instructions to run clamav on manjaro as daemon
anti-virus
#1
I've intended to run clamav on my manjaro setup and ran into some trouble, as the
sudo pacman -S clamav
did of course install clamav on my system, however when trying to enable the service as instructed here https://wiki.manjaro.org/index.php?title=ClamAV
I've just received the notice
Failed to enable unit: Unit file clamd.service does not exist.
I then went to /usr/lib/systemd/system and found the following 3 files
clamav-daemon.service  clamav-daemon.socket  clamav-freshclam.service
With this information, I was able to enable the service and start it by typing
sudo systemctl enable clamav-daemon.service
sudo systemctl enable clamav-freshclam.service
and finally start the daemons for clamav and freshclam
sudo systemctl start clamav-daemon
sudo systemctl start clamav-freshclam
I've also installed clamtk from AUR for a graphical UI and enabled the respective module in Claws Mail to have my mail being checked by clamav.
This is a little writeup for others who also run into issues with setup of clamav.
split this topic #2
2 posts were merged into an existing topic: Wiki Change Request
closed #3
