feb 20 09:45:48 v-work bluetoothd[3154]: Starting SDP server
Feb 20 09:45:48 v-work bluetoothd[3154]: Bluetooth management interface 1.14 initialized
But still no device is found.
I seem to have an older iwlw firmware than in other posts, although my computer is updated (stable):
dmesg | grep iwlw
[ 4.634048] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[ 4.645009] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 58.3.35.22
[ 4.645013] iwlwifi 0000:03:00.0: Found debug destination: EXTERNAL_DRAM
[ 4.645014] iwlwifi 0000:03:00.0: Found debug configuration: 0
[ 4.645255] iwlwifi 0000:03:00.0: loaded firmware version 50.3e391d3e.0 op_mode iwlmvm
[ 4.767987] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 4.779105] iwlwifi 0000:03:00.0: Applying debug destination EXTERNAL_DRAM
[ 4.779482] iwlwifi 0000:03:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ 4.949720] iwlwifi 0000:03:00.0: base HW address: 78:2b:46:29:b5:71
[ 4.964431] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[ 5.691581] iwlwifi 0000:03:00.0: Applying debug destination EXTERNAL_DRAM
[ 5.861770] iwlwifi 0000:03:00.0: FW already configured (0) - re-configuring
[ 5.892441] iwlwifi 0000:03:00.0: Applying debug destination EXTERNAL_DRAM
[ 6.062862] iwlwifi 0000:03:00.0: FW already configured (0) - re-configuring
Here is my config:
System: Kernel: 5.4.97-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=78e53ff4-c09a-4246-8901-b3b707cda837 rw quiet
resume=UUID=5e3f140a-b7c1-4839-91af-8fa9c48dac3d
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1 Distro: Manjaro Linux
Machine: Type: Desktop System: MSI product: MS-7817 v: 1.0 serial: <filter>
Mobo: MSI model: H81M-E33 (MS-7817) v: 1.0 serial: <filter> UEFI: American Megatrends v: 6.7 date: 04/21/2015
Battery: Device-1: hidpp_battery_0 model: Logitech M505/B605 serial: <filter> charge: 35% rechargeable: yes
status: Discharging
Memory: RAM: total: 15.52 GiB used: 2.62 GiB (16.9%)
CPU: Info: Quad Core model: Intel Core i5-4460 bits: 64 type: MCP arch: Haswell family: 6 model-id: 3C (60) stepping: 3
microcode: 28 L2 cache: 6 MiB bogomips: 25608
Speed: 900 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 901
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc
nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Micro-Star MSI driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0412 class ID: 0300
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver: loaded: intel display ID: 0
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c class ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:8c20 class ID: 0403
Sound Server: ALSA v: k5.4.97-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8168
v: 8.048.03-NAPI modules: r8169 port: e000 bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000 bus ID: 03:00.0 chip ID: 8086:2723
class ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> type: noprefixroute scope: global
IP v6: <filter> type: noprefixroute stable-privacy scope: link
Bluetooth: Message: No Bluetooth data was found.
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 1.02 TiB used: 374.6 GiB (35.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1SB10C size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC43 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SV300S37A120G size: 111.79 GiB block size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s rotation: SSD serial: <filter> rev: BBF0 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD0 rev: LH00 dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition: ID-1: / raw size: 102.99 GiB size: 100.87 GiB (97.94%) used: 91.6 GiB (90.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
label: N/A uuid: 78e53ff4-c09a-4246-8901-b3b707cda837
ID-2: /boot/efi raw size: 550.2 MiB size: 549.1 MiB (99.80%) used: 256 KiB (0.0%) fs: vfat dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: 9504-E886
ID-3: /run/media/v/Bold raw size: 443.23 GiB size: 436.15 GiB (98.40%) used: 282.81 GiB (64.8%) fs: ext4
dev: /dev/sda2 maj-min: 8:2 label: Bold uuid: e8283074-4d3c-4d4f-b437-d881d41175e6
ID-4: /run/media/v/Brick raw size: 488.28 GiB size: 480.49 GiB (98.41%) used: 196.9 MiB (0.0%) fs: ext4
dev: /dev/sda1 maj-min: 8:1 label: Brick uuid: 94c72275-019d-40ab-bb8a-2512377f6758
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.26 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 5e3f140a-b7c1-4839-91af-8fa9c48dac3d
Unmounted: Message: No Unmounted partitions found.
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 8087:8008
class ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 2-2:2 info: Logitech Keyboard K120 type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s chip ID: 046d:c31c class ID: 0300
Device-2: 2-6:3 info: Super Top Mass Storage Device type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s chip ID: 14cd:125d class ID: 0806 serial: <filter>
Device-3: 2-8:5 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c52b class ID: 0300
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-5: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 8087:8000
class ID: 0900
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003 class ID: 0900
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C
Info: Processes: 218 Uptime: 28m wakeups: 7 Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.1 Packages:
pacman: 1640 lib: 479 rpm: 0 flatpak: 0 Shell: Zsh v: 5.8 running in: tilix inxi: 3.3.01
Thanks!
