Intel ac 9560 - Firmware issue - No WiFI
wifi can't work in manjaro-gnome 18.1.0
wifi model: intel ac 9560
i have tried the driver in intel offical, but isn't work either.
the following info show the wifi have a driver, but the settings app shows Not found the wifi adapter.
linux-firmware version: linux-firmware 20190815.07b925b-1
inxi -Fxxxz
System:    Host: smilejack-pc Kernel: 5.2.11-1-MANJARO x86_64 bits: 64 compiler: gcc
           v: 9.1.0 Desktop: Gnome 3.32.2 wm: gnome-shell dm: GDM 3.32.0
           Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 81Q2 v: Lenovo XiaoXinAir-14IML 2019
           serial: <filter> Chassis: type: 10 v: Lenovo XiaoXinAir-14IML 2019
           serial: <filter>
           Mobo: LENOVO model: LNVNB161216 v: SDK0K09938 WIN serial: <filter>
           UEFI: LENOVO v: CKCN11WW(V1.01) date: 07/19/2019
Battery:   ID-1: BAT1 charge: 26.3 Wh condition: 53.8/50.0 Wh (108%) volts: 15.4/15.4
           model: 0x53 0x4D 0x50 0x00 0x32 0x30 0x PABAS0241231 type: Li-ion
           serial: <filter> status: Discharging cycles: 2
CPU:       Topology: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
           arch: Kaby Lake rev: C L2 cache: 6144 KiB
           bogomips: 33800
           Speed: 809 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 1434 2: 1265
           3: 1584 4: 1483 5: 1643 6: 1240 7: 1766 8: 1644
Graphics:  Device-1: Intel vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
           chip ID: 8086:9b41
           Device-2: NVIDIA GP108M [GeForce MX250] driver: N/A bus ID: 01:00.0
           chip ID: 10de:1d13
           Display: x11 server: X.org 1.20.5 driver: intel compositor: gnome-shell
           resolution: <xdpyinfo missing>
           OpenGL: renderer: Mesa DRI Intel HD Graphics (Comet Lake 3x8 GT2)
           v: 4.5 Mesa 19.1.5 compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:02c8
           Sound Server: ALSA v: k5.2.11-1-MANJARO
Network:   Device-1: Intel driver: iwlwifi v: kernel port: 4000 bus ID: 00:14.3
           chip ID: 8086:02f0
           Device-2: Realtek RTL8152 Fast Ethernet Adapter type: USB driver: r8152
           bus ID: 1-1.4:11 chip ID: 0bda:8152 serial: <filter>
           IF: enp0s20f0u1u4 state: up speed: 100 Mbps duplex: full mac: <filter>
           IF-ID-1: vboxnet0 state: up speed: 10 Mbps duplex: full mac: <filter>
           IF-ID-2: xdroid0 state: down mac: <filter>
Drives:    Local Storage: total: 476.94 GiB used: 30.45 GiB (6.4%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
           speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 3L1QEXF7 scheme: GPT
Partition: ID-1: / size: 39.12 GiB used: 14.76 GiB (37.7%) fs: ext4 dev: /dev/nvme0n1p6
           ID-2: /home size: 50.64 GiB used: 15.69 GiB (31.0%) fs: ext4
           dev: /dev/nvme0n1p8
           ID-3: swap-1 size: 8.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/nvme0n1p7
Sensors:   System Temperatures: cpu: 44.0 C mobo: N/A
Info:      Processes: 312 Uptime: 6h 28m Memory: 11.44 GiB used: 4.80 GiB (42.0%)
           Init: systemd v: 242 Compilers: gcc: 9.1.0 Shell: bash v: 5.0.9
           running in: gnome-terminal inxi: 3.0.36
logs
journalctl -b |grep iwl
9月 16 08:25:41 smilejack-pc kernel: iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
9月 16 08:25:41 smilejack-pc kernel: iwlwifi 0000:00:14.3: Found debug configuration: 0
9月 16 08:25:41 smilejack-pc kernel: iwlwifi 0000:00:14.3: loaded firmware version 46.93e59cf4.0 op_mode iwlmvm
9月 16 08:25:41 smilejack-pc kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x354
9月 16 08:25:41 smilejack-pc kernel: iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
9月 16 08:25:41 smilejack-pc kernel: iwlwifi 0000:00:14.3: Allocated 0x00400000 bytes for firmware monitor.
