Intel Arc B580 stuck loading after bootloader
Hi folks,
So I switched my GPU yesterday from a 5700XT to a Sparkle ARC B580. I first started Windows in my dual boot configuration (TPM is disabled) to install the latest drivers (SoC firmware included, since its currently not possible on Linux). The GPU is detected fine in GPU-Z.
I installed the latest chipset drivers and the latest motherboard BIOS version.
I enabled ReBar (above 4G decoding enabled too). ASPM was already enabled (to massively reduce the GPU power draw when doing nothing).
First time Manjaro booted fine, and I hopped directly into two games to check the FPS:
  • Hogwarts Legacy, AMD: ~112 FPS, Intel: ~35 FPS with heavy graphical glitches (I checked with AMD FSR 2 and Intel XeSS, no changes)
  • AC Origins: AMD: ~73 FPS, Intel: Did not load after menu screen
I thought this was really weird since many people said the card should perform fine.
So I switched back to Windows and started AC Origins there and achieved around 45 FPS with heavy stuttering.
But now I can’t even load Manjaro since it is stuck loading after selecting Manjaro in the bootloader. When switching back to the 5700 XT Manjaro loads fine. Then switched back to the Sparkle Arc B580 again and I was stuck loading.
I tried both kernel 6.12 and 6.13.
I will upload my system specifications in the evening since I’m not home till then.
Hope someone can help, since I want to believe in Intel further advancing in the GPU market. I don’t care if I could have gotten a better AMD/Nvidia for equal money.
I suggest using
sudo inxi -zv8
for overall info about the system.
From 2024-12-11T23:00:00Zhttps://www.phoronix.com/review/intel-arc-b580-graphics-linux
Those wanting to use Intel Battlemage graphics on Linux will still need to resort to using a very recent Linux kernel and Mesa drivers, but it’s at least all upstream for launch and much more mature than it was at the time for Alchemist. For those planning to buy an Intel Arc B580 graphics card tomorrow, you will need to be at least on the Linux 6.12 stable kernel for that’s the first mainline kernel where Xe2 graphics are enabled out-of-the-box and all the necessary bits are in place. But if you don’t mind a bit living on the edge, the Linux 6.13 Git kernel has even more Intel Xe2/Battlemage improvements.
The road …
  1. switch to Manjaro Edge branch (unstable)
  2. run a full system sync
  3. use the latest upstream kernel (kernel.org 6.14)
sudo pacman-mirrors --api --set-branch unstable
sudo pacman -Syu
mhwd-kernel -i linux614
reboot
//Afterthought: this is a guess - I’d be sure to shutdown Windows fully - sometimes Windows Fast Startup is preventing hardware from being fully functional.
Switching to unstable and kernel 6.14 should not be necessary since Michael from Phoronix ran the GPU with kernel 6.13 and it worked without problems (
…you will need to be on Linux 6.12+ and Mesa 24.3+
According to https://manjaristas.org/branch_compare?q=mesa there is no difference in the mesa version if I switch to unstable.
And if I want bleeding-edge, I rather switch to Arch itself.
I will check if fast startup is activated or not in Windows.
If it is, this will likely be quicker to disable it:
powercfg /h off
(from an administrative cmd prompt)
As promised, the output of sudo inxi -zv8:
I installed the 5700 XT GPU again to boot into Manjaro.
Summary
  Kernel: 6.13.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64
    root=UUID=45797e1e-3f6c-488a-bf1f-297865d468a9 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-F GAMING v: Rev X.0x
    serial: <filter> part-nu: SKU uuid: 37fb448c-094e-fe35-dcc3-04d9f5f5603e
    UEFI: American Megatrends v: 5021 date: 09/26/2024
  System RAM: total: 32 GiB available: 31.25 GiB used: 5.46 GiB (17.5%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK16GX4M2B3000C15 serial: N/A
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:03.1
    children: 1: 09:00.0 class-ID: 0604 type: bridge children: 1: 0a:00.0
    class-ID: 0604 type: bridge children: 1: 0b:00.0 class-ID: 0300
    type: display 2: 0b:00.1 class-ID: 0403 type: audio
  Slot: 1 type: PCIe status: available length: long volts: 3.3
    bus-ID: 00:1f.7
  Slot: 2 type: PCIe status: available length: long volts: 3.3
    bus-ID: 00:1f.7
  Slot: 3 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 4 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Info: model: AMD Ryzen 9 3900X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
    gen: 2 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 64 MiB desc: 4x16 MiB
  Speed (MHz): avg: 1744 min/max: 550/4673 boost: enabled
    base/boost: 3800/4650 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 1744 2: 1744 3: 1744 4: 1744
    5: 1744 6: 1744 7: 1744 8: 1744 9: 1744 10: 1744 11: 1744 12: 1744
    13: 1744 14: 1744 15: 1744 16: 1744 17: 1744 18: 1744 19: 1744 20: 1744
    21: 1744 22: 1744 23: 1744 24: 1744 bogomips: 182121
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600
    XT / 5700/5700 XT] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-1
    code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,HDMI-A-2
    bus-ID: 0b:00.0 chip-ID: 1002:731f class-ID: 0300
  Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1355x381mm (53.35x15.00")
    s-diag: 1408mm (55.42")
  Monitor-1: DP-1 pos: primary,right model: PG27AQDM serial: <filter>
    built: 2023 res: mode: 2560x1440 hz: 240 scale: 100% (1) dpi: 110 gamma: 1.2
    chroma: red: x: 0.678 y: 0.322 green: x: 0.255 y: 0.686 blue: x: 0.145