Fabby
21 February 2021 14:15
2
Is the inxi
output before or after the modprobe
d7rk
22 February 2021 09:23
3
I do not know but this one is after rebooting, presumably back into pre-modprobe
state:
System: Kernel: 5.4.97-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: GNOME 3.38.3 tk: GTK 3.24.24
status: Discharging
Memory: RAM: total: 15.52 GiB used: 3.28 GiB (21.2%)
CPU: Info: Quad Core model: Intel Core i5-4460 bits: 64 type: MCP arch: Haswell rev: 3 L2 cache: 6 MiB bogomips: 25613
Speed: 1124 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 1124 2: 1188 3: 1218 4: 1214
v: 8.048.03-NAPI port: e000 bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
class ID: 0280
Drives: Local Storage: total: 1.93 TiB used: 1.34 TiB (69.5%)
ID-1: /dev/sda vendor: Seagate model: ST1000DM003-1SB10C size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm
ID-2: /dev/sdb vendor: Kingston model: SV300S37A120G size: 111.79 GiB speed: 3.0 Gb/s rotation: SSD
ID-3: /dev/sdd type: USB vendor: Western Digital model: WD My Passport 0741 size: 931.48 GiB serial: <filter>
rev: 1022 scheme: MBR
Partition: ID-1: / size: 100.87 GiB used: 91.82 GiB (91.0%) fs: ext4 dev: /dev/sdb1 label: N/A
ID-2: /boot/efi size: 549.1 MiB used: 256 KiB (0.0%) fs: vfat dev: /dev/sdb2 label: N/A uuid: 9504-E886
ID-3: /home/<filter>/Private size: 100.87 GiB used: 91.82 GiB (91.0%) fs: ecryptfs source: ERR-102 label: N/A
uuid: N/A
ID-4: /run/media/v/Bold size: 436.15 GiB used: 282.91 GiB (64.9%) fs: ext4 dev: /dev/sda2 label: Bold
ID-5: /run/media/v/Brick size: 480.49 GiB used: 196.9 MiB (0.0%) fs: ext4 dev: /dev/sda1 label: Brick
ID-6: /run/media/v/Bust size: 931.48 GiB used: 905.9 GiB (97.3%) fs: ntfs dev: /dev/sdd1 label: Bust
uuid: 1443B3DA24384F55
Swap: ID-1: swap-1 type: partition size: 8.26 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb3 label: N/A
class ID: 0900
Device-2: 2-3:5 info: Western Digital My Passport Ultra type: Mass Storage driver: usb-storage interfaces: 1
rev: 2.1 speed: 480 Mb/s chip ID: 1058:0741 class ID: 0806 serial: <filter>
Device-3: 2-6:3 info: Super Top Mass Storage Device type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
Device-4: 2-8:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid
class ID: 0900
Info: Processes: 252 Uptime: 34m wakeups: 8 Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.1 Packages:
pacman: 1640 Shell: Zsh v: 5.8 running in: tilix inxi: 3.3.01
And after:
status: Discharging
Memory: RAM: total: 15.52 GiB used: 3.46 GiB (22.3%)
Speed: 800 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
class ID: 0280
uuid: N/A
class ID: 0900
class ID: 0900
Info: Processes: 256 Uptime: 36m wakeups: 8 Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.1 Packages:
Fabby
22 February 2021 09:36
4
It’s the same: no Bluetooth data can be found, so what’s the output of:
lspci | grep --ignore-case blue
lsusb | grep --ignore-case blue
after a fresh reboot and after the modprobe?
Also, what’s the output of:
ls /etc/modprobe.d/
(I.E. did you blacklist Bluetooth in the past?)
d7rk
22 February 2021 09:47
5
They both return nothing.
And ls /etc/modprobe.d/
returns:
r8169_blacklist.conf
Fabby
22 February 2021 18:54
7
cat /etc/modprobe.d/r8169_blacklist.conf
Please?
d7rk
22 February 2021 21:25
8
It gives:
blacklist r8169
Thanks!
Fabby
22 February 2021 21:52
9
Hrmpf… (Thanks for your effort, but not what I was expecting… )
What’s the output of:
rfkill list
d7rk
23 February 2021 16:04
10
It gives:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
d7rk
23 February 2021 18:33
12
Alas no.
Thank you for the help!
Fabby
23 February 2021 21:50
13
Ona last piece of advice: Buy a Bluetooth dongle that is Linux compatible… (Check before you buy that it’s Kernel 5.X compatible!)