9月 16 08:25:46 smilejack-pc kernel: iwlwifi 0000:00:14.3: Failed to load firmware chunk!
9月 16 08:25:46 smilejack-pc kernel: iwlwifi 0000:00:14.3: iwlwifi transaction failed, dumping registers
9月 16 08:25:46 smilejack-pc kernel: iwlwifi 0000:00:14.3: iwlwifi device config registers:
9月 16 08:25:46 smilejack-pc kernel: iwlwifi 0000:00:14.3: 00000000: 02f08086 00100406 02800000 00800010 b4318004 00000000 00000000 00000000
9月 16 08:25:46 smilejack-pc kernel: iwlwifi 0000:00:14.3: 00000020: 00000000 00000000 00000000 00348086 00000000 000000c8 00000000 000001ff
9月 16 08:25:46 smilejack-pc kernel: iwlwifi 0000:00:14.3: iwlwifi device memory mapped registers:
9月 16 08:25:46 smilejack-pc kernel: iwlwifi 0000:00:14.3: 00000000: 18489004 00000040 00000000 00000000 00000000 00000000 00000000 00000000
9月 16 08:25:46 smilejack-pc kernel: iwlwifi 0000:00:14.3: 00000020: 00000011 0c040005 00000351 d55555d5 d55555d5 d55555d5 80008040 001f0040
9月 16 08:25:46 smilejack-pc kernel: iwlwifi 0000:00:14.3: Could not load the [0] uCode section
9月 16 08:25:46 smilejack-pc kernel: iwlwifi 0000:00:14.3: Failed to start INIT ucode: -110
9月 16 08:25:46 smilejack-pc kernel: iwlwifi 0000:00:14.3: Collecting data: trigger 16 fired.
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: Not valid error log pointer 0x00000000 for Init uCode
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: Fseq Registers:
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | FSEQ_ERROR_CODE
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | FSEQ_TOP_INIT_VERSION
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | FSEQ_CNVIO_INIT_VERSION
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | FSEQ_OTP_VERSION
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | FSEQ_TOP_CONTENT_VERSION
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | FSEQ_ALIVE_TOKEN
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | FSEQ_CNVI_ID
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | FSEQ_CNVR_ID
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVI_AUX_MISC_CHIP
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: Failing on timeout while stopping DMA channel 8 [0xa5a5a5a2]
9月 16 08:25:47 smilejack-pc kernel: iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
wifi
wifi      = on
rfkill list all
0: ideapad_wlan: Wireless LAN
	Soft blocked: no
	Hard blocked: no
1: hci0: Bluetooth
	Soft blocked: yes
	Hard blocked: no
lsmod | grep iwl
iwlmvm                466944  0
mac80211             1003520  1 iwlmvm
iwlwifi               385024  1 iwlmvm
cfg80211              856064  3 iwlmvm,iwlwifi,mac80211
lspci
00:00.0 Host bridge: Intel Corporation Device 9b61 (rev 0c)
00:02.0 VGA compatible controller: Intel Corporation Device 9b41 (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0c)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Device 02f9
00:14.0 USB controller: Intel Corporation Device 02ed
00:14.2 RAM memory: Intel Corporation Device 02ef
00:14.3 Network controller: Intel Corporation Device 02f0
00:15.0 Serial bus controller [0c80]: Intel Corporation Device 02e8
00:15.1 Serial bus controller [0c80]: Intel Corporation Device 02e9
00:15.2 Serial bus controller [0c80]: Intel Corporation Device 02ea
00:16.0 Communication controller: Intel Corporation Device 02e0
00:1c.0 PCI bridge: Intel Corporation Device 02bc (rev f0)
00:1d.0 PCI bridge: Intel Corporation Device 02b0 (rev f0)
00:1d.7 PCI bridge: Intel Corporation Device 02b7 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device 0284
00:1f.3 Audio device: Intel Corporation Device 02c8
00:1f.4 SMBus: Intel Corporation Device 02a3
00:1f.5 Serial bus controller [0c80]: Intel Corporation Device 02a4
01:00.0 3D controller: NVIDIA Corporation GP108M [GeForce MX250] (rev ff)
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