    y: 0.051 white: x: 0.290 y: 0.298 size: 590x334mm (23.23x13.15")
    diag: 695mm (27.3") ratio: 15:9, 16:9 modes: 2560x1440, 1920x1200,
    1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: HDMI-A-1 pos: left model: AOC Q32G1WG4 serial: <filter>
    built: 2019 res: mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 93 gamma: 1.2
    chroma: red: x: 0.682 y: 0.314 green: x: 0.282 y: 0.655 blue: x: 0.145
    y: 0.067 white: x: 0.314 y: 0.329 size: 697x393mm (27.44x15.47")
    diag: 800mm (31.5") ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080,
    1600x1200, 1280x1440, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
    navi10 LLVM 19.1.7 DRM 3.59 6.13.0-1-MANJARO) device-ID: 1002:731f
    memory: 7.81 GiB unified: no
  API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu name: AMD
    Radeon RX 5700 XT (RADV NAVI10) driver: N/A device-ID: 1002:731f
    surfaces: xcb,xlib
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
    bus-ID: 0b:00.1 chip-ID: 1002:ab38 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.13.0-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 3.64 TiB used: 1.4 TiB (38.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QGXA7 temp: 32.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 46d 12h cycles: 2,228
    read-units: 53,183,710 [27.2 TB] written-units: 42,573,457 [21.7 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Corsair model: Force MP600
    lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM11.1 temp: 30.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 1y 131d 4h cycles: 3,157
    read-units: 117,000,646 [59.9 TB] written-units: 91,504,476 [46.8 TB]
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 2TB
    family: based SSDs size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3B6Q
    temp: 25 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 27d 8h cycles: 244
    written: 2.39 TiB
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 258.81 GiB (28.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:8 label: N/A uuid: 45797e1e-3f6c-488a-bf1f-297865d468a9
    used: 292 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:7 label: N/A uuid: 1731-2E75
  ID-3: /mnt/disk1 raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 1.15 TiB (64.1%) fs: ext4 block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: N/A uuid: 8bae2c6f-a88c-4445-964b-c66565013d98
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: A63E-26CE
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 930.16 GiB fs: ntfs label: N/A
    uuid: 2402408D02406640
  ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 736 MiB fs: ntfs label: N/A
    uuid: 0AEE38C7EE38ACB7
  ID-5: /dev/nvme1n1p5 maj-min: 259:5 size: 525 MiB fs: ntfs label: N/A
    uuid: E8BA2E0DBA2DD938
  Device-1: 1-3:2 info: Razer USA Viper 8KHz type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 1532:0091 class-ID: 0301
  Device-2: 1-4:3 info: Corsair Gaming K55 RGB Keyboard type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1b1c:1b3d class-ID: 0300
    serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
    serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 37.0 C mobo: 29.0 C gpu: amdgpu temp: 45.0 C
    mem: 48.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 1570 pm: pacman pkgs: 1559 libs: 483 tools: pamac pm: flatpak
    pkgs: 11
    1: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    2: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    3: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    4: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    5: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    6: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    7: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 523
  1: cpu: 100% command: ps pid: 5956 mem: 4.03 MiB (0.0%)
  2: cpu: 50.5% command: firefox pid: 4461 mem: 645.7 MiB (2.0%)
  3: cpu: 28.0% command: pamac-manager pid: 2258 mem: 999.0 MiB (3.1%)
  4: cpu: 23.6% command: steam pid: 3585 mem: 216.0 MiB (0.6%)
  5: cpu: 19.7% command: firefox pid: 4926 mem: 253.4 MiB (0.7%)
  Memory top: 5 of 523
  1: mem: 999.0 MiB (3.1%) command: pamac-manager pid: 2258 cpu: 28.0%
  2: mem: 645.7 MiB (2.0%) command: firefox pid: 4461 cpu: 50.5%
  3: mem: 513.7 MiB (1.6%) command: plasmashell pid: 1287 cpu: 5.8%
  4: mem: 443.2 MiB (1.3%) command: ./steamwebhelper pid: 3860 cpu: 5.6%
  5: mem: 434.3 MiB (1.3%) command: steamwebhelper pid: 3959 cpu: 15.8%
  Processes: 523 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
Hey MystikReasons. do you have an update on your issue. your the first to have the same exact issue as me, except my non-B580 card is a GTX1070. the b580 works great in windows as well but really wanna ditch microsoft asap. I can boot into linux mint which is my DD i guess but not recognizing displays properly not on any newer kernels like i can on manjaro
Hi @ninjabarney,
I haven’t yet given it another chance since I didn’t had a lot of time. Maybe I can try a next round today since Manjaro released a new stable update :slight_smile:
Hi @ninjabarney
Today I tried it again but a few days ago I switched to EndeavourOS. I’m currently using kernel 6.13.8 with mesa 25.0.3. I tried 7 games and none of them worked (some said they didn’t detect a GPU with D3D11 or D3D12 but it recognized correctly in the OS itself and otherwise it worked fine). I don’t know if I did something wrong but I’m really disappointed. I will try it in a few months again to see if it works better.
