Installing xmind-zen from AUR.
Should all program files in the AUR install without incidence? In this case I have tried installing xmind-zen and came up with this (error):
Building xmind-zen...
==> Making package: xmind-zen 20190703-1 (Fri 12 Jul 2019 09:40:54 AM EDT)
==> Retrieving sources...
-> Found XMind-ZEN-for-Linux-64bit.rpm
-> Found index.html
-> Found XMind.desktop
-> Found xmind.xml
==> Validating source files with md5sums...
XMind-ZEN-for-Linux-64bit.rpm ... FAILED
index.html ... Skipped
XMind.desktop ... Skipped
XMind.png ... Skipped
xmind.xml ... Skipped
==> ERROR: One or more files did not pass the validity check!
Is this because the package is extention .rpm? If so is there any way to get the install working?
No, it is becasue they offer unversioned packages, file is always called XMind-ZEN-for-Linux-64bit.rpm and when they update the package the hash check in the pkgbuild fails
the procedure is like this Can not install XDM from Pamac replacing xdm with xmind-zen
or like mbb posted below
That error means the source has been updated but the PKGBUILD hasn't. So the validation check fails. You need to download the PKGBUILD to a directory of your choice:
wget https://aur.archlinux.org/cgit/aur.git/snapshot/xmind-zen.tar.gz
Then unpack it:
tar -xf xmind-zen.tar.gz
Then enter that folder and update the checksums:
cd xmind-zen
updpkgsums
Then build and install the package:
makepkg -si
Then you should go to the AUR page and post a comment or flag it out-of-date so the maintainer knows the package needs to be updated.
I tried to built it and is not failing for me, likely your download has been interrupted