03:00.0 SD Host controller: O2 Micro, Inc. SD/MMC Card Reader Controller (rev 01)
mhwd -li
> Installed PCI configs:
video-hybrid-intel-nvidia-430xx-bumblebee            2019.08.24               false            PCI
           video-linux            2018.05.04                true            PCI
try use wifite
it show
 .;'  ,;'             `;,  `;,   WiFite v2 (r87)
::   ::   :   ( )   :   ::   ::  automated wireless auditor
':.  ':.  ':. /_\ ,:'  ,:'  ,:'
 ':.  ':.    /___\    ,:'  ,:'   designed for Linux
  ':.       /_____\      ,:'
 [!] the program reaver is required for WPS attacks
       available at http://code.google.com/p/reaver-wps
 [!] the program tshark is not required, but is recommended
 [!] the program pyrit is not required, but is recommended
 [!] the program cowpatty is not required, but is recommended
 [+] scanning for wireless devices...
 [!] no wireless interfaces were found.
 [!] you need to plug in a wifi device or install drivers.
 [+] quitting
thanks reply
On some intel wireless cards - disabling bluetooth disables wlan as well.
Try unblocking your bluetooth.
A forum search will do you good.
https://forum.manjaro.org/search?q=AC%209560
i have try the way you say, the bluetooth work normally, but the wifi doesn't work.
i have searched the forum about this and try it, but all not work.
does this matter with kernerl version?
Yes the kernel version absolutely matters. Start by installing and testing the newest kernels. Then install older LTS kernels. As a last resort test the most recent real time kernel.
As you have tested the most recent Intel firmware your only alternative (as far as firmware) is to download and test some older firmware versions. Recent Intel firmware has caused many problems with some Intel adapters requiring a firmware downgrade of late.
Awesome set of outputs BTW. Very nicely done.
you can try blacklisting ideapad-laptop
echo "blacklist ideapad-laptop" | sudo tee /etc/modprobe.d/ideapad.conf
then reboot after. if that doesnt help or if it causes other things like hotkeys to stop functioning you can just delete the file
sudo rm /etc/modprobe.d/ideapad.conf
That was the first thing I thought of as well @dglt, but I don't think that is the issue. If that is the problem it usually presents as a hard block in the rfkill output.
I think Lenovo laptops are starting to get better kernel support for the ideapad_laptop module, as this issue doesn't seem as common these days.
i wasnt sure but now that you mention it, it makes sense.
im still using downgraded firmware to fix the connectivity issues on my intel wireless adapter
~ >>> pacman -Qs linux-firmware
local/linux-firmware 20190424.4b6cf2b-1 (base)
    Firmware files for Linux
anything newer seems to have issues
can you send me this package, i can't find it, i just install the system in this new computer some days ago, thanks.
the package is downgrade and you can use it to downgrade the linux-firmware package.
sudo pacman -S downgrade
if your on testing or unstable branch, you can use it like this
downgrade linux-firmware
if your on stable branch, like this
DOWNGRADE_FROM_ALA=1 downgrade linux-firmware
then just choose the version you want
I have the same problem on my YOGA C940, my network card is AX201. I tried driver from intel website, and it doesn't work too.
doesnt work at all? or drops connection frequently?
No. I tried demsg | grep iwlwifi, and it said the driver failed.
(Interestingly, according to demsg, it seems iwlwifi thought my AX201 as AX101. I don't know why.)
Someone erroneously removed the solved tag from this post. I assume that was because of these last few posts reporting the wifi is broken. This thread was solved by downgrading the firmware.
@wanicca is not the OP of this thread. This is a threadjacking. Try the suggested fix or open your own thread please @wanicca.
